Dislikes: 0
cred ca e cel mai tare receptor hd de pana acum
"the Box is based on Sti processor 7101(latest version), and use like operating system Linux with Enigma 2 interface. Qbox is an High definition Set Top Box DVBS2 Capable Resolution: (1080I, 720P, 480P/576P, 480I/576I)."
- 266 MHz ST40 CPU SH4 Core. STi 7101 based.
- Linux Operating System
- Linux DVB-API compatible.
- 2,2” TFT high definition Display
- WiFi - 802.11n. Stand-Alone internal Module
3 Antennas. WEP/WPA/WPA2 supported.
- 2 x Common Interface Slots
- Ethernet 10/100 MBit compatible interface
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S2, DVB-C, DVB-T
- 3 x Tuner Module Input - Plug&Play
- 2 x Smartcard-Reader ISO 7816-3 with programmable clock speed
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 2 x Scart (RGB, FBAS or S-Video)
- HDMI Output
- 2 x USB 2.0 external USB
- 1 x USB 2.0 internal for FileSystem
- S/PDIF Interface for digital bit stream out (AC-3)
- 8 MByte NOR for Secure Bootloader, 128 MByte RAM
- Internal SATA for PVR
Use either as internal SATA HDD 2,5“
- unlimited channel lists for TV/Radio
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
DVB-S2 Tuner:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Serial Interface RS 232:
RS232 bidirectional
BitRate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
SATA Interface:
For use either as internal HDD 2,5“
USB
2 x USB 2.0 Host
1 x USB 2.0 Host Internal Slot for USB stick to hold the Firmware.
Count of active satellite positioniSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power Supply:
Input:
110-240V AC / 50-60Hz / 0,6A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H):370 mm x 230 mm x 60 mm
Weight: 2,5 kg ca without HDD
mai multe detalii aici
http://www.sat-universe.com/showthread.php?p=279735
http://www.brasolino.info/showthread.php?p=411459
qbox, ipbox, kathy, vor fi receptoare care vor face acelasi lucru cu dreambox la bani mai putini
e cel mai complect receptor pe are l-am vazut pana acum. nu face compromisuri (DVI la dm)
plusuri:
- HDMI Output
-Internal memory stick USB preinstalled(1 Gb)
-Diablo embedded
-2 sata
-pretul
ar fi prea frumos sa coste numai 450€
Totusi nu cred ca o sa costa mai mult decit 900Euro cum o sa costa dm8000.E bine sa exista alternative ca sa scade si preturi prin concurenta.Eu v-am spus ca un receptor HD nu merita mai mult de 550 euro.Dm se exagereze ca sa face profit mare.Pretul lui dm100 e foarte buna pt ca vrea sa loveste sub centura pe clone.Asa unde il convine vinde la preturi bune....
Tare de tot,dar sa vedem... infaptuirea,apoi implinirea of our dreams.![]()
FOCUS SAT-UPC;RCS-digital cablu;ADSL;BAYERN MUNCHEN&AC MILAN;
.de
am trimis mail la duolabs, cand imi raspund revin cu noutati .
asa este dar suportul cccam pe care se pare ca il are si un soft nonlinux il face atractiv pentru cei ce nu vor sa-si bata capul cu un receptor cu soft plin de floricele . acum sincer cati stau sa priveasca la tv o emisiune si cati stau sa verifice cate scripturi merg , cate plugins merg , ce skinuri bengoase au mai aparut ... etc . un receptor beton este acela care are suport emu cat mai bun si sa fie cat mai fiabil ... restul e cancan![]()
cineva de pe celalalt forum a "afirmat" din surse sigure (din interior) ca va fii intre 449-499euro , inca se discuta ce si cum.
da si asa fata de dm8000 care deja a aparut un pret informativ comercial aici : http://www.satmedia-engineering.eu/o...roducts_id=103 , basca ca din start de la 4 tunere cu cat se lauda ca duce a ramas la 2 sloturi , deci ceva de genul cum este ip-box-ul la noi la vanzare cu 1 tuner montat si 1 optional dupa aceea.
sa numai zic si de prb. care inca persista la tunerele lui dm800 , sper sa nu aiba aceeasi soarta si dm8000.
nu am sa platesc nici macar 10euro unui producator care nu-si permite sa plateasca licenta ptr HDMI care costa infirm dar cere 1000€ pe unitate! am un dvd italian pe care am dat 60€ si are HDMI! se intampla aceleasi chestii ca in anii 90, toti cumparau dacia la preturi enorme deoarece masinile din import nu rezistau pe drumurile din tara...
- WiFi - 802.11n.
ce standard e asta? merge direct la un router wifi, nu?
suna bine!!!!!!!!!!!!
AMAZING RELEASE FOR Q-BOX!!! GERMANY NEVER IN THE DARK!
Premiere Packages and Bundesliga!
«NeW» Kabelkiosk - Eurobird 9 (9.0E) -
«NeW» Kabelkiosk - Atlantic Bird 2/Telecom 2D (8°W) -
XclusiVe E M Us
Conax: Canaal Digital Nordic - Thor 3/5 (0.8°W)
Conax: DigitAlb - Eutelsat W2 (16.0E)
Conax: Kabelkiosk - Atlantic Bird 2/Telecom 2D (8°W) -
Die software findet ihr wie immer im np-ulc! http://np-ulc.net![]()
dar si mai bomba e pretul. am vazut undeva 470€ cu tot cu tva, sa vedem cat de adevarat va fi.
