Thanks Thanks:  7
Likes Likes:  7
Page 11 of 11 FirstFirst ... 7891011
Results 151 to 157 of 157
Thread: Dvb Viewer
  1. #151
    45 Post(s)
    @ronuquet
    Ai o singura postare plus insistenta pe PM. Licenta DVBViewer s-a ieftin acum la 20E. Cu mai ieftin de atât nici nu ieși din casă seara la o bere cu prietenii
  2. #152
    02 Feb 2021
    Licenta la DVBViewer a fost intotdeauna 20 de euro, nu inteleg despre ce ieftinire vorbesti, eu vreau doar Transedit pentru verificari de bitrate, scanare NIT pe digital si asa mai departe.
    Nu folosesc DVBViewer ca sa ma uit la TV - am Vodafone, abonamentul cu toate canalele, am decodorul Vodafone TV si un CI+ pentru televizor, deci zgarcit nu sunt.
    Daca era vorba sa ma uit la TV plateam cei 20 de euro, dar pentru verificare de bitrate si sa ma uit pe ce pozitie in LCN sunt unele canale regionale, nu mersi.
    Ah, si daca tu iesi cu tovarasii si dai pe consumatia ta 20 de euro adica 100 lei, inseamna ca bei de stingi...
    Am Transedit 4.2.1.1 luat din alta sursa. Am vazut ca Transedit 4.3 aduce urmatoarele schimbari, curioase pentru mine:
    • Added: Scanner Options: “Scan NIT, BAT and VCT for logical channel numbers” checkbox. It lets the scanner read the broadcasted NIT (Network Information Table) in case of DVB-T/C, BAT (Bouquet Association Table) in case of DVB-S or the VCT (Virtual Channel Table) in case of ATSC. The scanner displays logical channel numbers in an additional column of the Scanner Window after the scan is done.For ATSC they appear as major and minor number separated by a dot.The new columnenables to sort scan results by number. If the broadcaster does not provide logical channel numbers, the LCN field remains empty. The numbers are also written to exported INI channel lists as “LCN=x” entries. Please note that additionally reading the NIT and/ or BAT may let the scan take considerably longer (due to NIT/BAT cycle times that are mostly longer than PAT, PMT and SDT cycle times). The logical channel numbers cannot be imported inthe current DVBViewer version since it cannot handle them and ignores them in INI channel lists.
    • Added: Scanner Options: Network/Bouquet ID input line, allowing to specify a Network ID (if logical channel numbers are contained in the NIT) or Bouquet ID (if logical channel numbers are contained in the BAT), that lets the TransEdit scanner only use logical channel numbers from tables with a matching ID. The default ID 0 lets the scanner prompt for selection, if more than one kind of numbering is available (see below).
    • Added: Scanner Window: “Channel Numbering Selection” dialog. It can be opened by selecting the corresponding context menu item (or by pressing Ctrl + L) after a scan has found logical channel numbers. If more than one kind of numbering is available and no Network/Bouquet ID is set up on Settings → Scanner, the dialog opens automatically after a scan, prompting to select one of the numberings. For each the dialog displays the ID and the network/bouquet name. Ticking the “Remember LCN ID” checkbox before clicking OK lets TransEdit copy the selected ID to Settings → Scanner and save it, so that the “Channel Numbering Selection” dialog does not appear automatically after a scan anymore. However, it can still be opened manually, in order to view the available IDs and names, or to try an alternative numbering."
    De asta l-am vrut mai exact...... dar ma rog. Postare insistenta insemna sa te spammez cu mesaje. Ti-am scris un singur mesaj si atat. Cu politeturile de rigoare.
  3. #153
    Nu ai de ce sa fii supărat; la al doilea post deja critici un user vechi. De fapt primul tău post ar fi trebuit să fie un salut către membrii forumului.
  4. #154
    02 Feb 2021
    Am cerut un simplu reupload si incep sa mi se faca reprosuri nefondate, cum ca o iesire cu tovarasii nu se poate realiza fara minim 20 de euro. Putea sa spuna in privat : "nu" si gata, fara atata tevatura.
    In plus repet, insistenta in PM inseamna spam, ceea ce eu nu am facut, am dat un simplu mesaj daca se poate un simplu reupload, am fost cat se poate de politicos.
  5. #155
    Peste o lună chiar te rog sa fii politicos.
  6. #156
    DVBViewer Pro 7.1.2.1 setup
    DVBViewer_setup.exe (9.3 MB)
    https://www106.zippyshare.com/v/CMgTTkuu/file.html
  7. #157
    Change Log DVBViewer Pro 7.2.3.0
    Added: Key Tool: Possibility to create an encrypted license data backup file containing the key file content, DVBViewer password and add-on passwords. Please note that the Key Tool stores already installed license data as backup, not possibly differing data entered or edited in the Key Tool user interface. So it is necessary to install licenses before creating the backup. The Backup should be saved on an external medium like a USB drive, where it survives a PC crash, so that you don’t have to purchase the license(s) again in this case!
