i have problem with my box , i put wrong flash software and now my reciver dead
how to fix to boot again ?
please help
please help
It is impossible to put software from other ipbox model in your ipbox.So you can not put software for ipbox 9000 in 900 or 910....Maybe it is a problem with bootloader.Try to installed DGS r9580 if you can not then send your ipbox in your local dealer.Jtag you can not do in ipbox.
i try install beckup software and when it's goo to boothing it's write ER9
When i press of/on on the front panel only flash and then nothig no booting or usb update
when i connect to putty with rs 232 and start nothing read on putt
or it's totaly dead or i can fix this problem ?
with hyperterminal type all the command above it should restart
setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot
then put last uboot or good image for your box
thanks my frend i will try this .
regards
