Thanks Thanks:  1
Results 1 to 15 of 20
Thread: Cum sa configuram newcs + cam
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Cum sa configuram newcs + cam
    Mai intai descarcati si instalati newcs-ul din panelul receptorului, respectiv imaginii pe care o aveti. La fel procedati si cu newcs.cfg. Acesta din urma il veti gasi in var/tuxbox/config.
    Acest fisier va trebui sa-l editati in functie de cerintele dorite. Va recomand pentru editarea lui notepad ++. Nu folositi notepadul din windows, deoarece vor aparea probleme.
    Vom folosi ca exemplu newcs.cfg de mai jos.
    <newCSconfig>
    <readers name="SCI">
    <device>
    <name>Lower Cardreader</name>
    <type>sci</type>
    <mhz>357</mhz>
    <node>/dev/sci0</node>
    <parity>odd</parity>
    <reset>normal</reset>
    <export>Yes</export>
    <enabled>Yes</enabled>
    <blocksa>No</blocksa>
    <blockua>No</blockua>
    <blockga>No</blockga>
    <!-- <boxkey>0000000000</boxkey> -->
    <!-- <rsa>0000000000</rsa> -->
    <irdeto-camkey>0000000000000000</irdeto-camkey>
    <irdeto-camkey-data>00000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​0000000000000000000</irdeto-camkey-data>
    <crypto-special>No</crypto-special>
    <ipk>00000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​0000000000000000000</ipk>
    <ucpk>00000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​ 00000000000000000000000000000000000000000000000000000000000000000000000000000000 ​0000000000000000000</ucpk>
    <PTShandshake>No</PTShandshake>
    <carddetect>yes</carddetect>
    <newcamd_port>34000</newcamd_port>
    <autosid>Yes</autosid>
    <Seca-PPV>no</Seca-PPV>
    <pincode>0000</pincode>
    <priority>round</priority>
    </device>
    <device>
    <name>Upper Cardreader</name>
    <type>sci</type>
    <mhz>357</mhz>
    <node>/dev/sci1</node>
    <newcamd_port>34001</newcamd_port>
    </device>
    </readers>
    <radegastserver>
    <enabled>No</enabled>
    <port>16000</port>
    <allow>
    <hostname>localhost</hostname>
    </allow>
    </radegastserver>
    <cache>
    <emm>20</emm>
    <ecm>-1</ecm>
    </cache>
    <debug>
    <password>NewCSpwd</password>
    <level>normal</level>
    <type>init</type>
    <output>console,tcp</output>
    <console_options>normal,init</console_options>
    <tcp_port>1001</tcp_port>
    <tcp_options>normal,init</tcp_options>
    </debug>
    <newcamdserver>
    <name>newcs</name>
    <user>
    <name>user1</name>
    <password>user1</password>
    <port>34000</port>
    <au>on</au>
    <sidoverride>off</sidoverride>
    <spider>No</spider>
    <allow>lower</allow>
    <rate>2</rate>
    </user>
    <user>
    <name>user2</name>
    <password>user2</password>
    <port>34001</port>
    <au>on</au>
    <spider>No</spider>
    <allow>Upper</allow>
    <rate>2</rate>
    </user>
    <user>
    <name>peer1</name>
    <password>peer1</password>
    <port>34000</port>
    <au>on</au>
    <spider>No</spider>
    <rate>2</rate>
    </user>
    <user>
    <name>peer2</name>
    <password>peer2</password>
    <port>34001</port>
    <au>on</au>
    <spider>No</spider>
    <rate>2</rate>
    </user>
    </newcamdserver>
    </newCSconfig>
    In cazul de fata avem un confing pentru cititorul de jos si de sus al receiverului (dreambox 7xxx sau ipbox 4xx/9xxx, acelasi cfg poate fi folosit si pentru dm 500, 600, 800, ipbox 2xx, 3xx, 91, 9xx - doar ca vom folosi numai configurarea slotului de jos)
    Portul alocat pentru slotul de sus este 34000, iar pentru cel de jos 34001. Aceste porturi pot fi schimbate cu oricare altul dorit.
    Le gasiti la randul:
    Lower card reader port: <newcamd_port>34000</newcamd_port>
    Upper card reader port: <newcamd_port>34001</newcamd_port>
    Userul 1 si 2 sunt folositi pentru propriul dumneavoastra cont. Userul 1 pentru a citi cardul de sus iar 2 pentru cel de jos. In majoritatea cazurilor de instalare, parola predefinita va fi dummy dummy. Va recomand sa schimbati aceasta parola, deoarece poate fi usor ghicita de cineva. Am s-o inlocuiesc si eu cu user1 user1, pentru readerul de jos si user2 user2 pentru cel de sus.
    Liniile de newcs, pot fi folosite de oricine, asa ca mare atentie cui incredintati o astfel de linie.
    Asadar in primul rand schimbati userul si parola, in cazul de fata dummy dummy cu orice alt user si pas pe care il doriti.
