Results 1 to 4 of 4
Thread: Script for checking CCcam status
    13 Feb 2007
    Earth
    Post Script for checking CCcam status
    '' This script will work on most linux dist. including enigma1/2.
    The script will check if the CCCam proccess are running with a crontab and restart CCcam if stopped for some reason.
    Make a file called checkcccam.sh and place it under /bin. chmod with 755 and paste this into the file:
    #!/bin/bash
    CCCAM_CONFIG_FILE_PATH="/etc"
    CCCAM_EXECUTABLE_PATH="/bin"
    NAME_OFF_CCCAM_EXECUTABLE="CCcam.x86"
    function Check_CCcam {
    ps -eo comm,pid,etime > tmpcat
    PID=$(grep -i $NAME_OFF_CCCAM_EXECUTABLE tmpcat | awk -F" " '{ print $2}')
    TIME=$(grep -i $NAME_OFF_CCCAM_EXECUTABLE tmpcat | awk -F" " '{ print $3}')
    Check_CCcam
    if [ "$PID" = "" ]; then
    cd $CCCAM_EXECUTABLE_PATH
    ./$NAME_OFF_CCCAM_EXECUTABLE -C $CCCAM_CONFIG_FILE_PATH/CCcam.cfg
    fi
    exit 0
    Modify the 3 lines marked with red to fit your local settings for paths and name of cccam file.
    Then make a crontab to run this script every 1 min.:
    # crontab -e
    Insert this line and save the file:
    * * * * * /bin/checkcccam.sh
    Try to kill your cccam process and check that it starts again in max. 1 min. ''
    11 Apr 2008
    Fost mebru
    Default Re: Script for checking CCcam status
    Funcţionează la cineva acest script ?
    Fost membru al acestui forum
    10 Aug 2008
    Hi
    I use Cccam 2.1.4 to DM 800 ( Orginal)with Gemini 5.0 and DreamEite 13 Image,
    can you Write a sample Instead of red setting, please?
    Best regards
    24 Jun 2009
    Hamburg
    Default script restart pt E2 folosit pe BH 1.7.9
    Daca mai are nevoie cineva de un script care sa verifice si sa dea restart la CCcam in caz in care e nevoie, eu pe BH folosesc scriptul urmator denumit ccheck.sh si plasat in
    /usr/script
    #!/bin/sh
    if ps x |grep -v grep |grep -c CCcam >/dev/null
    then
    echo "cccam... ok"
    else
    echo "cccam... restarting"
    /usr/bin/CCcam
    fi
    Se adauga liniade mai jos in fisieru root si bh.cron aflate in /etc/bhcron/
    */5 * * * * /usr/script/ccheck.sh
