Results 1 to 2 of 2
Thread: Cum pot bloca trama pe cccam?
    06 Mar 2007
    Default Cum pot bloca trama pe cccam?
    Am un dreambox 500 S cu gemini si cccam 2.011,posed un m.o.s.c si as vrea ca el sa nu mai poate primi trama , cum pot sa fac asta pe cccam.
    Multumesc de ajutor
    06 Mar 2007
    Default Re: Cum pot bloca trama pe cccam?
    Iata solutia, pentru cei ce vor sa stie cum se face:
    dans CCcam.cfg
    # configure what EMM blocker you want. Add as many as readers you have attached
    # default is blocking nothing
    # B: /dev/sci0 01
    # 00 - nothing
    # 01 - sa blocked
    # 02 - ua blocked
    # 04 - ga blocked
    #and sum of for combinations << donc pour tout bloquer il faut mettre 07
    #examples
    #B: /dev/tts/0 07
    #B: /dev/sci0 01
    # disable all local EMM readers
    # saves lots of CPU, but you won't get any updates anymore
    # (unless you get updates from your clients)
    # default: no
    #DISABLE EMM : yes
    # with this setting you can
    # allow a client on two hops away
    # to send the updates to the cardserver
    # default : no
    #EXTRA EMM LEVEL : yes bien entendu, pour que la line soit active il faut enlever le "#"
