VU+OpenHDF-5.3 Vu+ Zero Image
---------- Post added at 10:51 ---------- Previous post was at 09:57 ----------
VU+OpenDroid 5.2 --------Vu+ Zero Image
VU+rudream-5-------VU+ Zero Image-----17.01.2016
Open Source VU+ Zero Image 3.0 Update 20/01/2016
VU+VTi 9.0.2 Vu+ Zero Image
19.01.2016 - Urgent Information
Please check tuner configuration when tuners are in loop through mode.
It is not allowed to loop through a tuner multiple times
19.01.2016 - Software Update VTi 9.0.2
- increase image version: VTi 9.0.2
- update drivers (2016-01-19) (solo4k)
support Chromium OS
fix DiSEqC problem
improve power consumption
fix misc.
- add Chromium OS to image (including YouTube TV) (solo4k)
- update dvbapp2 (2016-01-17)
keep compatibility for extra headers in stream urls
MovieList: improve handling when leaving movie
MovieList: add option to hide entries
when start dir is set to all or new movies
Timeshift: add separate menu: Menu>VTi>Setup - Timeshift
Timeshift: map button STOP to live TV (timeshift recording is still in progress)
Timeshift: map button STOP LONG to stop timeshift
Timeshift: add function to transform timeshift to regular recording (Please note: short outage in TS file at transforming timestamp)
Common: add global option for dvbapp2 debug output
Menu>VTi>Setup - System
Common: support EPG and picons for 4097 services (e.g IP>TV)
Common: support recording of 4097 services (e.g IP>TV) -> THX @betacentauri
Common: fix handling of http timeout at streams
Common: fix button EXIT when infobar animation is enabled
EPG: add option to blacklist services for DVB EPG (EIT) updates
EPG: support for adding extra data to EPG events
- add plugin epgshare THX @einfall (ver. 0.01 20160117)
- add plugin tinyfoscamviewer (ver. 1.0)
- readd plugin mediatombplugin (ver. 1.0-r5)
- update plugin autoframerate
fix switching to 24p mode
- update plugin camofs (ver. 10.01)
- update plugin devicemanager2 (ver. 1.7)
fix partitioning for some devices
- update plugin graphicalmultiepg
support button mappings
support custom picon folder
- update plugin infobartunerstate (ver. 3.0.1 20160108)
- update plugin lcd4linux (ver. 4.7.-r2)
- update plugin multiquickbutton (ver. 2.7.14-r6)
- update plugin openwebif
switch to standby when transcoding starts (solo4k)
- update plugin picturecenterfs (ver. 7.03)
- update plugin seriesplugin (ver. 4.5.0 20151221)
- update plugin webradiofs (ver. 13.57)
- update skin atile (ver. 4.2-r0)
- update skin mutespectator (ver. 2.8)
- update skin stylefhd (ver. 2016-01-11)
- update opera hbbtv (2015-12-22) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
- update transtreamproxy</itemtext>
support infobartunerstate plugin
- update vtipanel (ver. 3.36)</itemtext>
add favourites list loader (see forum for howto)
Menu>Setup>Service Searching
- add package jpegtran-cffi
- remove xbmc from image (solo4k,duo2,solo2,solose)
Vu+ Eurosat 2.0 Vu+ Zero Image
Update
GST 1.7.1
We recommend the Flash Box
VU+ Openplus 1.1 Vu+ Zero Image
OPENPLUS 1.1 - Pública
Openplus es un firmware para decodificadores de TV (TDT/SAT/CABLE) basado en el software de código abierto Enigma2.
OPENPLUS está basada en código opensource de enigma2 de publicado por OpenAtv y otros autores.
Esta imagen no contiene claves, emuladores u otros sistemas que permitan el visionado sin una subscripción de pago
Openplus está constituida por un conjunto de software de múltiples autores con licencias variadas que se pueden consultar en cada paquete.
Todo el código generado por el equipo de Open-Plus, se ha licenciado bajo GPL.
Tal como se indica en la licencia este software se entrega sin ninguna garantía.
OPENPLUS 1.1 - Public
Openplus is a firmware from TV decoders (DTT/SAT/CABLE) based on open source software Enigma2.
OPENPLUS is based on open source code enigma2 published by OpenAtv and other authors.
This image does not contain keys, emulators or other systems that allow viewing without a active subscription.
Openplus consists of a set of software from multiple authors with various licenses are available on each package.
All code generated by the team of Open-Plus, is licensed under GPL.
As indicated in the license this software comes with no guarantee.
Bugs y cambios de 1.0 Final a la 1.1 Final
Funciones destacadas:
- Adaptacion Skin Openplus y Mymetrix.
- Implantacion del nuevo enigma2 Oe.
-Traducciones actualizadas en Espańol de enigma2
- Skinparts para skin OpenplusHd y Metrix-lb
-Iptv Movistar (podras visionar y crear lista de canales de movistar tv)
-Lista Movistar Iptv (para vlc y .m3u)
-Lista Astra e Hispasat openplus con equivalencias actualizadas (solo Movistar)
-Epg 7 dias de Movistar iptv y la posible visualizacion del Picon con Picons Astra
-Mayor informacion
-Traducción Gigablue VDF control y AutoboquetsMaker
CAPTURAS
LISTAS OPENPLUS
MOVISTAR IPTV
LISTAS MOVISTAR IPTV
encontrarás toda la imformación para ponerla en marcha...
OpenPlus wiki manuales
AGRADECIMIENTOS
Gracias a siteincloud.com por el alojamiento del foro y los feeds
Gracias a todos los otros desarrolladores y betatesters de openplus.
You will find all the information to implement it ...
