Results 1 to 7 of 7
Thread: Card Technisat Conax ''CX''
    12 Aug 2007
    Default Card Technisat Conax ''CX''
    Am cardul Technisat Conax SmartCard ''cx'' . Cum pot sa il folosesc cat mai eficient ? Nu stiu ce deschide , nu stiu care e treaba cu mtv , daca ma puteti lumina un pic. Luam si receptorul ce era cu cartela dar ..era doar cutia inauntru era alt receptor sd.
    Here is the newest information on MTV unlimited from TechniSat
    You have probably noticed that for a while that there is no more 6 or 12-month ticket available.
    (I deliver instead of 12-month tickets, 3 month tickets that you can purchase for the full 12 months when you order 4 of them)
    Just recently it has been rumored: From 1 July 2013 there will be new smartcards (up to now Yellow Conax card) and also new tickets with the corresponding validation time.
    There is a string attached to this:
    · The new Conax cards will not be exchanged free of charge you will have to purchase a new card (price is not known at present, but should be in the region of the old price approx. 25 Euro)
    · Old and new tickets are not compatible. This means, the ticket that you have purchased from me can only be activated by the old smartcard. This means also if you have not already activated the cards you must activate the card before the 30th June 2013. After this date it will not be possible to activate the tickets
    · When you wish to receive MTV beyond 30th June 2013 I recommend that you charge the card before this date (perhaps for 1 or 2 years in advance) the old cards that are valid will not be switched off according to the announcement from MTV. So you will be spared the costs of a new Conax card for the validation time of the old card.
    oscam.server
    [reader]
    label = MTV
    protocol = internal
    device = /dev/sci0
    services = mtvunlimited
    caid = 0B00
    detect = cd
    mhz = 500
    group = 1
    oscam.services
    [mtvunlimited]
    caid = 0B00
    provid = 000000
    srvid = 6FF3,6FEE,6FEF,6FF1,6FF0,6FFF
    12 Aug 2007
    Deci se aseamana cu cardul de la Focussat, se reincarca cu cod de reincarcare pentru nu stiu cate programe MTV . Am dreptate ? Sau am si ceva nelimitat ?
    exact ai dreptate 100%
    exact ca si la card focus
    se incarca in functie de perioada pe care ai ales 6 luni sau un an (365 zile )
    https://www.technishop.de/zubehor/mtv-unlimited.html
    http://www.ebay.es/itm/Technisat-MTV...QAAOxyk99R0e5i
    http://www.ebay.es/itm/MTV-unlimited....c100005.m1851
    dupa ce ai efectuat plata prin pay pal prin email iti vine acel cod (Ticketnummer)
    trebuie sa-ti activati cardul ( luni-vineri 8-20) complectand acest formular de pe pagina lor :
    https://www.mtv-unlimited.de/index.php?page=mtvticket
    se introduce cardul intr-un receptor cu cititor conax nativ sau cam TechniSat Conax
    oscam ,scam 3.59--3.60
    se comuta pe ---MTV Music 24----MTV Dance---VH1 Classic (depinde cum avem norocul )si asteptam lumina
    succes
    12 Aug 2007
    era undeva cu 50 ron ptr 90 zile ..satmultimedia parca . O sa incarc o data sa vad cum este .Sau il dau ...
    09 May 2007
    Seria cardului ? In 2013 s-au schimbat cardurile. Daca e un card vechi, nu v-a mai merge.
    Numai bine
    12 Aug 2007
    0000/4539 merita sa il incarc sau nu ?
