OpenLD VU+ Zero-----OpenLD 2.4
VU+OpenHDF-5.3 Vu+ Zero Image
VU+OpenHDF-5.3
---------- Post added at 10:05 ---------- Previous post was at 09:48 ----------
OpenSPA-5.0.003 NEW UPDATE 04.12.2015
OpenATV 5.1 Vu+ Zero Image
VU+OpenDroid 5.2 --------Vu+ Zero Image
---------- Post added at 17:47 ---------- Previous post was at 16:44 ----------
SatDreamGr 4.0 Vu+ Zero Image
new experimental gst1
OpenViX 3.2 Release Image for Vu+ Zero
VU+ Uno : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
VU+ : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
Changes since previous release:
- mx3L's gstreamer revert which fixes mp4 playback from remote locations
- Spark drivers updated to 20151113
- Using aio-grab from oe-alliance which includes fixes for sprak receivers
- New Japhar IPTV List (thanks to ToySoft).
- DM8000 has no more gsod's now (thanks to ToySoft for testing!)
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
By mx3L which fixes mp4 playback from remote locations.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
- The 2.6.18 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any kernel driver from OE1.5 to 2.0.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
To find the download link, search for MastaG Japhar OpenPLi 4.0
Enjoy !
VU+rudream-4-------VU+ Zero Image-----16.12.2015
OpenATV 4.2 Vu+ Zero Image----------GST 0.10 Images
OpenATV 5.1 Vu+ Zero Image----------GST 1.5.1 Images
Vu+ Eurosat 2.0 Vu+ Zero Image
Open Source VU+ Zero Image 3.0 Update 23/12/2015
VU+ Zero HDMU Image
Powerboard-Image 5.1 Vu+ Zero Image
Neues Powerboard-Image 5.1 fur die VU+
Diesmal mochten wir euch sehr fruh mit unseren neuen Werken bekannt machen. Soll heissen, das aktuelle hier vorgestellte 5.1er Image ist ein Beta-Werk mit vielen Verbesserungen, aber eben halt ohne ausgiebigen Test.
Wir mochten euch das jedoch nicht vorenthalten, also viel Spass damit.
WICHTIG - neues Passwort: powerboard
URGENT - new pasword: powerboard
Wir haben das Image zwar umgebaut, aber an den bekannten Funktionalitäten nichts geändert.
Code:
- neues Enigma2 mit wesentlich mehr Funktionen
- aktueller Kernel und Treiberstand
- GStreamer 1.6.0
- Expert-Installer
- Auto-Systemupdate
- script-Starter
- Piconpfadanpassung
- logfile-viewer & remove (logs unter /home/root)
- Autorestarter fur Anwendungen
- LCD-skin-Selektor
-neuer oscam Standard-Pfad
uvm.
We havn`t completly rebuild the Image, but didn´t changed anything in the familiar functions.
Code:
- a brandnew Enigma2 with a bunch of more functions
- actuell Kernel and Driversrelease
- GStreamer 1.6.0
- Expert-Installer
- Auto-Systemupdate
- script-Starter
- adjustable Piconpath
- logfile-viewer & remove (logs under /home/root)
- Autorestarter
- LCD-skin-selektor
-new default path for oscam
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
Please reflash your receiver since a software update will most likely fail.
Especially on spark/spark7162.
- Gstreamer snapshot updated to 1.7.1:
* The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
* Libsoup has been updated so I've dropped the revert for the old libsoup as well.
- DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
- More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
* This should give us a few more MBs to work with (Dreambox *cough*).
- Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
* Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
* Enable of the zram module.
* Shipping his wifi drivers.
* VFD time is now synced every 5 minutes using a cron job.
* Software update and plugin-installation has been fixed.
* Using Tapaat's lirc config for spark and spark7162.
- The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
* A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
- Libsoup has been updated to 2.52 (from master-next).
- Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
added si2166b blindscan support.
Known issues:
Please use 'duckbox' instead.
- On Zgemma Star you cannot use full HD skins.
- Some Dreambox remotes may behave very sensitive.
TODO:
- Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
- Linux 2.6.18: Look into the v4l usb drivers.
- Add Spark specific plugins by gorski.
- Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
Link:
