Likes Likes:  4
Results 1 to 5 of 5
Thread: Plugin Netflix Dream Dreambox HD Models
    Thumbs up Plugin Netflix Dream Dreambox HD Models
    Netflix Dream
    This plugin enables you to use Netflix on a Dreambox One.
    No other VOD plugin needs to be installed for this.
    The actual VOD plugin is already included in this plugin, so the access data is also entered in Netflix Dream.
    In advance, you can also install and continue to use the actual VOD plugin and the GP4 GUI-Netflix plugin.
    Netflix Dream also uses its own Netflix cookie, so all plugins can run in parallel.
    https://i.postimg.cc/8CCpNDK7/1.png
    You can reach the menu with Exit, Menu and left arrow key.
    https://i.postimg.cc/LXfrMbpq/2.png
    https://i.postimg.cc/cHqbTBnd/2a.png
    You reach the genres if you use the up arrow on the start screen.
    https://i.postimg.cc/jSwc9JK2/3.png
    https://i.postimg.cc/PJ5zMC2t/3a.png
    https://i.postimg.cc/65SLd5RX/3b.png
    In the episode screen you can stay in the episode list and at the end of a season you will automatically be added to the new season
    https://i.postimg.cc/JnnG6jVd/4.png
    When searching, you only have to enter a letter or number, then the search starts automatically.
    You can adjust the search text at any time, even when the Netflix spinner is running.
    The input is checked every 4 seconds, if you have changed the input, a search is started again.
    Installation:
    As a dependency, enigma2-plugin-widevineprocessor and lib32-dreamwidevine are used.
    Those who now use GP4, NN2 or the MediaPortal already have these dependencies on the box.
    I myself use the Dreambox Experimental Image, here these dependencies are missing, here you have to install the two packages first, then you can only install Netflix Dream.
    Packages enigma2-plugin-extensions-netflixdream_x.x.x.deb onto the box after / tmp FTP
    Enter the following in Telnet or SSH:
    apt-get update
    dpkg -i /tmp/*.deb
    NOTE:
    If you enter incorrect login data when you first log in, it can happen that you get a login block from Netlfix.
    For this I ask you to check and adjust your access data.
    Now you have to wait 3 hours until this lock is lifted again.
    But if the registration worked and you have to choose a profile, then that fits.
    Maybe you can not play a stream yet, you have to restart Gui to do this, then it works too.
    This plugin is still very young, so there may still be a few imperfections
    Also this plugin will only be available for Dreambox, hence the dream in the plugin Png and the plugin name Netflix Dream.
    Thanks murxer
    enigma2-plugin-extensions-netflixdream_1.0.3.deb.rar (4.06 MB)
    https://www.mediafire.com/file/akc64...3.deb.rar/file
    Update v1.0.8
    - Profile ID revised thx dhwz
    - Serial logo fix
    - Series episodes fix when there are less than 5 episodes available
    - Timer fix for cover loader
    v.1.0.7:
    - new plugin png thx pclin
    - keymap update thx pclin
    - Revised Netflix API queries
    - Player Gui and other functions added
    - Protection of minors
    - Fix genre
    - several minor fixes
    - Movie info screen revised
    - Add and delete my list function added
    - My list query revised, up to 200 entries are supported
    - Profile Screen Fix
    - Revised config screen for the protection of minors
    Thanks murxer
    enigma2-plugin-extensions-netflixdream_1.0.8.deb.rar (4.09 MB)
    https://www.mediafire.com/file/vnt1e...8.deb.rar/file
    Update v1.0.9
    -Progress backup fix
    Thanks murxer
    https://www.mediafire.com/file/733xo...9.deb.rar/file
    Default Update-compatible installation adapted.
    Child Safety:
    To do this, you have to activate and set up parental controls via the browser on Netflix.
    Unfortunately, the pin query via Netflix does not work, you have to save the pin in the plugin menu.
    You can correct the entry with the left arrow key.
    Player:
    You shouldn't get it wrong, it's just a gui for the multi-function player.
    - Skip intro, with timer
    - Play next episode automatically, with timer
    - Progress is sheared off in /etc/enigma2/NetflixDream/netflix_watched.json for each profile individually.
    Didn't manage to secure progress on Netflix yet
    - You can jump using the number keys and direction keys
    Installation:
    There are no more deb files to install the plugin, the plugin is now only installed via the console, is also online updatable when a new version is pending.
    Thx Lizard who made it possible.
    wget http://netflixdream.bpdl2.mine.nu/dreamos-installer.sh -O - | / Bin / sh
    To you list:
    - Secure progress on Netflix
    - Pin request from Netflix
    May be that you can not play a stream yet, you have to restart Gui to do this, then it works too.
    __________________
    Update Online
    Version 1.1.0
    - Player InfoBar when jumping is now also displayed
    - Profile screen revised
    __________________
    Update online
    Version 1.1.6
    - add trailer
    - Serien/Movies Genre Fix
    - Cover loader Fix
    Quote:
    murxer wrote:
    At the moment the trailers cannot be played yet, here the picture remains black.
    Here you have to be patient, widevine has to get an update.
    If you now select Series or Movies in the menu, you will automatically be taken to the genre screen.
    Then select your desired genre, now a maximum of approx. 1200 entries are loaded.
    The old function for series and films no longer works, so I decided on this variant.
    From version 1.1.3 you should now get a message that is an update for NetflixDream Online.
    Installation can then be carried out immediately.
    Because of QB, I haven't done anything here yet, first I had to get JustWatch up and running again.
    Now I will customize Amazon, Netflix and JustWatch, then the QB will work again.
