Results 31 to 45 of 105
Thread: Sifteam Enigma 2 V0.1.0
Threaded View
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Exclamation Enigma 2 pentru 900/910/9000
    Aici e enigma 2 for 900/910!!!
    Informatii pt install sunt inaitru la readme file.
    ENIGMA 2 for ipbox HD/cuberevo/cuberevo-mini SIFTeam:
    First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
    Default settings are for single tuner on HotBird sat. (you can change them in the menu)
    WARNING: Do not forget to change your DNS configuration (if you want to use the decoder on the net). The DNS configuration could only be made by editing manually the file "/etc/resolv.conf"
    HISTORY:
    release 0.1.0(beta):
    This is the first public release, it's released as a beta version, probably it has many and many bugs, but to fix and to discover them I need all your help, so I decided to make it public
    This version does not support:
    - card reader
    - DVB-T, DVB-C, DVB-S tuners
    - twin tuner
    Enjoy it! Tideglo
    ABOUT ENIGMA 2 for ipbox9000/900/910/cuberevo/cuberevo-mini:
    This is an adaption of Enigma 2 for the DGStation's High Definition boxes.
    I want to thank these people:
    Team DuckTales: for helping me on finding really many bugs and to helping me on make Enigma2 like it is now.
    zbigzbig20: for default bootlogo
    Spaeleus: for Italian translation
    SIFTeam: this is my place, with all my friends that i like really to chat with!!!! (I LOVE YOU GUYS)
    I want also to thank two special friends:
    genge: for be the best betatester of ever!!!!! (really a ball breaker but also a good friend )
    PhotosOfGhosts: for helping me on finding, studying and solving bugs
    Regards, Tideglo
    HOW TO INSTALL:
    To test this enigma2 image you need a running nfs server and a serial & network
    connection to the receiver.
    You need uboot 1.3.1 or higher to run e2 (never tested with lower versions)
    Do this only if you want to use nfs-server otherwise go to point 3:
    1. extract the tgz file on the server and set the directory in /etc/exports
    for example:
    /root/Desktop/root 192.168.1.0/255.255.255.0(rw,no_root_squash,sync,no_subtree_ch eck)
    where 192.168.1.0 is your net base-address and 255.255.255.0 is your netmask
    2. restart nfs server
    3. connect via serial console with an hyperterminal connection to the receiver (I suggest you to use putty, it's freeware, and configure it to use a 115200 serial connection)
    4. turn on the receiver and hit ctr+z in serial console
    you should see the following prompt:
    cuberevo>
    5. customize the following settings to your network environment and type them into the
    serial console:
    setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
    setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_3 'setenv ipaddr 192.168.1.6;setenv serverip 192.168.1.1;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 bigphysarea=10240 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";seten v bootcmd "run bootusb";saveenv;boot'
    setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
    saveenv
    remember to customize where /root/Desktop/root is the directory you added to /etc/exports and ipaddr is the ip of your decoder, serverip is the ip of your nfs-server, gateway is your gateway ip, netmask is the mask of your home-net
    6. now you can restart your decoder and press the relative remote controller's button for 5 seconds to start the image you want:
    Press Button 1: start your image using nfs-server
    Press Button 2: start your image using usb pendrive if you don't have a SATA hdd
    Press Button 3: start your image using usb pendrive if you have a SATA hdd
    Press Button 4: start your original flash image in the decoder (DGStation's original firmwares and images based on them)
    That operation is necessary only the first time you want to change your boot commands. You don't need to press all the time you reboot the decoder a button to select wich image to start, simply do that only if you want to change to e2 nfs from usb, or from original images.
    That's all, Tideglo
    DOWNLOAD
    Ipbox 9000
    http://forum.sifteam.eu/downloads.php?do=file&id=3860
    Ipbox 900/910
    http://forum.sifteam.eu/downloads.php?do=file&id=3859
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
