Se pregateste ceva:
Se pregateste ceva:
Este clar ca suntem in linistea dinaintea furtunii.
Sunt curios ce versiune de enigma si mai ales daca apare o versiune noua de mbox sau poate un nou emu.
Sa vina furtuna cit mai mare ... :)))
f11
O nou versiune de mbox va aparea curand. Mower s-a intors si lucreaza la asta acum
Team DuckTales proudly presents the first enigma2 BETA image for Kathrein UFS-910.Code:..,,,uuuuuuux-
.XJ$$$$$$$$$$$$$R"
:<???????$$$P???" ... uuuux ,ucdL
'''''` :<$$$: .dWWW>:;$$::$$F":J$$"''
,uuuouuu, .uu xcd:x$u.:J$$$ :J$P9$>;$$F.<$$h=`?$h
:$$$$$$$$$$b, .uz ucd xJ$$$:J$6d$$F':$$$F:J$P;3$>J$P.:3$,,,;J$$E
:d$$$$$$$$$$$$c::$$F;$$FJ$$P":<$$$$P` :J$$$:J$P???$>$$??:????`???"
::?"'<Xio::??$$$>J$$ :t$P;$P` :3$$P$$u::$$$P:??' `?F'
'' :d$$P `:9$$>$$F;J$><$C,,u;$$P:?$$h:3$$>
:<$$$' <8$$>$$X<J$$:<$$$$F:??' `"":J$$$
:3$$P :d$$$:$$$$$P `:???' :<P???"
::$$$' .d$$$$'`????" '::::
.:d$$6ud$$$$F
.;cJJ$$$$$$$PF'
::9$$$$$$$PF"
,z$$$$$ :::::::::::::::::.
e$$$$$$$$ ::::::::::::::::::::
d$$$$$$$$$$;`::::::::::::::::::::
::::::::."$$$$$b ::''''''''':::::::'
`:::::::::`$$P" . :''''<<<<<<;. `'
,-'.:::::::::::' dMMMMMMx :::::` .`::::::::
,'.::::::::::::: dMMMMMMMMMM ``` JMMM `:::::
,'.:::::::::::' . MMP',ccc "MMM Mb MMMMM `:::
; :::::::::::' nM MM',$$$$$$b "Mb4M,M c,`? :'
; ::::::::::: xMMMMM'J$$$$$$$$b )MMMMM.`$$.
' :::`::::::: dMMMMM'J$$$$$$$$$$F MMMMMM $$$.
:: <`::::: JMMMMM',$$$$$$$$$$$P MMMMMM $$$$
`:::`bc,.. ,edMMMM $$$$$$$$$$$$F MMMMMM $$$$ .
` ,nMMMMMMMMTMMMM P""?$$$$$$$$".MTT4MM ?$$F;P""?x_
,d)MMMMMMP'dMMMMM $$$$$$P .cCc. $ cCc L~
,MMMMMMM ,c, 4MMr $$$$$ .CCCC> 4 CCC> L"
P)MMMMM> $$?$ "MM $$$$" CCCCC' ,, CC> % `
' MMMTMMM `b $$c.?b $$$" `CCC'-""___,,,,,__
M" `?, ??$c,,,,,,cc$7= _,cc$$$$PP"""""??$$$$
" `"b,_ "?$$$$$$$$$$P"" .. ,d"
`?$b `,,,,,,.`;;;;;;'j"
n ?$c`;;;;;;;`',;;; F
,;-;MM "$b;;;;;,,;;;'j"
,!!!!! MMMM,`?$c,_`` _,,cd'
!!!!!!!; MMMMMMn, `"""""''
. !!!!!!!!!, `"TT';!!!!>
If you are a developer, and you have experience in (embedded)hardware/linux-dvb-api
coding feel free to contact us - you're welcome!
To test this enigma2 image you need a running nfs server and a network
connection to the receiver.
The aim of the BETA version was to create an e2 image with as less changes in the e2 source as possible.
We have moved most work into the driver and therefore we can now provide you the modified e2 source code.
In the last weeks we made many modifications which reduces the green screen, make picture and sound more
stable, add the cam module handling to e2 and add many proc entries like they are on dm machines. Of course
there are many things to do and of course some things are not done because of the amount of work and
of missing hardware. But we think that we can say that the current release has the BETA status.
Other improvements:
- changing resolution works no without changing current channel
- streaming BoX -> PC (VLC) works
- AC3 Output works, HDMI and optical
- Startup wizard works
- better RC support
For the future the following tasks are planned:
- improve stability of system
- add support for other cam modules (like alphacrypt, we wait for the delivery of a testmodule )
- timeshift
- handling of loosing signal of tuner
- fixing vfd
- scart and hdmi output at one time
- MKV support
The main change is the proc tree, which is for big parts the same as on dm's.
