Results 1 to 6 of 6
Thread: DM500plus
    04 Jun 2008
    Brasov
    Default DM500plus
    In afara de PERUVISION mai comercializeaza cineva DM500plus ? Din cite am citit la asta nu sint clone . Asa este ?
    MULTUMESC !
    DM 800 (clona ) ; 1.9 Al ; si altele
    Default Re: DM500plus
    tu ce zici , ia uita-te aici : http://www.sateliti.info/showthread.php?t=6939
    el vrea 500+ nu clona 500s e diferenta!
    gobi2000 , citeste mai atent si fa comparatii intre caracteristiciile celui expus si site-ul unde l-am trimis eu pe cel care a deschis threadul si o sa vezi ca este vorba de acelas receiver DM500 +
    oricum stii foarte bine ca DM500 S nu se mai fabrica de 2 ANI
    DM500 + : http://www.dream-multimedia-tv.de/en..._technical.php caracteristicii
    si de cand are DM500 S modem incorporat si 32Mbyte Flash asa cum scrie la "Pingtech DVB 500" ?
    Code:
    500+
    - 250 MHz PowerPC Processor
    - Linux Operating System
    - 2 LED status
    - MPEG-2 Hardware decoding, DVB-S
    - 1 x Smartcard-Reader
    - 1 x Scart-interfaces (RGB, FBAS or S-Video)
    - V.24/RS232 Interface
    - 10/100Mbit compatible Ethernet Interface
    - analog modem
    - S/PDIF Interface for digital bit stream out (AC-3)
    - 32 MByte Flash, 96 MByte RAM
    - unlimited channel lists for TV/Radio
    - channel-change time < 1 second
    - automatic service scan
    - directly bouquet-lists
    - EPG (electronic program guide)
    - Videotext Decoder
    - multiple LNB-Switching control (DiSEqC)
    - OSD in many languages and skin-support
    - extern12V power supply
    DreamBox DM500 + technical data
    DBS-Tuner:
    Frequency Range 950 …. 2150 MHz
    Signal Level - 65 dBm …. - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    dm500+ are flash mai mare
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical (AC3)
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB, S-Video
    Serielle Interface RS 232:
    Typ RS232 bidirectional
    Bitrate 115,2 kBit/s max.
    Plug Connector SUB-D-9
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    LNB Power and polarisation:
    LNB Current 500mA max. ; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    LNB shut-off at Standby-Mode
    Count of active satellite position:
    DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
    DiSEqC - Rotor Control
    Power consumption:
    < 10W / 12V
    Input voltage:
    DC12V +/- 15%
    Extern power supply:
    Input: 110-240V AC / 50-60Hz / 0,6A
    Output: 12V = / 1A or 2A
    Physical specification:
    Ambient Temperature +15°C...+35°C
    Humidity < 80%
    Size (W x D x H): 195 mm x 130 mm x 40 mm
    Weight: 0,6 kg
    clona 500s
    250 MHz PowerPC Processor (350 Mips)
    - Sistem Operativ Linux
    - 1 x Smartcard
    - MPEG2
    - Interfata V.24/RS232
    - 10/100Mbit compatibil Ethernet
    - 2 LED
    - 32 MByte Flash, 96 MByte Ram totali
    - Capacitate infinita de memorizare a canali Tv si Radio
    - Schimbare de canale rapida < 1 secunda
    - Servici de cautare canale automatic complet
    - Suporta denumirea directa bouquet
    - Suporta EPG (electronic program guide)
    - Suporta subtitrari (videotext)
    - Suports LNB multipli (DiSEqC)
    - OSD in Multilanguage
    - S/PDIF out (AC-3)
    - 1 iesire Scart
    - 1 iesire pentru modem analog
    DVB-S-Tuner:
    - Frequency Range 950 …. 2150 MHz
    - Signal Level - 65 dBm …. - 25 dBm
    - Signal-to-Noise Level 12 dB max.
    - DBS-Tuner Input Connector F-Type female
    - Input Impedance 75 Ohm
    - AFC +/- 3 MHz
    - Demodulation Shaped QPSK
    - FEC Viterbi and Reed-Solomon
    - Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
    - Roll-off Factor 35 %
    - Demultiplexing according ISO 13818-1
    Video decoder:
    - Video Compresie MPEG-2 and MPEG-1 compatibil
    - Video Standard PAL G/ 25 Hz
    - Format Video 4:3 / 16:9
    - Format 16:9, automatico
    - Letterbox 4:3 TV-Device
    Audio decoder:
    - MPEG-1 & MPEG-2 Layer I and II
    - Audio Mode Dual (main/sub), Stereo
    - Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Audio Analogico:
    - Output Level L/R 0,5 Vss on 600 Ohm
    - THD > 60 dB (1 kHz)
    - Crosstalk < -65 dB
    Audio digitale:
    - Output Level 0,5 Vss on 75 Ohm
    - Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    - S/PDIF Uscita ottica (AC3)
    Parametri Video:
    - Mufe video composite 1 Vpp +/- 0.3 dB on 75 Ohm
    - Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    - Iesire: Video composite, RGB e S-Video
    Seriale RS 232:
    - Typ RS232 bi-directionale
    - Bitrate 115,2 kBit/s max.
    - Connettore Pin SUB-D-9
    - Functiuni: Update Firmware
    Ethernet:
    - 10/100 MBit
    - Functiun: Update pentru flash
    gobi2000 vrei sa te uiti mai atent si sa intelegi bine , daca nu iar e bine
    ce ai scris tu e acelas receiver , uite niste poze daca nu te-ai convins din caracteristicii :
    - DM500 S : http://telsat.tv/images/Products/Dreambox%20DM500-S.jpg
    - DM500 + : http://antennacenter.eu/images/dream..._500t_plus.JPG
    uita-te bine la ele sa vezi diferentele si vezi ca scrie clar pe pnoul din fata ce model este unul si care este celalalt , vezi apoi imaginile cu panoul din spate cu conectica si vezi ca DM500 + are 1 mufa in plus deasupra mufei de retea care la DM500 S nu exista (ala este modemul) si in plus DM500 S are mai PUTINA MEMORIE FLASH (nu 32Mbyte car are DM500 +)
    de aceea si imaginiile pt. DM500 S sant de maxim 5-6mb in comparatie cu 10mb sau mai mult la DM500 +
    STUDIAZA INTAI SI APOI FA "AFIRMATII"
