Results 1 to 5 of 5
Thread: Special Kaon
    Standard RSP member gessle's Avatar
    tg ocna;jud. BACAU
    Exclamation Special Kaon
    you can make a full keypatch with RadiacTools:
    Use RadiacTools v3.3, the higher versions are not so good...
    Extract a keyblock:
    -open RadiacTools and go to "Blocks"
    -load the firm in the right window
    -have a look at the window with compressed blocks and click on the first data-block
    -click on "Extract Block"
    Now you have a new folder in your firm-directory.
    Open this folder and you can see the decompressed keyblock as "data".
    You can patch other firmwares with this keyblock or you can modify the block with a hexeditor.
    First comes the key, then the provider-id, then the keynumber and then the cryptsystem (I = Irdeto, S = Se*ca, V = Viaccess, C = Conax, N = Na*gravision, B = Biss, W = Cryptoworks, F = Fixed Control Word).
    You can update the keys, but you can't add new keys.
    When you add new keys by any cryptsystems, you must delete other keys.
    The size of keyblock must ever be the same.
    Before you patch a new firm with the keyblock, make sure, that the keyblock have the same size.
    You can see it in RadiacTools v3.3 by "Blocks" in the right window.
    When the block go to offset 001F30 (EMU 5.8.139), your keyblock must be not higher.
    Patch the keyblock:
    -open RadiacTools v3.3 and go to "Patches"
    -load a new firm in the left window
    -look in the window with compressed blocks at the name of the keyblock (first data-block) when you will patch onother HW
    -rename your modified keyblock
    -go to "Patches"
    -load the renamed keyblock in the right window
    -click on "Compress"
    Now you have a second file in your "data" - folder with .bin-COM.
    -load the .bin-COM - file in the right window by "Patches"
    -load the new firm in the left window by "Patches"
    -click "Patch"
    Now the firm is patched with your modified keyblock.
    You can see him by blocks in the right window.
    You can patch a clear soft only (type1).
    Compressed firm you must generate to type1 before.
    Firm in type4 (patched with KaonCDH) you can't generate with RadiacTools.
    You must patch the kaon with this firm and then you can read the software with SW Reader 21 (Hostmode: 3 x exit on kaon and mute on remote control or 3 x channel+ on kaon and mute on remote control).
    Not forget to add the header in the SW Reader!
    Then you have the firm in typ1.
    By some softs the SW Reader add the header not correct (missing a part of the SW-ID).
    You can correct this with the hexeditor.
    Sample:
    KAON0008B916C001
    B00020000000000C
    KSF-202Zx.XXXXXX
    must be changed to:
    KAON0008B916C001
    0B00020000000000
    CKSF-202Zx.XXXXX
    X
    You must past the "0" ("30" in hex) by offset 000010.
    Now the header is correct and ready for the KUP.
    Block-patches with RadiacTools ever must be in the same menu-language and the compr. block must be in the original-folder.
    You can't extract the block in french language by RadiacTools and patch him in english language.
    The same you can make with font-blocks and with language-blocks.
    You can patch every soft with the new fond from 0B.00.02 and you can change the language without KaonCDH (that's importend for soft, who already patched with KaonCDH).
    Daca s-a scris inainte ,va rog frumos sa stergeti !
    Special kaon utilities 1:
    Attached Files Attached Files
    FOCUS SAT-UPC;RCS-digital cablu;ADSL;BAYERN MUNCHEN&AC MILAN;
    .de
    Default Re: Special Kaon
    explicatia este buna inrto oare care masura (cei care au mai facut si stiu sa editeze in hexa) extragerea bootloaderului a fisierului de pache apoi rescriere acelui fisier in alt soft apoi re compimarea cu atentie sa nu depaseasca 1024 kb se face acest lucru doar in cazul in care vrem mai multe norme de codare schimbari de emmu sau limba afisajul este la fel o editare care se face cu alt program si se poate re introduce doar in hexa in soft la fel compimat...deci atentie mare si ff mult timp necesita acest lucru in final va iesi o treaba de expert
    tg ocna;jud. BACAU
    Kaon cu firm sunny si un alt mic secret au subitrare in mod corect
    .de
    incep testele
    tg ocna;jud. BACAU
    Minimanual radial tool sau niste instructiuni in limba de unde isi are originea soft-urile kaon
    -pus la upld!
    .de
