pai cel mai simplu ar fi sa ne arati oscam,conf si oscam.user ...precis ai o problema acolo !
altfel ...asa din avion ...ce-am putea intelege ? eu folosesc aceasta versiune si merge fara
repros !
Am instalat Enigma2 NightlyBuild 1.1.1 pe un receptor IPBOX 910HD totul ok pana la emu, nu reusesc sa fac sa functioneze oscam am pus emu manager v4.0 pornesc Oscam-ul dar nu vrea sa mearga. Exista alta metoda de a pune oscam pe imaginea asta??
repros !
oscam.conf
# main configuration
[global]
nice = -1
WaitForCards = 1
# logging
pidfile = /var/run/oscam.pid
logfile = /var/log/oscam/oscam.log
usrfile = /var/log/oscam/oscamuser.log
cwlogdir = /var/log/oscam/cw
# monitor
[monitor]
port = 988
aulow = 120
monlevel = 1
# web interface
[webif]
httpport = 8888
httpuser = myusername
httppwd = mypassword
# anti-cascading
[anticasc]
enabled = 1
numusers = 1
sampletime = 2
samples = 5
penalty = 1
aclogfile = /var/log/oscam/aclog.log
denysamples = 9
# protocols
[newcamd]
key = 000102030405060708090A0B0C0D
port = 10000@0100:FFFFFF;10001@0200:FFF000,FFFF00;10002@0300:FFFFFF
[radegast]
port = 20000
user = user1
allowed = 192.168.0.0-192.168.255.255
[cs378x]
port = 30000@0100:FFFFFF;30001@0200:FFF000,FFFF00;30002@0300:FFFFFF
[cccam]
port = 40000
version = 1.2.3
build = 1234
reshare = 2
[gbox]
password = password1
maxdist = 4
cardinfos = card.infos
ignorelist = ignore.list
onlineinfos = online.infos
locals = 01000000,02000000,0300FFFF
[serial]
device = user2@/dev/ttyS0?delay=1&timeout=300
[dvbapi]
enabled = 1
user = user1
socket = /tmp/camd.socket
oscam.user
# user configuration
# user for group 1 with Betacrypt tunnel, no monitoring, only one connection possible, AU enabled
[account]
user = user1
pwd = password1
monlevel = 0
uniq = 1
group = 1
au = reader1
services = services1
betatunnel = 0300.FFFF:0100,0400.FFFF:0100
ident = 0100:000000
caid = 0100
# user for group 2 with monitor access, AU enabled
[account]
user = user2
pwd = password2
monlevel = 1
uniq = 0
group = 2
au = reader2
services = services2
ident = 0200:000000
caid = 0200
# user for group 2 without monitor access, AU disabled, account disabled
[account]
user = user3
pwd = password3
disabled = 1
group = 2
ident = 0200:000000
caid = 0200
# user for group 3 without monitor access, only one connection possible, AU disabled, multiple idents
[account]
user = user4
pwd = password4
monlevel = 0
uniq = 1
group = 3
ident = 0300:000000,FFFFFF;0400:FFFFFF
caid = 0300
# user for group 5 with anti-cascading, only 1 logging allowed, send fake CWs as penalty
[account]
user = user5
pwd = password5
group = 5
services = services5
ident = 0500:000000
caid = 0500
numusers = 1
penalty = 1
Daca cineva foloseste aceasta versiune de emu manager, rog sa spuna daca stie cum se activeaza pornirea automata a emulatoarelor. am facut chmod 755 la toate fisierele dupa ce le-am copiat. daca pornesc manual, totul ok fara probleme, inclus dupa restart-gui, dar dupa un reboot la tot aparatul sau daca mai faca astia vreo faza si taie curentul, tre sa fiu atent pe aparat, sa-i dau un start la emu. nici pluginurile care sunt acolo nu apar la meniul pluginuri, si mai mult de atat, butonul galben pe care selectional subtitrarea s-a dezactivat de cand am copiat si acel keymap.xml; toate acestea pe un cuberevo 250 hd
Pentru a porni emu la restart pui in var/etc/rcS_user asta /var/bin/oscam & sau cum e emulatorul denumit in var/bin adica /var/bin/nume_emu &
multumesc pentru sfat, dar tot nu vrea. am incercat si cu panel 3.0, dar se pare ca nu reusesc. am mai adaugat eu cateva linii in acel script, dat nu porneste nimic automat
Am vazut ca si AAf Multimedia 2 e ceva mai nouá. Merge cu oscam?# add here your own commands to be launched at enigma2 starts
#!/bin/sh
/usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/emustarter.sh
/usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/start_oscam.sh
/var/bin/oscam &
insmod /lib/modules/cifs.ko
mount -t cifs //192.168.1.101/dreambox /hdd -o username=dreambox,password=dreambox
exit 0
#-------------fine mod mario sat
Mege oscam bine pe AAF, stabila imagine de data asta, si merge si PKT cel mai nou e stabila ca si siftemu 1.1.1 de mai sus, cu skyn gold Hd.
niste mizerii. si nightly build si extreme. fara suport emu, scripturi de start-stop poti sa te p*i*s* pe ele. alt receptor pus deoparte pentru "piese". adio SH4! back to vu+!
succesuri!
Pacat,sa stii ca sunt cele mai stabile si rapide imagini de pana acum !
Daca te chinuiai putin puneai emu pe ele .
pai.... am pus! cu problemele de rigoare!
stii reclama aia la iaurt (parca): prea tare, prea moale, prea acru... aici (vorbim de imaginile pomenite mai devreme) devine prea complicat! eu am inteles ca grupurile de "dezvoltare" incearca sa indeparteze incepatorii si nestiutorii de C S, da' nici in halu' asta! trebuie sapat pana in China ca sa aflii 2-3 proceduri. nu-mi vine chiar la indemana. cand ajung la performanta sa ma apuce 2 dimineata punand o imagine si pregatind-o pentru "viata de zi cu zi", nu mai e performanta si nici tentant. vremurile in care: a) imagine up pe rs232, b) configurare video, c) download emu, d) configurare, e) vizionare placuta s-au dus. probabil ca aici se opreste si partea de hobby. le fac sa mearga (trebuie sa satisfac toata familia la capitolul asta) si la revedere!
scuze de offtopic da' nici cafeaua nu ma trezeste la ora asta!
succesuri!
