Thanks Thanks:  7
Likes Likes:  14
Results 1 to 15 of 24
Thread: Vu+Duo 4k
    Default Vu+Duo 4k
    Azi a ajuns STB-ul, acum am ce sa fac
    Box
    Brand & Model: Vu+ Duo4K
    Chipset: 7278
    Main Memory: 436420 kB free / 567432 kB total
    Box Uptime: 0:35
    Software
    System OE: OE-Alliance 4.2
    Firmware version: OpenViX 5.2.025 (2019-01-20)
    Kernel / Drivers: 4.1.45 / 20190107
    Tuners
    Tuner A Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner B Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner C Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner D Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner E Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner F Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner G Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner H Vuplus DVB-C NIM(BCM3158) (DVB-C)
    Tuner I Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner J Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner K Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner L Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner M Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner N Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner O Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Tuner P Vuplus DVB-S NIM(45308X FBC) (DVB-S2X)
    Hard disk model: ATA(KINGSTON SH103S3)
    Capacity: 12.0 GB free / 111.8 GB ("120 GB") total (/media/hdd)
    Network Interface: eth0 (dsa)
    Link Speed: 1 GBit/s
    Are 8 tunere de cablu (1*8 FBC) si 8 tunere de sat (2*4 FBC)
    12 Nov 2007
    Sal, de unde l-ai cumparat, cat a costat ma intereseaza si pe mine ?
    Multumesc !
    De aici 400 (+18 transport in RO) dar nu livreaza decat in DE (gratis)
    Acum vad ca s-a scumpit
    De fapt nu stiu daca s-a scumpit, atunci au avut o reducere de la 429 la 399.6
    Din pacate, de ce mi-era frica...
    Softul nu e "copt", nu-mi forwardeaza vol+/- , mute si power la TV prin HDMI CEC, nu merge diseq 1.1 si nu-mi vede tot RAM-ul, doar 567432 kB din 2048 MB.
    O sa mai umblu nitel prin el, poate mai trebuie sa instalez ceva si oricum astept un update de soft, poate se rezolva problemele.
    In rest e bun.
    1 la diseqc am gresit cablul, iar la volum si power tv trebuia programat cam ca la vu+uno
    2 ramane sa vad de ce nu arata tot RAM-ul
    PS E bine ca-mi da de lucru...
    27 Apr 2007
    Bayern, DE
    O parte din memoria RAM e rezervat sistemului de operare. Ceea ce iti Este afisat este disponibilul pt. User Interface.
    Cum e impartita aceasta memorie Poti sa vezi dupa pornire in
    /var/logs/message
    Framebufferul grafic, OpenGL pentru Animatii Si Kodi, bufferul de rulaj sunt rezervate Si scazute , deci vezi efectiv CE ramane la dispozitia userului.
    Momentan am un VU+ Uno 4k SE , iar inainte am avut Si Solo SE , intotdeauna memoria RAM afisata in soft (VTI , Blackhole) era mai mica .
    Gesendet von meinem Redmi 4X mit Tapatalk
    ---------- Post added at 21:58 ---------- Previous post was at 21:48 ----------
    La Mine in Vu+ Uno 4K SE sunt afisati aprox. 700 Mb RAM din 2 GB
    Si in consola arata tot asa
    top - 21:15:21 up 6:32, 1 user, load average: 0.44, 0.37, 0.37
    Tasks: 243 total, 1 running, 125 sleeping, 0 stopped, 117 zombie
    %Cpu(s): 0.3 us, 0.6 sy, 0.0 ni, 98.9 id, 0.0 wa, 0.1 hi, 0.1 si, 0.0 st
    KiB Mem : 567432 total, 227332 free, 189512 used, 150588 buff/cache
    KiB Swap: 0 total, 0 free, 0 used. 328328 avail Mem
    iar pe duo2
    top - 21:15:59 up 1 day, 6:17, 1 user, load average: 0.31, 0.23, 0.16
    Tasks: 148 total, 1 running, 92 sleeping, 0 stopped, 55 zombie
    %Cpu(s): 4.8 us, 2.0 sy, 0.2 ni, 92.5 id, 0.0 wa, 0.0 hi, 0.5 si, 0.0 st
    KiB Mem : 1240080 total, 46724 free, 168708 used, 1024648 buff/cache
    KiB Swap: 0 total, 0 free, 0 used. 1039722 avail Mem
    in webif
    Brand & Model: Vu+ Duo²
    Chipset: Broadcom 7424
    Main Memory: 1058580 kB free / 1240080 kB total
    si duo2 are tot 2giga de ram
    Parca pe solo4k arata tot, dar nu-l mai am sa verific...
    ---------- Post added at 21:46 ---------- Previous post was at 21:35 ----------
    Mda, am intrat pe un solo4k si e acelasi drac
    Brand & Model: Vu+ Solo4K
    Chipset: 7376
    Main Memory: 760960 kB free / 907744 kB total
    BH (doar ei deocamdata) au implementat driverele pentru multistream.
    Merge perfect pe 5W (altceva n-am incercat)
    S-a actualizat MIS si pe OpenVix. Tot pe 5W am probat.
    Thumbs up The latest BlackHole image is 3.1.0 Multistream VU+ Duo4k Image
    BlackHole-3.1.0-vuduo4k_usb_release_20201005_b5f1952.zip
    https://mega.nz/file/PZ8USBTK#gM_sou...nPQWVzNG-KLHa4
    Ca sa am un all-in-one, am probat un stick android 4k cu kodi si cu alte aplicatii de streaming in HDMI-in.
    Functioneaza, dar imaginea e cam spalacita.
    Maine, ca acum nu pot, o sa bag un duo2 in hdmi-in sa vad daca e aceeasi imagine.
    A mai intalnit cineva problema asta? Exista vreo solutie?
    7 Post(s)
    Eu nu il mai folosesc de mult pe hdmin cauza aceeasi imaginea e spalacita nu am sapat sa caut info daca se poate schimba ceva.
    Imi pare ca vuduo2 trecut prin hdmi-in de la duo 4k se vede la fel.
    Stickul cu android e ceva mai spalacit.
    Se poate adauga intr-un buchet de favorite (de ex. /etc/enigma2/userbouquet.dbe00.tv):
    #SERVICE 8192:0:1:0:0:0:0:0:0:0:
    #DESCRIPTION HDMI-IN
    Si apare in lista HDMI IN in buchetul respectiv
    10 Nov 2019
    hdmin are o setare in care poti alege rezolutia.
