Page 1 of 10 12345 ... LastLast
Results 1 to 15 of 149
Thread: Images Vu+ Zero
    Thumbs up Images Vu+ Zero
    openATV 4.2
    openatv-4.2-vuzero-20141121_usb.zip
    http://speedy.sh/7bpTk/openatv-4.2-v...141121-usb.zip
    Vu+ Zero Open Source Image
    vuplus-image-vuzero-20141124021700_usb.zip
    http://speedy.sh/Nd2YB/vuplus-image-...021700-usb.zip
    New VTi "Vu+ Team Image" - v. 8.0.x - 2014.11.28
    From VTi Team
    VTi Panel (Blue Button)
    Supported languages:
    English, German, Dutch, Italian, Turkish, Danish, Polish,
    Russian, Ukrainian, Czech, Arabic, French, Swedish,
    Portuguese (Portugal), Greek, Bulgarian, Hungarian
    With modular, flexible VTi Skin: Atile HD
    VTi Bootlogos and Radiomode Logo.
    Short press on blue button opens VTi Panel, long press opens Pluginmenu
    Support for FTDI chipset cardreader like smargo and easymouse2
    Running Softcam shown in the Infobar
    MovieList with extended functions
    Support for full image backup and restore
    Supports VTi image flash online
    Restore Plugins, Bouquets, Settings, etc. during installation
    Remove preinstalled packages during installation (VTi Zero)
    CHANGELOG
    - Treiber: 26.11.2014 (Solo SE, Zero)
    - Treiber: 29.10.2014 (Duo²)
    - Treiber: 21.10.2014 (Duo, Solo, Uno, Ultimo, Solo²)
    - Kernel 3.13.5 (Solo², Duo², Solo SE, Zero)
    - Kernel 3.9.6 (Duo, Solo, Uno, Ultimo)
    - IPtables Unterstutzung hinzugefugt
    - Enigma2 (2014-11-21)
    - AtileHD skin
    - Plugin GraphMultiEPG aktualisiert und Funktionsumfang erweitert
    - HbbTV aus Image entfernt (Uno, Duo)
    Basiert auf Vu+ OpenEmbedded Repository 2.1
    --> Änderungen von Vu+ : hxxp://code.vuplus.com
    CHANGELOG
    - driver: 26.11.2014 (Solo SE, Zero)
    - driver: 29.10.2014 (Duo²)
    - driver: 21.10.2014 (Duo, Solo, Uno, Ultimo, Solo²)
    - kernel 3.13.5 (Solo², Duo², Solo SE, Zero)
    - kernel 3.9.6 (Duo, Solo, Uno, Ultimo)
    - support for IPtables readded
    - update plugin graphMultiEPG (add new functions)
    - remove HbbTV from image (Duo, Uno)
    Based on Vu+ OpenEmbedded Repository 2.1
    --> changes from Vu+ : hxxp://code.vuplus.com
    http://www.mediafire.com/download/u3..._8-0-0_usb.zip
    Black Hole 2.1.4 VU+Zero
    Black Hole 2.1.4 VU+ Zero
    What is new in Black Hole 2.1.4:
    All models: Full HD Skin ready.
    The 1920x1080 framebuffer support recently introduced in Vu+ drivers has made it possible to use full hd skins. But many parts of the enigma2 gui are hardcoded with fixed fonts and itemheight.
    This causes fonts at 1920x1080 resolution to appear far too small. All these gui parts have been re-coded in Bh 2.1.4 to support larger fonts and itemheight in case of full hd skins (thx to Matrix10)
    Solo and Duo only:
    The 1920x1080 framebuffer support has required extra Ram usage. For this reason the old Solo and Duo models do not have enough free ram to run the curent images with these new features.
    In Black Hole 2.1.4 we have included ram compression (zram) that increases performance by avoiding paging to disk and using a compressed block device in RAM instead, inside which the paging takes place until it is necessary to use the swap space on a hard drive or usb stick. Since using ZRAM is an alternative way to provide swapping on RAM, zram allows Linux to make more use of RAM when swapping/paging is required.
    misc:
    drivers: 20141126(solose, zero)
    - Fix booting problem(solose)
    - Support LED brightness control in idle mode(solose)
    - Support LED brightness control in normal/idle(zero)
    - (Brightness can be controlled in Menu -> Setup -> System -> Display Setup)
    New Skin MX-Black
    Meoboot update: Fixed the issue of non working usb drivers in images in multiboot.
    About screen: Add drivers version, kernel version and Cpu info.
    Bh Full Backup update.
    OpenWebInterface update.
    WirelessLanSetup: add quote to wpa_passphrase for password.
    Black Hole Swap panel: Allow to create swap files upto 2 GB.
    Black Hole Swap panel: Update descriptions (Thx to Ev0).
    Solo2: fix ethernet problem in some Gigabit switches.
    Solo/Duo: implement Zram
    Librtmp update.
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    http://www.4shared.com/zip/DeQVWJwUb...uzero_usb.html
    VU+ Zero Open Source 3.0 (Original Image)
    http://code.vuplus.com/download/boxi...113300_usb.zip
    VU+ Zero Open Source 3.0-----Update
    http://code.vuplus.com/download/boxi...024404_usb.zip
    OpenLD VU+ Zero-----OpenLD 2.3
    http://www.odisealinux.com/Firmwares...151023_usb.zip
    This version is the final and official version if you have installed an earlier downloaded from somewhere else, please do clean install, there are many differences.
    >> Blue Panel Blue button OpenLD
    Green button >> Plugins
    Green Button Green Button >> >> ADDONS
    Red button blue button >> >> Services
    Yellow Button >> Set Sound
    Red Button >> Electronic Program Guide
    VU+OpenDroid 5.2 --------opendroid-5.2 :new: vuzero
    http://images.opendroid.org/5.2/VU+/vuzero
    Thumbs up OpenViX 3.2 Release Image for Vu+ Zero
    http://www.openvix.co.uk/openvix-builds/Vu%2BZero/
    http://code.vuplus.com/download/boxi...170608_usb.zip
    Thumbs up VU+rudream-4-------VU+ Zero Image-----16.11.2015
    Thumbs up OpenATV 5.1 Vu+ Zero Image
    Thumbs up OpenPLi-4.0-beta Vu+ Zero Image
    Thumbs up SatDreamGr 4.0 Vu+ Zero Image
    http://sgcpm.com/satdreamgr-images/vu/vuzero/
