Dislikes:
- Rep Power
- 82
IPBOX 91 **ABCOM firmware**
Aici o sa gasiti firmware pt ipbox 91HD.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- Rep Power
- 82
ABCOM r8873 91HD
AB release r8873: ( 23/Jan/2009)
1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
press once FF or REW button, the interval is 10 seconds.
press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
2. Add Scan option on Channel Scan Menu
When there is no channel list, all these options create with the same result.
- Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
- Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
- Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
3. Add USB upgrade menu
- Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
it is useful for software upgrade with USB morory stick.
4. Fixed EPG contents Display
- inserted new line on the screen for EPG and extended EPG information as well
5. Fixed DVB subtitle - color table
6. Fixed OSD teletext - some old data not updated occassionally
7. Fixed wrong duration with the file after schedule recording with EPG
8. Fixed Local time auto update
- When the last channel time of the Satellite is different from the STB time within 10 minutes,
the STB time is automatically adjusted with the Satellite time during the STB booting.
9. Upgrade setting
10. Updated Web-interface
11. Fixed small bugs
12. Support *.mkv with video player.
- If the file needs higher class CODEC, the file will not be playback with video player .
- In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
13. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
14. Fixed some bug for schedule recording.
15. Fixed record subtitle.
16. Added "post-descrambling with CAM" function on system settings menu
: When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
and then you can descramble the recorded file later.
- The channel in record cannot be watchable.
- The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
- even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
(Caution)
The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
If descrambling is not running, it is impossible to do the file descrambling anymore
or able to damage the smartcard since the smartcard has already been updated.
17. Added HUB function for USB host.
18. Fixed record programs with DVB subtitle.
19. Support adjust LipSync using page up/down buttons in Videoplayer
20. Support NFS function for Linux System in Mount manager
- changed NFS config in /etc/exports
ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
- Removed the firewall of system
- Removed the firewall of IP table when your system is Fedora
# iptables -F
21. Support displays elapsing time on banner of MP3 player
22. Support Sort function on TMP folder in Recorded files menu
23. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
24. Updated language table for Slovak, Bulgarian, Polish and Russian
25. Fixed DVB EPG bug for HB13 10891
26. Fixed elapsing time error when schedule recording.
27. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
28. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
29. Added WSS function through SCART
30. RED BUTTON - stretch picture to full screen if 16:9 movie broadcast in 4:3 mode with black in all sides (Without 91HD)
31. YELLOW BUTTON - direct start of fav PiP plugin (Without 91HD)
32. Installed plugins - bitrate, Fav PiP, e-mail, weather, Shoutcast, pong, Sudoku, Tetris, HDD temp.
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
no audio with such as Digifilm channel
adjust color table of DVB subtitle for some channels
http://www.upload-drive.com/7598/AB_...all_noboot_zip
Addon version 230109 for AB Image
Remove Red button for key update, You can update keys only from webinterface.
Upgrade Newcs 1.65 version
For upgrade read instruction in Beginners guide for AB IPBox HD series on this website.
http://www.upload-drive.com/7599/add...sh4_230109_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- Rep Power
- 82
ABCOM r9057 91HD
AB (DGS based)release r9057: ( 10/Mar/2009)
1. Fixed Astra 23,5E, TP 11876, 11992 PANIC problen
2. Added additional channel scan options for TV or Radio
3. Added repeat function in Video Player
4. Added navigation method for TTXT sub-channel
5. Display the summary when searching channel
6. Save the name of recorded file when user want to schedule in EPG
7. Fixed bug Toptext navigation with TTXT
8. Fixed bug which was AB IPBox 91HD and 910HD were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins .
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.(this function will be back in next versions)
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
Images marked as "DRE" are especialy for DRE CAM modules use. If you don´t have this CAM, don´t use "DRE" version !
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
3. This image include sci.ko and smart_core.ko
known issues :
USALS doesn´t initialized correctly after box crashed
http://www.sateliti-upload.info/inde...x/Ipbox%2091hd&
AB IPBox HD/91HD_Images - unofficial/SF update for AB Images/SF_addon_for_91ABr9057.zip
SF addon for AB r9057 image
installation:
First update new image version r9057.
Unzip file, rename to "usb_update.img"
Use usb stick or flash tools for update. Is it same as image update
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
ABCOM r9057b 91HD
AB (DGS based)release r9057b: ( 13/Mar/2009)
Bud fixed:
- doesn´t work webinterface
Add
- New Slovak language
- New Romanian language
Note:
If you use AB r9057, you can install only usb_kernel_root version without chage your settings.
AB_91HD_r9057b_130309_usb_all_noboot.zip
AB_91HD_r9057b_130309_usb_kernel_root.zip
- Rep Power
- 82
ABCOM r9580
AB release r9580: ( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 91HD in filebrowser
6. Change HDD clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update TP information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://www.upload-drive.com/file/69/...oboot-zip.html
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
