Thanks Thanks:  51
Likes Likes:  20
Page 80 of 81 FirstFirst ... 3070767778798081 LastLast
Results 1,186 to 1,200 of 1201
Thread: OSCAM file
  1. #1186
    7 Post(s)
    OSCAM 11734
    Message: deleted module-ird-guess files
    improved some log message for videoguard thanks to @ohmza
    proper fix for mdc2.c
    7 Post(s)
    OSCAM 11736
    Message: fixing HD05 thanks to ohmza convert space to tabs
    OSCAM 11736
    Message: fixind CLANG compiler for no-schedule-insns flag.
    OSCAM 11735
    added Streamrelay libdvbcsa - thanks to lpm11 <lpm11@lpm11>, fegol, icb, loka, kitte888, youtube18, WXbet and many more
    added cak7 patch - thanks to ohmza, TV-Gamer and others
    7 Post(s)
    OSCAM 11738
    Message: removing ffdecsa
    added libdvbcsa_buffer Patch thanks to WXbet and others
    fix for HD04 Tiers and 1856 thanks to ohmza
    7 Post(s)
    OSCAM 11739
    Message: typo fix for Makefile und CMakeLists.txt thanks to ohmza
    fix tivusat 1856 shared emm thanks to ohmza
    7 Post(s)
    OSCAM 11740
    Message: fix #4913 gbox part remove as defaults CARDREADER_STINGER & MODULE_SCAM
    7 Post(s)
    OSCAM 11741
    Message: fix tivusat 1856 shared emm thanks to ohmza
    7 Post(s)
    OSCAM 11742
    OSCAM 11743
    Message:
    fix UK descrambling thanks to WXbet
    update copyright year thanks to WXbet
    added libdvbcsa help thanks to WXbet
    removed non neon supported message thanks to WXbet
    cak7 improved log and HD04H tiers date fix thanks to ohmza
    added Fransat V6 cards to hanlde ECM of UHD Channels thanks to Constance
    removed some whitespace
    updated the CS_VERSION to 1.30 since was significant changes in short past
    OSCAM 11744
    OSCAM 11745
    OSCAM 11746
    OSCAM 11747
    OSCAM 11748
    Message:
    fix whitespaces thanks to Optimum Power
    7 Post(s)
    OSCAM 11749
    Message: fix for macOS libdvbcsa (thanks to ohmza)
    introduce IPv6 support for streamrelay and radegast (thanks to ohmza)
    inform about using the wrong libdvbcsa library in startlog and avoid crashes in this case (thanks to WXbet)
    7 Post(s)
    OSCAM 11750
    Message: fix LIBDVBCSA_LIB not properly defined (thanks to WXbet)
    7 Post(s)
    OSCAM 11751
    Message:
    reduced binary size with AES constants, there was twice included (thanks to lpm11) -> ​https://trac.streamboard.tv/oscam/ticket/4919
    fix dynamic linking compile errors on the system that install libdvbcsa at an unusual path (thanks to ohmza)
    add supports to cwpk1 through cwpk7 (thanks to ohmza and feri33)
    7 Post(s)
    OSCAM 11752
    Message:
    remove unnecessary imports during libdvbcsa static build
    replace string preprocessor variables regarding libdvbcsa
    precise libdvbcsa warnings in startlog
    fix build warnings with clang on MacOS
    force build warning when wrong libdvbcsa headers detected
    all thanks to WXbet
    7 Post(s)
    OSCAM 11753
    Message:
    fix linking errors when compiling oscam with static LIBCRYPTO library alone
    fix IRD ID is not correctly displayed on nagra cak7 cards
    fix typo on cwpk7 log message on nagra cak7
    all thanks to ohmza
    OSCAM 11754
    Message:
    extended the ecm_info file (thanks to DimitarCC)
    force use of UTF8 for Webif (thanks to lpm11)
    removed Touch function (thanks to lpm11)
    Do not start DVBAPI client (and unnecessary thread) if DVBAPI is compiled, but not available on the machine (thanks to lpm11)
    OSCAM 11755
    Message:
    remove old and unneeded JS stuff (thanks to lpm11)
    removed one more touch element forgotten
    whitespace cleanup
    OSCAM 11756
    Message:
    fix for Browser localStorage (thanks to ohmza)
    7 Post(s)
    OSCAM 11757
    Message: git-svn-diff.sh changed permission to 755 (thanks to WXbet)
    fix for forgotten length (thanks for patch alex2501)
    OSCAM 11758
    Message: simplify cak7 code (thanks to lpm11 and for all who tested)
    7 Post(s)
    OSCAM 11759
    Message: fix compile warnings for unused variables (thanks to gabberhead for reporting and WXbet for patch)
    7 Post(s)
    OSCAM 11760
    Message: fix Building without Nagra not possible at Nagra_Merlin ​https://trac.streamboard.tv/oscam/ticket/4924 (thanks to Opti)
