Results 1 to 2 of 2
Thread: How to Setup Motor in Enigma2
    13 Feb 2007
    Earth
    Post How to Setup Motor in Enigma2
    How to Setup Motor in Enigma2 by Ghost from DMM
    Photos by The LT TEAM
    When you select in the Tuner Setup " Simple -> Rotor " the rotor is running in USALS Mode.. and dont use stored positions.
    When you like to use stored positions you must select "Advanced" in the Tuner Setup. Then go to the Satellite Line and select one satellite you like to setup for rotor use. Then change the "LNB not available" to LNB1,
    change DiSEqC Mode to 1.2, change Committed and Uncommitted Command to None.
    Now change "Use USALS for this satellite" to No.
    Now you see a new line with "stored position" here you can setup the stored position number in rotor.
    For each other Satellite you like to use you now only must change the LNB to LNB 1,
    set "Use USALS for this satellite to "No" and set the correct stored rotor position. You need to ush OK to store your changes for each satellite.
    O zi frumoasa! Snow's Avatar
    Default Re: How to Setup Motor in Enigma2
