Thanks Thanks:  6
Likes Likes:  10
Page 11 of 11 FirstFirst ... 7891011
Results 151 to 162 of 162
Thread: General News
  1. #151
    03 Feb 2014
    BeIn Sports va transmite integral CM 2014
    Ieri BeIn Sports a anuntat transmiterea integrala a Campionatului Mondial de Fotbal 2014. Cele 64 de meciuri ale competitiei vor fi transmise in integralitate de BeIn Sports, dintre care 36 in exclusivitate, pe canalele BeIn Sport 1&2 HD, respectiv SD, precum si BeIn MAX In afara de acestea, pe toata durata competitiei se vor transmite interviuri, comentarii si actualitatea completa a meciurilor necodat pe BeIn Sports, dar nu meciurile competitiei.
    Cum timpul este cam scurt pana la CM 2014 sa vedem daca vor avea timp sa-si implementeze masurile de securitate anuntate contra piratajului si anume imperecherea cardurilor cu receptoare proprii, dar eu sunt cam sceptic ca vor reusii, mai degraba este un anunt de marketing pt a-si vinde produsele.
  2. #152
    konstantine's Avatar
    BSkyB cumpără Sky Germania și Sky Italia sursa
    19 Feb 2013
    Deci se va numi SKy Europe?
  4. #154
    E o intrebare cu raspuns indus (tendentioasa).
    Daca am postat sursa,nu prea vad rostu' intrebarii.
    Romanian Intact Media Group combines the TV channels
    Antena1,
    Antena Stars,
    Antena3,
    Happy Channel,
    Zu TV,
    Antena International,
    Antena HD
    and radio stations
    Radio Zu (FTA)
    Radio Romantic (FTA).
    The TV channels are encrypted in the Conax system, but at the time of publication of the article, the audio on all channels is decoded.
    The same composition of the package is originally broadcast by the Eutelsat 16A satellite (16 ° E) , and the transmission is used by Freesat Romania cardholders .
    A possible shift of the transmissions to the 39 ° E position would complicate the reception among Freesat Romania users , who would have to install a second antenna or move the existing one, e.g. to a satellite turntable.
    Technical parameters of the tests (PID V / A / PCR / SID):
    Hellas Sat 3 (39 ° E) tp. -
    ( 12.655 GHz , pol. H, SR: 15155, FEC: 3/4; DVB-S2 / 8PSK) Provider: Antena Group
    - Antena1 (1120/1221/1120/1; MPEG-4 / SD; Conax)
    -Antenna Stars (2120/2221/2120/2; MPEG-4 / SD; Conax)
    - Antenna3 (3120/3221/3120/3; MPEG-4 / SD; Conax)
    - Happy Channel (4120/4221/4120/4; MPEG -4 / SD; Conax)
    - ZU TV (5120/5221/5120/5; MPEG-4 / SD; Conax)
    - Antenna International (6120/6221/6120/6; MPEG-2 / SD; Conax)
    - Antenna HD(7120/7221/7120/7; MPEG-4 / HD; Conax)
    - Radio Zu (- / 6223/6223/55; FTA)
    - Radio Romantic (- / 3223/8191/56; FTA)
    http://satkurier.pl/news/192805/rumu...nie-z-39e.html
    azi 30.09.2020 la orele 09.00 am si 11.15 am pe programul antena 1 a rulat un baner in partea superioara a ecranului, prin care informa ca incepand din data de 08.10.2020 grupul Intact Production se muta pe satelitul Hellas Sat 3 (39°E)
    12,655 GHz, pol. H, SR: 15155, FEC: 3/4; DVB-S2/8PSK Conax
    Antena 1
    Antena Stars
    Antena 3
    Happy Channel
    Zu TV
    Antena HD
    -R- Radio ZU
    -R- Romantic FM
  6. #156
    45 Post(s)
    Am primit azi SMS 1752 cu urmatorul text:
    Ca urmare a schimbarii satelitului de catre Antena Grup, incepand cu 8.10.2020, posturile Antena 1, Antena 3, Antena Stars, Happy Channel si ZU TV nu vor mai fi disponibile in grila Freesat. Ne cerem scuze pentru incovenient si depunem toate diligentele sa fie disponibile incepand cu 01.12.2020.
  7. #157
    Default Intelsat 10-02 1W
    Intelsat 10-02 1W, 12705 V 45000 3/4 8PSK
    Alaturi de NASA UHD inca 3 canale 4K: Wow, Mooz si Heritage.
    Stiti ceva ceva despre ele, teste cumva?
  8. #158
    45 Post(s)
    Abia au aparut, dar vad ca 4K Heritage deja nu mai transmite decat sigla sau o fi pauza mai indelungata de transmisie.
    Celelalte inca mai au si imagini.
    ---------- Post added at 11:07 ---------- Previous post was at 09:49 ----------
    Revin si semnalez ca programul WOW este vazut ca serviciu de date in unele imagini E2, cum ar fi OpenAtv sau Pure2, poate mai sunt si altele
    Pentru asta trebuie schimbat atributul serviciului din "Data" in "TV" astfel:
    1) Prin dreamedit se transfera fisierele in folderul de lucru.
    2) Se editeaza manual programul WOW! si se schimba atributul Service Type de la 0 (data) in 1 (Tv)
    3) Se salveaza dupa care se tranfera inapoi in receiver. Se restarteaza si WOW! va apare in lista de programe.
  9. #159
    10 Nov 2019
    In Pure2 trebuie doar o rescanare a frecventei, fara alte giumbuslucuri.
  10. #160
    45 Post(s)
    @escco
    se vede dupa rescanare, e corect, dar dupa ce te te plimbi prin alte transpondere si vezi alte programe nu mai gasesti wow! in lista. iarasi rescanezi, de fiecare data?
  11. #161
    10 Nov 2019
    Nu, nu dispare.
  12. #162
    ARTE
    Programs in UHD quality-----from 15 april to 1 may
    https://www.arte.tv/de/videos/RC-022...uhd-qualitaet/
