Results 1 to 15 of 16
Thread: Mbox Control Center
    Default Mbox Control Center
    Mbox Control Center V1.0 Beta 2.7
    - add G-line in test peer
    - add stat.info
    - change tabs to multirow when to small screen
    - add Czech language
    please backup your files BEFORE you use MCC !!!
    http://www.upload-drive.com/7944/MboxCC_Setup_rar
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Re: Mbox Control Center
    Mbox Control Center V1.0 Beta 2.8
    - add the new stat.info format.
    - some small bugfix ( Trace peer right mouse click in main menu, check for to big window size)
    http://www.upload-drive.com/8857/MboxCC_Setup_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Mbox Control Center V1.0 Beta 3.1b
    - fix no msms.log in Local mode
    - fix copy to clipboard Inbox/Status
    Mbox Control Center V1.0 Beta 3.1a
    - fix reload bug
    - change login telnet only when you go to the tab telnet
    - add Msms inbox ( from Mbox beta V0.5 build 0015 )
    - fixed show local card ( from Mbox beta V0.5 build 0014 )
    - fixed cart count
    - change Trace color messages to new debug text
    - update spanish language
    - add Italiano language
    - store the value of checkboxes (Hide Double, Auto Reload, EcmPid)
    - add Boxid, DNS/IP and Dist. to ECM info ( only if found in share.info )
    Note: You can only sent one message in one minute.
    You can only send Msms to peers in cwshare (download first cwshare.cfg to load the peer list)
    To hide the Email picture just click on it.
    http://www.sateliti-upload.info//ind...tory=Emu/Mbox&
    Mbox Control Center V1.0 Beta 3.2
    - fix show local card with COM port
    - change Msms to new protocol to fix chirilic chars
    - new ident.info (you need to delete the old first before install MCC)
    - fixed no scrollbar when coming from minimized
    http://www.sateliti-upload.info/inde...tory=Emu/Mbox&
    Link rezolvat!
    25 Jul 2007
    Netherland
    asta ultim e 3.1b nu 3.2
    Mbox Control Center V1.0 Beta 3.2c
    - add color orange for local card on different box ( C-line with same Boxid and Dist 2)
    - add CTRL+f for mbox.cfg and cwshare.cfg in editor ( focus to Find textbox )
    - sort msms drop down alphabetically
    - add new info wait screen
    - add show global_sc.info (because not all cards are shown correct)
    - add Caid to ignore.list
    - add Y-line to cwshare.cfg
    - add right mouse click in grid select cell
    - several small fixes
    11 Apr 2008
    Fost mebru
    Default Mbox Control Center V1.0 Beta 3.6
    add French languages
    - changed languages routine (fix wrong language when new was added)
    - changed profile selection from static to dynamic.
    Now you can add so manny profiles if you like.
    - add delete profile
    NOTE: the config file is changed so you will lost all settings !!!
    You need to config MCC complete new.(only this time)
    All values will be set to default (english)
    Download
    Fost membru al acestui forum
    Standard RSP member saturn's Avatar
    28 Feb 2009
    Mbox Control Center V1.0 Beta 3.7
    - add oldnewcs connection
    - add "Intruder Alert" filter for Trace
    - add Finnish language
    - fix for share.info "index out of range"
    - fix cosmetic bug in Peerstatus grid
    - fix Y-line Boxid
    Download:
    http://www.2shared.com/file/5808018/...xCC_Setup.html
    13 Feb 2007
    Am pus aceasta versiune si i-mi face fite... la accesarea Newcs nu mai vede cardul local
    am revenit la versiunea anterioara si este ok, astept urmatoarea versiune
    Respect
    02 Feb 2007
    Mbox Control Center V1.0 Beta 3.8
    - add save button and CTRL+S for save mbox.cfg, cwshare.cfg and file-editor to disk
    - add open button and CTRL+O for open mbox.cfg, cwshare.cfg and file-editor from disk
    - add CTRL+G for download mbox.cfg, cwshare.cfg and file-editor
    - add CTRL+P for upload mbox.cfg, cwshare.cfg and file-editor
    - small fix for Telnet window
    http://www.upload-drive.com/23736/MboxCC_Setup_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    28 Feb 2009
    Mbox Control Center V1.0 Beta 4.0
    - bug fix for MultiTrace and Trace peer filter
    - store the MultiTrace screen format and size.
    - add copy MultiTrace text
    - add MultiTrace filters for each screen
    - add settings for startup Multitrace screen (numbers of screen to open, Tile vertical or horizontal)
    - auto arrange screens while resizing in MultiTrace (what is set on startup)
    Download:
    http://www.2shared.com/file/6131631/...xCC_Setup.html
    28 Feb 2009
    Mbox Control Center V1.0 Beta 4.1
    - bug fix for MultiTrace and Trace peer filter (again)
    - bug fix closing dropdownlist in Trace1 (multitrace)
    - bug fix filling peer selection list in multitrace (screen with focus will fill selection peer box when reload or download share.onl)
    - bug fix Newcs trace for Newcs version 1.66
    NOTE: there is still a little bug when tracing with peer filter when sending more ecm's (after zap)
    Then CW and boxid is not shown the first time.
    Download:
    http://www.2shared.com/file/6140597/...xCC_Setup.html
    28 Feb 2009
    Mbox Control Center V1.0 Beta 4.3
    - add SFTP for read msms
    - add delete message on box/server after download (only FTP and Local)
    - reset timer send next msms after profile change
    - goto tab msms when click on Email picture
    - delete msms on pc when right mouse click on selectionbox or textbox
    Mbox Control Center V1.0 Beta 4.2 updates
    - small bug fix for resizing multitrace windows
    - add "Hello off" color red in Trace
    - add AutoReload set time by user (min 10 sec.)
    - add new Msms system (from Mbox V0.6 build 0001)
    NOTE: Msms is still not ready, need more time.
    But know you can read the messages for FTP and Local mode.
    Download:
    http://www.2shared.com/file/6214726/...xCC_Setup.html
    DM800 + DM3800 + Inverto + ceva offset alb + CCCam
    28 Feb 2009
    Mbox Control Center V1.0 Beta 4.3a
    few changes
    Download:
    http://www.2shared.com/file/6228806/...xCC_Setup.html
    28 Feb 2009
    Mbox Control Center V1.0 Beta 4.4
    - get rid of the winsock and replaced it with net.sockets
    This is for Trace, Multi-Trace and NewCS logger.
    Download:
    http://www.2shared.com/file/6381038/...xCC_Setup.html
