Rezolvat
Am butonat azi un pic acest receptor " octagon sf8008 "cu img openATV 6,3 am reusit sa fac sa functioneze cam tot ce poate acest receptor, ce nu imi mai amintesc cum sa fac sa imi apara in skin default ecm info server info. O mana de ajutor daca se poate.
Multumesc.
Rezolvat
Open Black Hole 4.3.014 Octagon SF8008
https://www.mediafire.com/file/5c294...8_mmc.zip/file
OpenESI 9.0 Octagon SF8008
http://www.openesi.eu/images/index.p...ctagon/sf8008/
OpenNFR
nfr/feeds/6.4/images/sf8008
http://dev.nachtfalke.biz/nfr/feeds/6.4/images/sf8008/
nfr/feeds/6.3/images/sf8008/
http://dev.nachtfalke.biz/nfr/feeds/6.3/images/sf8008/
pkteam SF8008 HYPERION 7
http://e2.pkteam.pl/index.php?dir=IM.../HYPERION%207/
AAF nightly images Octagon SF8008
Neue Titan stable Version 1.91
v1.91
http://atemio.dyndns.tv/nightly-imag...K%20UHD/v1.91/
v1.90
http://atemio.dyndns.tv/nightly-imag...K%20UHD/v1.90/
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 27.02.2020
- [SF8008] + [SF8008mini] Update Drivers]:
- May improve the IR Infrared receiving sensitivity
- Fix a issue for smart card when close the /dev/sci0
- Improve the diseqc send when lnb power on.
- Updated files:
- hi-dvb.ko
- hisi_sci.ko
- hisi-ir.ko
- libreader
From tomorrow in images!
OCTAGON GERMANY SUPPORT​
Super acest decoder :
Recomand cu caldura la tori.
Imaginea cea mai buna e Openeigth.
Prietenii stiu de ce.
KODI 18.5 TEST mit NETFLIX OCTAGON SF8008 E2 4K UHD
https://octagon-forum.eu/sf8008-atv-test185.jpg
oe-alliance Presends
Big Thanks goes to openSPA Team and openBH Team for Porting all from KODI 17 to 18
thanks Captain OpenATV too.
Anleitung
Install Netflix Addon for Kodi 18.5 Octagon SF8008 (Test, OpenATV 6.3)
https://youtu.be/6TREaabHf7Q
Netflix Repo : https://mega.nz/#!t3ZATIpI!GLiQYqkcq...IIxpPRhQIayjPM
Amazon Repro: https://mega.nz/#!NigHnQpB!zQX41VJz_...2X2K6-xMH0Jmv4
Kodinerds Repro z,b, Joyn,DAZN usw : https://mega.nz/#!FygnlaxY!zlzYk4KDv...h8nkITkhttp://
INFO Netflix ABO wird benötigt!
Installation am besten über Flash Online aus dem Laufenden Image
KODI 18.5 ist im Image enthalten
andere Widevine Addons sollten auch laufen wie dazn, Joyn, Prime usw.
Schreibt eure Erfahrung und was Ihr Installiert hab mit eine kleinen Anleitung das auch alle es verstehen.
Link zum Repro oder Addons nicht vergessen.
und hier wie immer alles Public im GIT nicht wie andere Images die alles Close machen...
https://github.com/oe-alliance/oe-al...s/meta-octagon
STATUS was Positive getestet wurde:
Netflix
Amazon VOD
SKY GO VOD, LIVE Spiele gehen nicht
Joyn
Xtream
SF8008 openATV 6.3 Image mit KODI 18.5
https://mega.nz/#!t3ZS1A5I!F39jzONe6...DQkKgp9zpfT3KE (mega nz)
https://www.mediafire.com/file/pfvjk...3_mmc.zip/file (mediafire)
__________________
OCTAGON SF8008 4K UHD E2 (Single, Combo, Twin)
Review OCTAGON SF8008 v2 | Deutsch (E2WORLD)
https://youtu.be/ljD1O1vXjtw
Danke an Gunnar Koser für das Video.
Octagon SF8008 Single, Combo and Twin V2. (in Sales since October 2019)
imporvements:
- Front Display improved
- Material Housing cover imporved
- CPU heathing improved
- Tuner GAIN improved
- Rubber foot use better one
- Giftbox improved
- WOL HW + HW Full Recovery by Recovery Button.
https://www.octagon-forum.eu/
https://www.octagon-germany.eu/
OCTAGON SF8008 openATV 6.4 KODI 18.6
Link 1:
https://mega.nz/#!Mr5TgboR!cCJTKF_64...6n7lUmvOMhttp:
Link 2:
https://www.mediafire.com/file/l2flm...5_mmc.zip/file
Nonsolosat OCTAGON SF8008 Unofficial Image
http://www.mediafire.com/file/xktw9f...8_usb.zip/file
http://www.mediafire.com/file/alf7z3...write.zip/file
---------- Post added at 11:45 ---------- Previous post was at 11:32 ----------
OpenEight KODI 18.x OCTAGON (Test)
OpenEight Kodi 18.6 OCTAGON SF8008:
https://octagon-forum.eu/test-team/o...200317_mmc.zip
X-Streamity Plugin (.m3u Player) auf OpenEight
Config
Ftp:
/etc/enigma2/X-Streamity/playlists.txt
Open playlists.txt and copy (öffne playlists.txt und kopiere m3u link)
http://domain.xyz:port/get.php?usern...plus&output=ts
https://octagon-forum.eu/test-team/xtv/1xtv.jpg
https://octagon-forum.eu/test-team/xtv/2xtv.jpg
https://octagon-forum.eu/test-team/xtv/3xtv.jpg
https://octagon-forum.eu/test-team/xtv/4xtv.jpg
https://octagon-forum.eu/test-team/xtv/5xtv.jpg
https://octagon-forum.eu/test-team/xtv/6xtv.jpg
Note; this plugin for all octagon models with open8eight image.
Noua imagine cu Kodi 18.x pregatita pentru testare, sper sa apara in curand disponibila pentru publicul larg.
Foarte interesanta.
Am testat kodi 18.6 Leia cu Openatv 6.4
Filmele in format HEVC nu le reda. Cele in format mkv sunt redate dar dupa scurt timp Octagonul se blocheaza si trebuie repornit din butonul Power.
In schimb Youtube reda cursiv imaginile UHD.
Si pluginul Netflix functioneaza bine, dar mai incomod este de umblat prin menu.
Tinere, nu uita ca e in beta!!! Tu gandeste ca eu am "alfa 19" de doua luni si stau mai rau ca tine
Vor apare pe rand versiuni noi. Cunosc personal o parte din echipa de la openeigth cei care dezvolta acest project.
Vezi ca "tanarul" e de-o seama cu noi .
Ar vrea el sa fie cu vreo 30 mai mic