OpenPlus wiki manuals
Acknowledgements
Thanks to siteincloud.com forum for housing and feeds
Thanks to all the developments and beta testers of openplus.
Puedes descargar la versión 1.1 pública de [Only registered and activated users can see links. Click Here To Register...]
Download public version 1.1 from [Only registered and activated users can see links. Click Here To Register...]
ViX4E2PROJECT Vu+ Zero Image
VU+PKT IMAGE HYPERION 5.1 Vu+ Zero Image
OpenATV 4,2 ---5,1 Vu+ Zero Image
20.01.2016 - Software Update
- update dvbapp2 (2016-01-20)
fix silly timer conflicts
add missing service info for 4097 streaming services
- update plugin devicemanager2 (ver. 1.8)
readd support for devices without single partitions
-update plugin hbbtv (YouTubeTV) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
keep compatibility for skins
- update plugin epgshare (ver. 0.1 20160120)
- update plugin infobartunerstate (ver. 3.0.3 20160120)
INFORMATION - 21.01.2016
Replace VTi 9.0.2 images in database : VTi 9.0.2 (2016-01-19) --> VTi 9.0.2 (2016-01-21)
21.01.2016 - Software Update
- update dvbapp2 (2016-01-21)
fix freezing mkv playback for some rare mkv types
fix black screen after framerate change
to activate plugin set:
Menu>Setup>System>A/V settings>Refresh rate: multi
22.01.2016 - Software Update
- update gstreamer1.0-libav (2016-01-22)
fix media playback with TrueHD audio tracks
23.01.2016 - Software Update
- update dvbapp2 (2016-01-23)
Timeshift: change default value for event change behaviour
Timeshift: take care for zap timer
- update plugin picturecenterfs (ver. 7.10)
24.01.2016 - Software Update
- update dvbapp2 (2016-01-24)
Timeshift: change default value for file remove intervall (default = 0)
fix dvbapp2 shutdown
25.01.2016 - Software Update
- update dvbapp2 (2016-01-25)
Timeshift: map function transform timeshift to REC button
Timeshift: remove duplicate menu entries
REC button: add transform timeshift to configuration choices
- update vtipanel (ver. 3.37)
fix image restore/flash tools
03.02.2016 - Software Update
- update dvbapp2 (2016-02-03)
Timers: fix repeating timers
Timeshift: enhance naming scheme for timeshift files
Timeshift: do not switch to live TV after event change
Timeshift: add option to to use < and > buttons for switching timeshift events
Timeshift: change default configuration for behaviour at event change
- update hbbtv (ver. 20151228) (solo4k)
- update skin mutespectator (ver. 2.9)
see TimeShift screen for new source TimeShiftService
05.02.2016 - Software Update
- update plugin camofs (ver. 11.0)
- update plugin fritzcall (2016-02-05)
- update plugin permanenttimeshift (2016-02-05)
keep compatibility to new dvbapp2 functions
- update plugin picturecenterfs (ver. 7.22)
06.02.2016 - Software Update
- update dvbapp2 (2016-02-06)
Common: fix releasing memory at loading epg data
- update plugin camofs (ver. 11.01)
07.02.2016 - Software Update
- update dvbapp2 (2016-02-07)
Timeshift: fix naming scheme of ts files
Timeshift: try to set correct file name for saved event
Timeshift: do not stop timeshift when channel selection will be closed without service change
- update gstreamer-plugin-dvbmediasink
fix sound dropouts at some media files
08.02.2016 - Software Update
miscellaneous bug fixes
fix AC3/DTS playback when PCM tracks are present
09.02.2016 - Software Update
- update dvbapp2 (2016-02-09)
[Timer] add option to avoid simultaneous timer starts
[Timeshift] add function to transform old timeshift events
[Timeshift] use begin time of event for ts file name
[Timeshift] add option to hide timeshift files in movie list
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
Hi folks,
It took me a while to build these because there were lots of small bugs and user requests.
I did my best to answer them all.
But due to my limited time I couldn't fulfill all of them, so my apologies if I didn't respond to a PM or forum-post.
So anyways.. there are lots of changes compared to my last images.
Too much for me to remember, so I guess:
- Added new receivers: Zgemma H5 and LC, Vu+ Solo 4K, XpeedC (whatever that is) and Atemio Nemesis (user-request, not tested at all so beware).
There are no Wetek builds and I ain't gonna build them, so don't ask.
- I've fixed the feed for mips32el-nf receivers (et4x00, hd1100, hd500c and xp1000).
- Oscam bumped to rev. 11211 with Joeuser's patch (yes I know you guys were waiting for this one).
- Lots of fixes for spark and spark7162 with the help of my great friend Taapat, they should be of equal quality as other PLi 4 images now.
The libeplayer versions are in the "eplayer" directory, everything else is gstreamer.
- No more patches to enigma2's servicemp3.cpp (except the one for aac transcoding), so it should reflect the current state now.
- Latest gstreamer 1.7.1 master head as of today.
- Many backports from master-next and Taapat.
- Lot's of small things I forgot.
Note:
- If you get corrupted jpeg images on spark/spark7162 the hardware decoder is not working for you, simply login using telnet and type:
rm -f /usr/lib/libmme_host.so
Then restart enigma2 and they should display fine
- Zram is now disabled by default on spark/spark7162, if would like to use it anyways, simply login using telnet and type:
touch /etc/gimme-zram
Then reboot your receiver.
If I didn't mess up badly this time, this will be my last round of public images.
I don't think there's any benefit for releasing gstreamer master head images anymore, since the next stable gstreamer release will hit master-next and oe-alliance anyways.
And most work went into supporting non-PLi-supported receivers which takes lots and lots of time.
Thank you all for the great feedback !
You're the best!
