Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: Probleme mbox
  1. #31
    Membru de onoare
    08 Apr 2007
    Default Re: Probleme mbox
    Poate in cazul Max ai dreptate,nu am zis nu.In cazul digi nu ma ajutau deloc.
    Pana la urma am pus totusi newcs 1.65 iar:
    Server uptime 00d 02:00:14
    [ 13:40:17 ] [ Loader ] Reinit card with caid 1801
    [ 13:40:17 ] [ Sci ] Closing device /dev/sci0 [Handle=6]
    [ 13:40:17 ] [ Loader ] Reader type 5 on node /dev/sci0
    [ 13:40:17 ] [ Sci ] Closing device /dev/sci0 [Handle=-1]
    [ 13:40:17 ] [ Sci ] Opening device /dev/sci0
    [ 13:40:17 ] [ Sci ] resetting card now
    [ 13:40:17 ] [ Sci ] Reset
    [ 13:40:17 ] [ Sci ] Card reset
    [ 13:40:19 ] [ ATR ] T=1 1etu=32.00us Guardtime:11etu CWT:139etu BWT:15371etu WWT:153600etu
    [ 13:40:19 ] [ ATR ] Historical bytes: D N A S P 1 4 2 R e v G 0 2
    [ 13:40:19 ] [ Loader ] Init Nagra card
    [ 13:40:19 ] [ KeymaN ] Adding key 0000004cexxxx type 0 on Provider 000000 for caid 1800 ID=0
    [ 13:40:19 ] [ KeymaN ] Adding key 0000004cexxxx type 1 on Provider 000000 for caid 1801 ID=0
    [ 13:40:19 ] [ Nagra ] using rsa key from config.
    [ 13:40:20 ] [ Loader ] Card 1801 on port /dev/sci0 ready
    Nu am modificat nimic altceva decat newcs.ppc pe Dream 600.
  2. #32
    Standard RSP member ovidiumarius's Avatar
    30 Mar 2007
    Si apropos la fel de bine poti folosi in port.list linii E iar in newcs.xml sid-urile.
    Doar setand sid-urile cardul functioneaza ok in newcs fara sa dea reset. Fiind mapate sid-urile acolo cardul functioneaza la parametrii optimi nefiind solicitat aiurea.
  3. #33
    Membru de onoare
    08 Apr 2007
    Bine,dar era vorba de problemele care le am cu newcs 1.65.
    Cu newcs 1.62 dupa 13 ore era asa:
    Cu newcs 1.65 dupa 3 ore aveam 9 reseturi:
    Bad ecm sunt oricum pe zero si reseturile apar doar cu 1.65,merge foarte bine cu 1.62,1.66 si 1.67.
