am reusit sa il trec settings si s-a rezolvat si problema cu doi sateliti.
cu acest program puteti formata stikul in linux de pe windows
aruncati o privire si pe satupdate....
Pentru ipbox 9000HD
The installation of SifTeam Enigma 2 for AB IPBox 9000HD with HDD on usb flash.
There has to be inserted HDD and USB flash in the receiver!!!
1. Use AB image 8340b
2. Install the enclosed addon.
3. In PC copy the file "usb_config.img", rename it to "usb_update.img" and install it by basic way. After "DONE" restart the receiver.
4. Connect by webinterface and choose "format". Wait until the message "formatted susesfully"
5. Copy "enigma2.tar.gz" by FTP to /mnt/usb/usb0 (when the usb flash memory is formated successfully the folder "lost+found" will appear there).
6. Connect by web interface and choose "unpack" (appr. 2-3 min). When the image is unpacked you can see the folder tree by FTP in /mnt/usb/usb0
7. Standby+OK - switch off the receiver
Before turning on the receiver hold on nr. 3 on the remote control for turning the E2 or E1 on.
After next start last used software will start automatically.
When there is no picture by HDMI on TV restart the receiver, hold on MENU button on the front display of the receiver and change the video output to 1280*720p.
Attention!:
It is just the test version of the software. The installation is possible only in your personal responsibility. After crash of the receiver the warranty does not have to be guarantied.
The software works just with 1 dvb-s2 tuner and EMU and smartcard readers are not supported.
Originally Posted by sorin_bidian [Only registered and activated users can see links. Click Here To Register...]
nu nu , spune aci de fata cu toti :D:D:DQuote:
Originally Posted by snow [Only registered and activated users can see links. Click Here To Register...]
cu sonorul e multumita toata lumea ? (volum )
si pe hdmi si pe toslink e destul de slab.
la mine e ok.incearca sa dai prin volum de telecomanda de ipbox mai mult.E la 50%
ai dreptate, oarecum sunetul e mai puternic..
intre timp am incercat sa pornesc imaginea de pe fiash ( buton 4 apasat la boot ), insa pe telnet am vazut ca nu reuseste sa faca mount la fs.
voi ce experienta aveti ?
nu se poate defini sateliti noi ?
If you want to preview E2 and have no serial cable, this can help you.
Requires: NLB image installed in flash!
Here is a little guide with a very small flashimage, that prepare your uboot for change, to use the "1" and "2" key to switch between DGS and E2 boot.
Note, you need to download E2 image from a different location.
This file is just instructions and a little flashimage for 900/910/9000.
Get it here: [Only registered and activated users can see links. Click Here To Register...]
Howto for installing E2 on internal HDD
with NLB image installed
without Serial cable, only requirements are telnet access.
1. flash image that matches your hardware, 900,910 or 9000 img.
this will enable the fw_setenv to work on you nlb installed image.
2. ftp enigma2_cuberevo.tar.gz file to /media folder
3. telnet to box and execute commands below
cd /media
tar xzf enigma2_cuberevo.tar.gz
cd release
mv * ../
sync
sync
fw_setenv menu_1 'setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500";setenv bootcmd "bootm a0060000";save;boot'
fw_setenv menu_2 'setenv ipaddr 10.1.1.181;setenv gateway 10.1.200;setenv netmask 255.255.255.0;setenv bootide "run bootargside;ide reset;ext2load ide 0:2 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargside "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda2 rw rootfstype=ext2 init=/bin/devinit ip=$ipaddr::$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";setenv bootcmd "run bootide";save;boot'
In the last command you need to update ip adresses to match your network. othewise E2 is not accessable from network.
and you can boot DGS flash(hold down 1 on remote during) or E2 (hold down 2 on remote during)
remember to change ip adresses above.
nu intzeleg pct 1... cum sa :flash" imaginea pt. ip9000 de exemplu ????
adica sa nu incarci pe 900/910 imaginea de pe 9000 si invers. nu va merge
OK, eu am imaginea de la Sifteam... intzeleg urmatoarele :
1. Re-instalez imaginea de la NLB8421(v1.110) pt 9000HD
2. Fisierul E2_onHDD.zip are 3 imagini, una pt. ip9000 - ce fac cu ea ? cum o "flash" iarashi pe USB stick ?
3. Instalez prin FTP fisierul enigma2_cuberevo.tar.gz.zip in directorul indicat...
De la pasul 3 intzeleg, nu stiu la pasul 2 cum sa ma descurc....
Thanks
la pasul 2 spune:
prin ftp copiezi enigma2_cuberevo.tar.gz in /media folder
ai dreptate.... de fapt nu inteleg ce fac la pasul 1 :" flash image that matches your hardware, 900,910 or 9000 img.
this will enable the fw_setenv to work on you nlb installed image"
La care imagine se refera ? la NLB8421 sau la imaginile mici fin fisierul usb_comfig.welcome9000.img ??????????:dance:
Hmmm, mai intai instalezi imaginea celor de la nlb apoi "imaginea mica" din link, dupa care urmezi pasii 2.3.....