Not all Nodes are implemented, to get the options for each node, just make a
cat 'NODE'
e.g.
echo "hdmi_yuv" > /proc/stb/avs/0/colorformat
switches the colorsystem on hdmi to YUV
Deci au facut publice sursele de la TDT 600 prima versiune BETA de e2 pe KATHY.
Asteptam prima versiune compilata. Se pare ca aparatele cu procesor SH40 vor avea suport de exceptie, nu de alta dar erau multi care le cantau prohodul.
Cel mai mult ma bucura ca au rezolvat in sfarsit cu sonorul!!!
Se pare ca se schimba numerotarea versiunilor.
Nu am postat fisierele ca nu aveti ce face cu ele. Se gasesc pe net, dar sunt pentru dezvoltatori de software.
Ai dat o stire grozava.
Sti cumva pe cand se pregateste versiunea ? Se va face oare si pentru flash varianta ?
Vad ca au in vedere si play de mkv. Chestie asteptata de multi.
Rezolvarea in cazul pierderii de semnal e iar o problema importanta de rezolvat , intrucat acolo se cam blocheaza kathy des.
Cred ca totusi de sarbatori vor da drumul la aceasta versiune, nu ? ca e timp mai mult de butonat.
:clap:
A aparut si imaginea:
TDTs first Beta Image XMAS release rev600
si cine vrea pe source code il gaseste aici
Merge imaginea.
-are sonor facut marfa, face zapping mult mai bine ca 474
-pleaca afisajul la pornire
-se misca natural
-nu pare sa aiba emu instalat si nici modificari, asa ca punem de la polonezi azi si de luni o sa avem imaginea noastra
Caut server pe care sa punem addonul pentru prima imagine romaneasca de e2 Kathy.
Astept idei.
sa inteleg acuma ca kathrein e dacia cu motor FERARI??????
* asta e pt vecinii care se ocupa cu masinii scumpe de gen BMW,AUDI,MERCANUL...
Din primele experiente, pe fuga ce e drept, constat ca pe receiver-ul meu de 14W telecomanda nu functioneaza. Acelasi neajuns l-am intilnit si la imaginea PKT, cel mai probabil sursa e comuna.
Stie cineva care ar fi cauza si ce ar trebui modificat, dar mai ales cum, pentru ca sa trec peste acest mare inconveninent?
Desigur ca cei de la AAF sper sa ne dea in cel mai scurt timp o imagine modificata de ei si care au functionat fara probleme majore si pe receiver-ul meu.
Felicitari @zildan pentru initiativa de a infiinta un server pentru noi. Nu am idei, dar voi urmari si sper sa pot participa la momentul la care va fi demarata actiunea.
Nici dupa Power OFF/ON nu merge telecomanda? la a 2-a pornire?
Se lucreaza la imaginea e2 XMAS RSP :). Pana diseara apare!!
Caut voluntari!!!!
Pe site-ul aaf am vazut ca sunt de download-at si:
TdT_sh4_enigma2_src_1.00_rev600.zip
modules_1.00_rev600.tar.gz si
eplayer_1.00_rev600.tar.gz
Am instalat cu KCC si nu porneste:agresiv:
Se instalaza altfel decat versiunile precedente??
Felicitari
Astept cu mare interes versiuna RSP ca pe asta nu am reusit sa instalez Camd3
Nu.
Celelalte sunt bucati cuprinse deja in aceasta imagine, pe viitor pot sa apara doar acele parti.
Verifica 2-nd boot.
adevarul ca si la mine foarte greu am reusit sa o instalez , mai mult din cauza partitionarilor nereusite si cand am instalato prima oara am avut si "ecrane verzi" care in prezent la a 2-ua inst. numai sant , cu toate ca numai este prb. stick-ului
Imediat dupa ce am instalat rapid imaginea cea noua, nu a vrut sa reactioneze nici chiar dupa Power OFF/ON. Acum insa am reluat, si dupa ce de 3 ori nu a vrut sa treaca de LOADING MODULES, a luat-o totusi din loc, iar acum vad ca reactioneaza si la telecomanda. Mi-am mai luat cit de cit o piatra de pe inima.Quote:
Nu stiu daca sunt in stare, dar de oferit ma ofer ca voluntar. Sunt sigur ca e si o oportunitate sa invat cite ceva.
Cine se ofera betatester? In max 45 minute primeste imaginea de test.
enigma 2 e naspa trebuia facuta o imagine bazata pe e1 ca e mult mai stabila
Am instalat-o si eu pe USB stick cu procedura normala de instalare imagine in partitie. Merge bine, nu am inteles de ce au scris ca e nevoie de "NFS server".
Am verificat si streaming "Box -> PC(VLC)" - merge, atat SD cat si HD.
Da stream-ul nativ (mpeg2 sau h264) - nici n-ar avea cum sa incerce o transcodare cu procesoru' firav pe care-l are.
Mai sunt probleme de instabilitate dar, in general, merge bine.
mbox instalat manual - functioneaza bine.
E cool sa te poti uita la TV pe laptop in pat :)
