Results 1 to 7 of 7
Thread: Pingtech Dvb 500
    27 Apr 2007
    Default Pingtech Dvb 500
    Ia cum apare o noua Clona de Dreambox 500s
    Dupa Unibox,Inetbox,Optibox acuma si Pingtech
    250 MHz PowerPC Processor (350 Mips)
    - Sistem Operativ Linux
    - 1 x Smartcard
    - MPEG2
    - Interfata V.24/RS232
    - 10/100Mbit compatibil Ethernet
    - 2 LED
    - 32 MByte Flash, 96 MByte Ram totali
    - Capacitate infinita de memorizare a canali Tv si Radio
    - Schimbare de canale rapida < 1 secunda
    - Servici de cautare canale automatic complet
    - Suporta denumirea directa bouquet
    - Suporta EPG (electronic program guide)
    - Suporta subtitrari (videotext)
    - Suports LNB multipli (DiSEqC)
    - OSD in Multilanguage
    - S/PDIF out (AC-3)
    - 1 iesire Scart
    - 1 iesire pentru modem analog
    DVB-S-Tuner:
    - Frequency Range 950 …. 2150 MHz
    - Signal Level - 65 dBm …. - 25 dBm
    - Signal-to-Noise Level 12 dB max.
    - DBS-Tuner Input Connector F-Type female
    - Input Impedance 75 Ohm
    - AFC +/- 3 MHz
    - Demodulation Shaped QPSK
    - FEC Viterbi and Reed-Solomon
    - Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
    - Roll-off Factor 35 %
    - Demultiplexing according ISO 13818-1
    Video decoder:
    - Video Compresie MPEG-2 and MPEG-1 compatibil
    - Video Standard PAL G/ 25 Hz
    - Format Video 4:3 / 16:9
    - Format 16:9, automatico
    - Letterbox 4:3 TV-Device
    Audio decoder:
    - MPEG-1 & MPEG-2 Layer I and II
    - Audio Mode Dual (main/sub), Stereo
    - Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Audio Analogico:
    - Output Level L/R 0,5 Vss on 600 Ohm
    - THD > 60 dB (1 kHz)
    - Crosstalk < -65 dB
    Audio digitale:
    - Output Level 0,5 Vss on 75 Ohm
    - Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    - S/PDIF Uscita ottica (AC3)
    Parametri Video:
    - Mufe video composite 1 Vpp +/- 0.3 dB on 75 Ohm
    - Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    - Iesire: Video composite, RGB e S-Video
    Seriale RS 232:
    - Typ RS232 bi-directionale
    - Bitrate 115,2 kBit/s max.
    - Connettore Pin SUB-D-9
    - Functiuni: Update Firmware
    Ethernet:
    - 10/100 MBit
    - Functiun: Update pentru flash
    asa arata inetbox
    Default Re: Pingtech Dvb 500
    salut nu cumva este mai degraba o "clona" a lui DM 500+ , fiindca dupa memoria flash/total nu prea este DM 500S :
    - DM 500+ : http://www.dream-multimedia-tv.de/en..._technical.php
    - DM 500S : din cate stiu eu are numai vreo 16mbyte flash si 48/64mbyte in total
    de aceea si imaginile intre cele 2 dm 500 difera in capacitate , cele pt. dm 500s in general in jur de 5mbyte si pt. dm 500+ depasesc si 10mbyte (din cate stiu eu)
    26 Oct 2007
    ce pret are?
    27 Apr 2007
    Pretul e de79 de euro dar dupa cum spun astia aici zice ca merge orice imagine de dreambox 500s si nu de 500+
    16 Jan 2009
    dami ceva indicati te rog
    nu vreau sa tin receptoru pe dulap
    27 Apr 2007
    adica ai receptorul asta si nu sti ce sa faci?
    dute la sectiune dreambox 500s si ai sa vezi ce se poate face.
    20 Jan 2009
    do you want a pingtech box ?
    send me private message.
