File Name: mbox 0.4 PRE BETA build 0020
File Submitter: mower
File Submitted: 2 Feb 2009
File Category: MBOX EMU
-TCP peers/connection (TCP0/TCP1 in cwshare.cfg) now works only with mbox peers!
-Mbox peers will have 1.00 as version number.
-Mbox peers now must be in G line in cwshare.cfg,D line stay for old gboxx peers.
-Added R option in mbox.cfg.
-Added J option in mbox.cfg. You can change J option with add.data at any time.
-Added A option in mbox.cfg , needed for QBoxHD receivers.
-Added back gboxx connection/protocol.Gboxx peers cant connect to mbox peers and vice versa!!!!
-Mbox now starts as deamon(background process).
-Fixed HD channels.
-Fixed problem with duplicate boxids, now mbox keep only boxid that has lower distance.
-Added support for AzBOX receivers(binary-> mbox_module).Dont expect mbox to work as should, because current API for AzboX receivers has restrictions regarding ECM "pids" streaming.
-Fix problem connecting to old mbox 016-019 versions.
-Fix problem with stack
-Fix problem with sending good ECM message to mbox ver. 0016-0019.
-Added H option in mbox.cfg for mapping provids.
-Few changes in code for local card priority, H option in cwshare.cfg.Now local card priority should work ok.
-Added code to check if same ECM is allready in ECM buffer for local card decoding over newcs.
-Fix problem not setting CA pids after channel change for devices that use dvb api.Screen stay black.
-Fix problem sometimes mbox start hitting cached CW for same ECM all the time.Now it should be okey.
-Fix problem black screen if first DCW is from cache for devices that use dvb api.
-Added mbox.prio file for adding priority system selection.Put the file in "K line-mbox.cfg" path directory.If no dcw arrived after several ECM send, mbox will reread PMT without using priority list.
