Felicitari Zildan! Asteptam cu nerabdare!
E2 RSP 2.02 TDT953
In aceasta seara echipa RSP are placerea sa va anunte o noua versiune e2.
Este prima versiune e2 localizata pentru Romania.
Alegeti limba romana de la primii pasi ai instalarii.
TDT
-mkv + h264 now in sync
-implemented mp3 playback directly via http connection for plugins like last.fm
-DVDPlayer activ
-fixed load mme bug - thx 2 nit
-added Romanian language file
-Estonian language added
RSP
Romanian translation and some software changes in order to help language integration
webif by TIC 2000
RSP list, a very good list (42E-30W) by EnF70 - update from menu.
Update from menu fixed
- the partition with the label "RECORD" is automatically mounted on /hdd/movie; the other partitions are mounted in /tmp/[device]
- when mounting the HDD you can see only the valid Linux partition
- it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg) with the ip of the pc,
user and password needed to login, and the folder name you want to be mounted.
download from www.sateliti-upload.info
Ma pregateam sa instalez varianta de la AAF care tocmai a aparut cand am citit ca apare varianta RSP.O astept pe a noastra.
Multumim RSP !
astept si eu .....sa testez.
Echipa RSP asteapta sugestiile si observatiile voastre.
La instalare alegeti limba romana.
E2 RSP 2.02 TDT953
In 10 minute imaginea deja era gata de folosire.
Zap foarte rapid. Inca nu am stresat-o sa vad daca pica, nu e domeniul meu.
Sper sa nu apara prb. cand o sa-le instalez pe toate 3 variante (RSP , AAF, PKT) pe stick
Asa zi sa tot "mai fie" , daca se merge in continuare pe mai multe versiuni , poate se apropie mai repede si "versiunea finala"
Acum cei cu acest receiver nu pot spune ca nu au de unde "alege" o imagine E2 pt. receiver
Cred ca nici cei de la "dm" nu au la ora actuala , atatea versiuni de E2 pt. un receiver , nu vreau sa-i supar pe detinatorii de dm800/8000 , dar faptele vorbesc
Totul a decurs rapid la instalare, dar am doua iintrebari. Una legata de imagine : m-am trezit ca merge totul fara sa incarc emulatoare si configurari. Asa s-a dorit sau am un mixaj de imagini ? Am sters imaginea din KCC si am instalat imaginea asta. A pornit imediat SKY IT si programele de pe 1W.
A doua intrebare ar fi : are cineva probleme cu varianta barry-allen-UFS-910-5.3.7 ? Pentru ca eu la instalare pe HDD am numai probleme (a se citi erori). Abia dupa 5 incercari , eventual , pot sa pun o imagine. Am observat si altadata ca reuseam din prima cu 5.3.6 , atunci cand 5.3.7 ma exaspera.
E posibil ca 5.3.6 sa mearga bine cu HDD si 5.3.7 sa mearga bine cu stick ? Pentru ca daca am renuntat ieri la hard si am pus un stick am instalat fara probleme cu 5.3.7 ( si azi la fel imaginea 953) Sunt curios daca vi s-a intamplat si voua .
Presupun ca nu ai pus bifa la stergerea continutului partitiei (ceea ce conduce si la formatarea cu cluster de 4096 atunci cind folosesti BA 5.3.7) atunci cind dupa ce ai sters imaginea pe care o aveai intr-o partitie, si ai folosit aceeasi partitie (sau una in care ai mai avut instalata o imagine ce continea si emu si tot tacimul).
Am patit si eu, procedind dupa cum spuneam mai sus, si spre surprinderea mea, desi era imagine PKT, atunci cind apasam de 2 ori tasta BLUE obtineam panelul RSP.
Am inteles din cele ce mi le-a explicat Zildan, ca era de asteptat, stergerea imaginii "lasa" informatii ce nu ii apartin in mod direct, pe care imaginea urmatoare le foloseste.
Din pacate legat de instalarea pe HDD nu pot spune nimic, am folosit o perioada si aceasta metoda, am avut parte de manifestari care m-au facut sa revin la utilizarea memory stick. Si pentru ca folosind GPARTED am putut sa imi partitionez spatiul stick-ului in 8 partitii, imi este suficient de comod sa am mai multe imagini de unde sa pot alege si testa. Mai ales acum ca au aparut 3 intr-o zi.![]()
ceva probleme la primele porniri din cauza retelei, dar de-atunci stabila
congrats
Cateva capturi din webif ar fi interesante, mai ales cu meniurile.
Merg filmele mkv foarte bine, cu subtitrari .srt sau cu cele din container.
Acum lista de canale se poate actualiza direct din meniu.
Changelog Webif by tic2000:
2009.03.13 beta 0.008
1. Added option to sort favorites list by dragging and dropping items in list using each item handler.
2. Changed a little the layout of favorites list so it's more obvious now which zone triggers the zap command.
3. Improved the code when the favorites list is saved in the cookie.
2009.03.11 beta 0.007
1. Added option to edit timers, add a timer from an EPG item or from a channel list. This required more edits in Timer.py.
2. Created a "one-theme" index file.
2009.03.05 beta 0.006
1. Added EPG link for current service.
2. Added timer listing. Edits in Timer.py to make it work.
2009.03.03 beta 0.005
1. Fixed a bug in rsp-tools.js that threw an error if the cookieFav was not created.
2. Added streaming for the current service.
3. Starting with this version the archive is saved with the tpl folder named "default". Just extract and use.
2009.03.01 beta 0.004
1. Added media tab with movie list. You can now see the list, play, download on your pc or delete your movies.
2. Updated jQuery to 1.3.2
2009.02.28 beta 0.003
1. Added power controls
2009.02.27 beta 0.002
1. Added 2 themes that were missing from the first release
2. Added code in rsp-tools.js to check if the url_zap variable is set ("comaptibility" with newer version of TDT E2).
3. Added loading graphic so you are aware the browser is doing something in the background.
4. Added the option to make an OSD screenshot. This feature changes the file Screengrab.py which wasn't used anyway.
5. Fixed a bug that made the current service info refresh duplicate. Now the timer takes into account only the first page load. Manual or zap refresh won't create new instances of the timer.
webif folosit in RSP 2.01 TDT 855 era 0.006.
@hd56fox
In momentul cand dai in BA sa stergi o imagine ceea ce se intampla de fapt este sa stearga informatiile din BA astfel ca imaginea nu mai apare in meniu, dar restul este pe partitie. Astfel, mai ales daca ai schimbat o imaginea RSP cu alta, care foloseste aceeasi logica pentru emu, fisierele sunt acolo si el le citeste.
Am instalat si merge foarte bine. De fapt este prima varianta care dupa mai multe incercari nu se soldeaza cu trecerea la varianta clasica. Am o mica problema pe gigitv nu deschide toate programele ce o fi ? Am scanat dar apare aceiasi problema.
Problemele la scanare nu sunt inca rezolvate. Fa update la lista din meniu. Scanare iti va da rezultate negative mai mult decat pozitive.
Hi, I checked this new image. Very, very nice job, thank you. I have only one problem: this image, the new PKT and the newest AAF image do not handle the Viaccess cam in simply way.I have to go into the CI menu to activate the cam every time after power on.
So I hade to put back your TDT 884 image, that is perfect for Viaccess.