    Userul 1 si 2 sunt creati pentru a face legatura cu Cam-ul dorit ( gbox, mbox, mgcamd, cccam, incubus, etc). Mai jos am sa va dau cateva exemple de cum sa creati linii pentru cam-ul intern folosit. Spre exemplu pentru :
    Cccam:
    Pentru user1 linia va fi de genul
    N: dreamboxlan ip 34000 user1 user1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    Iar pentru userul2
    N: dreamboxlan ip 34001 user2 user2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    ex dreambox lan ip: 127.0.0.1
    Pentru mgcamd/newcamd cele doua linii for fi de genul
    CWS= dreamboxlan ip 34000 user1 user1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    CWS= dreamboxlan ip 34001 user2 user2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    Pentru cwshare-ul de mbox:
    C: { dreamboxlan ip 34000 user1 user1 01 02 03 04 05 06 07 08 09 10 11 12 13 14 }
    C: { dreamboxlan ip 34001 user2 user2 01 02 03 04 05 06 07 08 09 10 11 12 13 14 }
    Dupa ce ati trecut aceste linii, salvati cfg-ul cam-lui respectiv si dati restart la cam. Ex cccam+newcs, mbox+newcs, etc
    Pentru a da mai depare liniile N, unui peers este nevoie ca mai intai sa deschideti din ruter porturile respective (34000 si 34001) si dati liniile dumneavoastra de forma: ( am luat ca ex peer1 si peer2)
    N: yourdns 34000 peer1 peer1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    N: yourdns 34001 peer2 peer2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    yourdns= hostul vostru ex: cccam.no-ip.org
    Atentie: aceste linii nu sunt pentru configul vostru. Ele vor fi date spre a fi trecute in cfg-ul partenerului
    Semnificatia liniei:
    <rate>2</rate>
    Valoarea rate inseamna de cate ori intr-un minut este permis ECM-ul. Multe carduri nu merg cu valoarea 2. Daca observati freezuri sau blocari, cresteti valoare progresiv. Unele carduri merg bine pe rate 4. Cel mai bine e sa-l lasati pe 0.
    <mhz>357<
    Frecventa la care este citit cardul. 357 in cazul de fata
    o linie foarte importanta, seteaza nod-ul de acces al cititorului in cazul de fata pentru readerul de jos
    cel de sus
    <node>COM1</node>
    cand interfata este conectat la un pc
    <node>/dev/tts/0</node>
    pentru interfata seriala, etc
    <boxkey>000000</boxkey>
    se va trece bk (nds sau nagra)
    <rsa>0000000</rsa>
    rsa-ul ( bk si rsa obligatoriu pentru cei cu carduri n)
    cei care folositi carduri m2+ eliminati aceasta linie
    in newcs.cfg poate fi introdusa si urmatoarea configurare:
    <httpd>
    <server> <!-- Port to accept connections on -->
    <port>8080</port>
    <enabled>yes</enabled>
    </server>
    <user>
    <!-- valid value for userfile are:
    Any username you'd like - Used for browser to logon (its case sensitive). -->
    <name>newcs</name>
    <!-- valid value for password are:
    Any password you'd like - Used for browser to logon (its case sensitive). -->
    <password>newcs</password>
    <!-- valid value for accesslevel are:
    admin, stats - Define what rights the user has in the web-console -->
    <accesslevel>admin</accesslevel>
    </user>
    </httpd>
    acest lucru usureaza mult munca celor incepatori si mai ales nu necesita restartul cam-lui cand adaugati un user nou
    mai exact, va permite configurarea newcs.cfg prin intermediua interfatei web
    logarea se face in felul urmator:
    http://ipdream:8080
    8080 este portul ales in cazul de fata, puteti sa-l inlocuiti cu oricare al port
    parola este newcs, userul newcs ( schimbati cu orice doriti)
    dupa ce v-ati logat mergeti la
    menage user
    la user treceti userul dorit, la parola -parola ( ex: geo dan )si dati add.
    dati acces la au, doar serverului dvs, in rest nu
    userul care il creati asa, va da acces la ambele porturi
    astfel daca doriti sa-i dati un peer acces ii veti da liniile de genul
    N: yourdns 34000 geo dan 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    N: yourdns 34001 geo dan 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    Toate liniile de newcs pe care le dati au valoare maxima de reshare 7
    pentru a da in reshare 2 treceti la finalul liniei 1 2 (multumiri rom3o)
    N: yourdns 34001 geo dan 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 2
    Dar atentie, doar daca peer-ul va este prieten, este posibil sa respecte acest lucru, daca va sterge terminatia 1 2, reshareul va trece pe 7 din nou
    Ma opresc momentan aici, am sa revin pe parcurs cu noi completari si invit si alti membri ai forumului sa o faca
    09 Feb 2007
    Bucharest
    Default Re: Cum sa configuram newcs + cam
    Daca avem primita o linie N de genul:
    N: xxx.no-ip.org 34001 geo dan 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    care este pusa in CCCam, cum o Re-shareuim mai departe?
    Se face automat prin trimiterea catre peersi a liniei C proprii, sau trebuie pus si un Server de Newcs si ceva setari suplimentare?
    05 Jan 2007
    cand primesti o linie de genul acesta, o treci doar un cccam.cfg
    linia vine cu reshare 7
    12 Nov 2009
    in cazul dolce - trebuie convertit tot in hexa ?
    trebuie sa aiba 6 caractere?
    se mai adauga vreun 0 in fata daca am numai 5?
    este acelasi din cccam?
    29 Nov 2008
    Cu capu' in nori
    In cazul Dolce dupa transformarea in hexa obtii 7 caractere (cifre+litere) la care mai adaugi un 0 in fata.
    Standard RSP member potty's Avatar
    23 Dec 2008
    cu receptorul primit acu 2-3 luni obtineam 8 caractere in hex .. si functioneaza