    Loading a license data backup with the key tool requires first entering the user name (the mail address used for ordering DVBViewer) with which the backup was created. After loading the file the Key Tool immediately re-installs the back-upped data without requiring further action.
    Change/Fix: Key Tool: Several fixes and adjustments in the Key Tool user interface, among them:
    For writing license data to your hard drive the Key Tool user interface now uses the term “Install”, not “Save” anymore, in order to avoid confusion with “Save License Backup”.
    For letting the browser show the add-on “Order” pages the Key Tool now uses HTTPS URLS, not out-dated HTTP URLs anymore.
    Deleting installed key files did not work correctly under certain circumstances.
    Removed: OSD: All games and the Alarm Timer page, assuming that nobody uses/needs it anymore. The pages can be reactivated with a tweak. Please post in the forum if there is any need for it.
    Fix: OSD Mini EPG: When using the Mini EPG for browsing through channels (requiring Options -> TV/Radio -> Browse in Mini EPG to be switched on), previously displayed EPG data was not replaced by "No EPG data available", if no EPG data for the next channel and given time was available (since 7.2.2, see here). Furthermore the bar in the Mini EPG showing the already elapsed time of the currently running program did not vanish when switching to the EPG of future or past programs with OSD Right/Left and did not show the elapsed time correctly after returning to the EPG of the currently running program (since 7.2.2, see here).
    Change: OSD Mini EPG: The time for which the EPG shall be displayed is reset to “Now” on each channel change, or to the time of the currently played program in case of timeshifted playback. Previously the last set time was kept (see here).
    Added: Radio Text:: Detection and display of radio text embedded in AAC frames, as broadcasted by the German ARD via satellite. This applies to playback of live radio and recordings in TS and .AAC format, no matter whether they have been recorded by earlier DVBViewer- and Media Server versions or converted from th broadcasted LOAS/LATM container to ADTS AAC. Please note that the used method (reading the AAC frames in reverse direction) detects almost all radio text, but may overlook parts of it in rare cases.
    Fix: TS Stream: General failure with URLs containing no path element, but an at sign (@) or colon in the query part (something like http://xxx.xxx?y=@zz:zz). They were parsed incorrectly, causing a socket error. Moreover redirections from a persistent “keep-alive” HTTP connection to an HTTPS URL with the same domain were not handled correctly.
    Removed: Channel List: Menu item “Sort by Channel Number” in the context menu of channel list representations (introduced in version 7.2.2). It didn’t prove to be useful (see here).
    Change: Channel List: After the import of M3U or INI channel lists by using the -l command line parameter (introduced in 7.2.0) DVBViewer saves its channel list automatically if it is configured as client of a Media Server on the same PC, in order to also update the channel list used by the Media Server (see here).
    Added: Channel Editor: On M3U (IPTV) channel list import the Channel Editor now adopts channel numbers from tvg-chno tags, if present. Using them for channel selection by number input requires Options → TV/Radio → Use custom channel numbers to be switched on.
    Fix: DiSEqC Editor: Display fault in the top area (see here).
    Added: Playlist Window: New “Auto-Save when DVBViewer Closes” item in the context menu. If checked this setting lets DVBViewer automatically save the current playlist to the Playlist.m3u file in the configuration folder on closing for restoring it on next start. Previously the playlist could only be saved manually.
    Change: Playlist Window: Now the Save/Reload Playlist tool buttons and context menu items are only enabled if the playlist differs from the content of the Playlist.m3u file in the configuration folder. Previously they were always enabled. The numbering of items (if switched on, see context menu) now is one-based. Previously it was zero-based.
    Fix: Playlist Window: Drag and drop of media files / folders from the Explorer into the Playlist Window did not work anymore as soon as a playlist item was selected.
    Fix: HbbTV: If a HbbTV video was playing, Playback → Playback Off did not finish the OSD HbbTV mode, so that the keyboard did not return to its normal OSD functionality and HbbTV content possibly remained on the screen.
    Change/Fix: HbbTV: Several HbbTV-related fixes and enhancements enabling to show (mostly German) HbbTV content and play HbbTV videos/streams that did not work before, for example the ARD and ZDF Replay function (see here), allowing to watch the currently running program from the beginning.
    General remark about HbbTV: Due to the generally problematic preprocessing of HbbTV content for presentation in PC browser components, and also because of out-dated third party HbbTV components, the HbbTV add-on for DVBViewer should not be expected to work flawlessly in every respect. It still works passably in German speaking countries (Germany, Austria, Switzerland). However, this can not be guaranteed for the future. In other countries the HbbTV add-on is mostly unusable.
    https://www.videohelp.com/software/DVBViewer
