QboxHD DVB Busters emu panel_update20090725Radar111
Fixed problem local network
Changes:
[+] Lang EN|ES|FR|DE|AL|NO|IT
1. FTP: Send file to /cccam
2. TELNET: chmod 755 /cccam
3. TELNET: /cccam
4. Edit /EMU/lib/CCcam.cfg
4.1 Add CLine and write file
5. Reboot AZBox HD
New DVB Busters for QboxHd release 22/07/2009
Updated radar cam with Multi C lines support
Minor bug Fixed
One cam for all; in the emu panel activating RADAR CAM now you can read subscription card and in the same time you have also CCcam available.
Read the read me for configuration(you have to edit for CCcam the file RADAR.cfg with the line C)
DVB BuStErS MMM 04 july 2009 UMMZ PrOudLY PrEsEnTs MMB QBoxHD Emu Plug-In =The Independence Day=
-^- RaDaR CaM 1.0 -^
MBox + NewCS
UnderWorld
What's RaDaR CAM?!?!
RaDaR CAM now includes CCCam Client
and NewCS for card reading coming next
all the other sharing protocols like
gbox, newcamd and radegast
Usage: Uncompress RAR File
Copy qbox_update folder in root of USB Stick
Insert USB Stick in QBoxHD ;
Turn OFF and Turn ON QBoxHD
Wait for install and enjoy
Blue Button to access the EMU Panel ;
files can be located in
var/etc/ or var/keys/ or var/bin/
radar.cfg is the new file you have to edit
C: string is for CCCam and N: string is for NewCS.
Salutare
Am incercat astazi dar fara prea mare success. Am pus trei carduri in newcs digi N2, max viaccess si TVR , am reusit sa fac lumina doar pe digi fara probleme pe tvr si pe max pleaca imaginea doar cateva secunde dupa care procesul mbox se prabuseste ( asta cu port.list gol, daca pun sid-urile tvr si max nu mai pleaca deloc imaginea si la fel se prabuseste mbox-ul ). In share nu am testat ca nu am linie de Mbox
Am mai reusit sa obtin imagine pe eurosportul de la 13 est deschis de pe cardul de Max dar la fel dupa un zapping scurt mbox-ul se prabuseste. In acelasi timp de canalele digi mbox-ul nu se mai inchide merge ok, deschide relativ repede.
Vreo idee unde gresesc?
QboxHd_Ultra_Image_By_TarantiniX_21-9-09
- diablo cam inside works
- picon works
- settings: Vhannibal 13°-19° 21/9/09
Skins with picons:
- skin default
- Kerni HD1 Blue
- Nemesis Glass Line
- Merlin Racer
- Merlin Magic
- X2Line
- Nemesis GlassLine Red
Plugins:
- DVB Busters Softcam Panel
- Sat Angels QboxHD Key Updater
- Simple RSS
- You Tube Player
- You Porn Player
- VLC Video Player
- Picture Player
- Webinterface
- Media Scanner
- Default Services Scaner
- Aspect Ratio Switch
- AC3 Lip Sync
- CrossEpg
- Kiddy Timer (passw. 1111)
- RS Downloader
- ORFat
- ZDF Mediathek
- Kicker Sportinfos
- Verkehrsinfo
- FritzCall
- Dream Buddy
- Elektro
- Permament Clock
- Password Changer
- Sudoku
DOWNLOAD 39 MB
Youtbe 1.0.1 for QboxHD
Saludos
<A href="http://www.sendspace.com/file/xx3ldc" target=_blank>[Only registered and activated users can see links. Click Here To Register...]
My Tube for QboxHD
<A href="http://www.sendspace.com/file/t7rlrb" target=_blank>[Only registered and activated users can see links. Click Here To Register...]
New Radar cam vers 2.1 BETA2
<A href="http://www.sendspace.com/file/ek2cxi" target=_blank>[Only registered and activated users can see links. Click Here To Register...]
Qboxhd-napo-bkp-fire-edition-12112009 New FIRE Distribution Filesystem available 10/11/2009 * important to use bootloder 25.9.2009 with qboxhd 1.04 * * this backup complete of nor 10.11.2009 * -------------------------------------------------------------------- QBOXHD-NAPO-BKP-FIRE-EDITION-11112009 Settings : Vhannibal Dual 13E-19E 01.11.2009 Skins mod. by Webkurier: HD Glass Infinity_hd Infinity_hd2 Hd_glass Allien-HD Skin_essential72 SWAIN-HD Plugins: Weather Plugin thanks luca1997 You Tube fix You Porn fix Cost botton fix Softcam Napo Hddstandby Qboxhd RadarInfo Sportinfos emu: Incubus094 QBOXHD and other. AddOns serch on menu Napo
<A href="http://www.easy-share.com/1908418460/Qboxhd-napo-bkp-fire-edition-12112009.rar" target=_blank>[Only registered and activated users can see links. Click Here To Register...]
Image by Luca1997 10/11
Working with bootloader from 25/09/2009
NEW Fire Distribution Filesystem for QBOX HD 10/11/2009
-HDD are now mounted at boot time if they're connected
Enigma2:
- Fixed bug: Passwd for login is again "qboxhd" (reported in the forum)
- Fixed bug: Teletext was not working (reported in the forum)
- Fixed bug: CI was not correctly initialized after a soft-reset
- Improvement: Add-ons mechanism works much better and it's better organized
Fixed:
Bootvideo by DVB Busters
Skins:
Skin dTV-HD for QboxHD mod. by Webkurier
HD Glass for QboxHD mod. by Webkurier
Infinity HD for QboxHD mod. by Webkurier
Allien-HD for QboxHD mod. by Webkurier QboxHD Skin
dmmHD mod by Webkurier
Skin essential72 for QboxHD mod. by Webkurier
Full package picons / piconlcd
Plugins:
Weather Plugin for QboxHD by Webkurier
My Tube for QboxHD by Webkurier
RaDar Cfg Version: 2.1 BETA1
Astra 19,2 /Astra 23,5 and Hotbird 13
HDDstandby Plugin for QboxHD
Al Jazira fixed. *Biss fixed. *CCCam protocol fixed
