Results 1 to 2 of 2
Thread: Avantgarde ReelBox Series II
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Avantgarde ReelBox Series II
    Avantgarde ReelBox II available from mid-April
    HDTV-DVB Multimedia Receiver HDD DVD Recorder
    Reel Multimedia is expected to result from mid-April a new edition of his HD receiver "ReelBox published. The avant-garde ReelBox Series II Media Center, HDTV, DVB Multi Receiver, HDD & DVD Recorders and Media Servers in a single device. The box can be equipped with up to three tuners for TV reception via satellite, cable or antenna equipped. The avant-garde II will cost around 1,300 euros.
    Hard Disk Recorder with Time Shift
    For the reception of pay TV, two Common Interface slots (CI) added. The ReelBox comes standard with a 320-gigabyte hard drive that are both internally and externally expandable. As hard disk recorder can be set-top box to record the TV program and a time lag - including pause and fast forward or back - play. Automatic search timers will find the desired program in the electronic program guide (EPG) and take them on a regular basis on request.
    TV interface via remote control
    This works not only in the living room: TV broadcasts can be over a local network or over the Internet from a distance program. TV recordings using the remote control can be cut, including HDTV-cut is possible. Advertising blocks can be marked and the playback will be skipped. With the built-in DVD burner extends Filmfan of his video collection, so by advertising-free movies burned to disc and can be archived.
    Individually expandable
    A Plus ReelBox extensibility is the individual: for example, can also be a Blu-ray burners are installed. In the ReelBox operates an Intel Celeron processor with 1.86 gigahertz, which has 512 megabytes of RAM. HD-TV can be on the DVB-S2 and DVB-C cards in 576i, 576p, 720p or 1080i received. On video connections are HDMI, Scart, YUV, S-Video, composite and VGA available.
    Connections
    For audio output, three Sony / Philips Digital Interface (S / P-DIF)-interfaces, two stereo RCA jacks and six mini-jacks for analog surround sound installed. For multimedia machine, the ReelBox two Ethernet ports, four USB 2.0 ports in front and a rear, an eSATA hard drive connection, WLAN and two FireWire ports. The brand-new avant-garde ReelBox "Series II" is scheduled from mid-April at a MSRP of 1299 euros in the trade.
    ps cam scump dar interesant receptor...
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    11 May 2009
    Exclamation Re: Avantgarde ReelBox Series II
    Salut,
    Sunt incepator in ale satelitilor si cu atat mai mult in linux si toate sistemele astea. O intrebare de noob. Am abonament si receiver(Cumparat) de la Digi. M-ar interesa Reel pentru posiblitatile pe care le aresi mai ales ptr HD. Dar nu stiu daca exista pe moment o posibilitate de a imi hackui propriul card astfel incat sa-l pot folosi pe acest nou receptor, eventual alte posibilitati de a rezolva aceasta problema. Te rog daca vrei sa-mi zici si mie cam ce variante as avea. Daca exista o posibilitate o sa apelez la un profesionist. Am disperat la cat de proasta e calitatea acestei coji si a transmisiunii semnalului prin scart. Multmesc ptr orice fel de indicatii.
