OpenPLi 4.0 IPTV by MastaG with GStreamer 1.9.0.1 VU+ Zero Image
15/ 04/2016
Changes:
- New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
- Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
- gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
Login with telnet and issue: opkg update && opkg install ffmpeg
- Latest openpli-oe-core changes
- Latest enigma2 changes
- spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
Note: servicemp3 still uses gstreamer
- spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
The servicemp3 memleak patch has been applied with some other patches/commits I found useful
- spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
- Fixed e-star dm800 image now using correct drivers and working great
- Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
OpenPli 4.0 Beta VU+ Zero Image
Satdreamgr-4.0-gst1 VU+ Zero Image
Black Hole 3.0.2.C Vu+ Zero Image
Black Hole 3.0.2.C
What is new ?
-Support customized subtitles.
- font color, size, opacity, edge style,
- background color, opacity,
- subtitle position, align, etc.
- add quick menu for subtitle
-Add OpenMultiboot to Solo4K
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
LICENSE (TERM OF USE)
Download
OpenDroid 5.5 VU+ Zero Image
Open Source 3.0 VU+ Zero Image
SatDreamGR 4.0-gst1 VU+ Zero Image
OpenSPA 6.0 VU+ Zero Image
User : root
Pass : openspa
What is new :
- New OE-Alliance 3.4
- Changes in EPG download, now is Movistar+ instead of D+
- Fix weather info
- Improvements at confluence 1080. Added new screens and plugins.
- Improvements at spaqbutton (Remap keys) to add more remote buttons (fav, portal, etc)
- Kodi 16.1 (Wetekplay/VuDuo2/VuSolo2/VuSoloSE/VuSolo4k)
- GStreamer 1.8.1 Stable
- VuDuo2/VuSolo2/VuSoloSE/VuSolo4k/VuZero/GigaBlue support iptables
- Fixed error in DeviceManager when initialize device in ext3/ext4
PKT SVN-3400 HYPERION v5.3.1 VU+ Zero Image
- [MIPS] new gstreamer 1.9.0
- [HC] new gstreamer 1.8.0
- new packages
- a lot of fixes and updates
- [sh4] & [HC] new second infobar XL mode
FTP login: root
passwd: pkteam
[BKP]OpenSPA 6.0 Vu+Zero by Robijay
Backup date 08/05/2016
Kernel 3.13.5
Avermedia A867 Driver OK
Splash Screen OpenSPA by robijay
Bootlogo by robijay
Setting Vhannibal Quadri Feed 13+19,2+23,5+28,2
Language: ENGLISH
Password FTP and Telnet: robijay
Whats Included ?
OPENSPA 6.0
Panel
LINUXSAT SUPPORT PANEL HD 1.2
SATVENUS PANEL HD 4.2
Plugins
MEDIAPLAYER 2
MEDIAINFO 3.0
LIVE SOCCER PLUGIN HD 1.2
SDG VU+ IMAGE DOWNLOADER
HMSTREAM PLUGIN
MEDIAPORTAL 7.4.7
MULTIBOOT
PANDASAT FREE IPTV PLUGIN
YOUTUBE PLUGIN
AUTOBOUQUETS 28,2 (FOR UK USER NEW VERSION)
IPTV PLAYER 124.00.00.00 (LATEST)
TSMEDIA 11.1 (WITH LATEST UPDATE)
EPG IMPORT RYTEC
VHANNIBAL NGSETTING 1.4 (NEW VERSION)
AND MORE..........
Emu
OSCam 11233 (LATEST)
DOSCAM 0.25
OSCam INFO
Skin
CONFLUENCE
CONFLUENCE HD
MORE SKINS
DOWNLOAD:[Only registered and activated users can see links. Click Here To Register...]
OpenVIX 4.1 VU+ Zero Image
Power-Board 5.3 VU+ Zero Image
