Results 1 to 2 of 2
Thread: A aparut E2 SIFTEAM 030
    21 Post(s)
    Default A aparut E2 SIFTEAM 030
    Noutatatile mari : versiuni 900,910si 91 !!! suport CI !
    release 0.3.0:
    Now there's no more need to change bootargs, IPs will be set on Enigma2 Network Menu.
    Bootargs are changed a bit more if you do not want to set anymore IPs on bootargs. Bitwise also old bootargs will work perfectly.
    What's new:
    - support for:
    - cuberevo-mini-fta (cuberevo-200Hdt)
    - cuberevo-250HD (ipbox 91HD)
    - cuberevo-2000HD
    - cuberevo-7000HD/9500HD
    - added support for Common Interface modules (take in consideration that a CI cam will make slower Enigma2,
    this will be fixed in future. Also do not forget that to the upper slot will work with Tuner1 and lower slot with Tuner2)
    - fix for CSAT France HD Blackscreen
    - fixed randomly occuring crash on e2 exit
    - fix restarting if old timer still set
    - fixed front panel display management
    - fixed hour display
    - fixed stanby
    - fixed deepstandby
    - fixed restart GUI
    - fixed restart
    - fixed HD channels bugs
    - fixed many of the random artefacts on viewing channels
    - changed keymap.xml, now we will use the Enigma-like functions for remote controller buttons
    - updated cvs to 09022009
    - added srt subtitle support
    - added avi x264 support
    - added avi h264 support
    - added xvid 720p support
    - fixed mv id3tag
    - added wav support
    - added 2nd scart input control
    - fixed many HDMI bugs
    - fixed fast forward, fast reward
    - fixed audio track selection m2ts/vob/trp
    - added CROND and CRONTAB
    - fixed configuration Menu Network Setup (this will works only with USB and Flash version, NFS couldn't set IP for obvious reason)
    - added tun.ko module (for VPN support)
    - added/updated usb-serial converter support (pl2303, ftdi_sio)
    - added ssa subtitle
    - fixed ass subtitle
    - enabled ntfs as module
    - fix for HD skins
    - fixed mkv + h264 sync
    - implemented mp3 playback directly via http connection for plugins like last.fm
    - added filextension pls
    - fixed crash when tuner is not configured
    - fixed crash when harddisk or stick connected
    - fixed DVB subtitle position for HD skins
    - fixed crash on entry manual tuning parameters when S2 is in use
    - updated webif
    - fixed support for large file playing
    - fixed all scan problems and "No SID found in PAT" message
    - support for Unicable/SCR based system
    - many code optimizations and personalization for Cuberevo
    Tuxtxt is enabled but not yet working good on the "pressing button" recognition
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
