Page 1 of 5 12345 LastLast
Results 1 to 15 of 72
Thread: dolce pe cccam
    Default dolce pe cccam
    Salut,
    Astazi am facut un abonament la Dolce si vreau sa trec de pe gbox pe cccam . I-as ramane indatorat celui care ma va ajuta sa fac setarile...
    O zi buna si sper intr-un ajutor imediat.
    P.S. Putem sa vorbim si pe messenger daca imi lasi in pm id-ul tau
    Default Re: dolce pe cccam
    SERVER LISTEN PORT : 12000
    WEBINFO LISTEN PORT : 16001
    WEBINFO USERNAME : root
    WEBINFO PASSWORD : dreambox
    AU = yes
    #SMARTCARD CLOCK FREQUENCY: /dev/ttyS3 8000000
    CAID PRIO FILE : /var/etc/CCcam.prio
    PROVIDERINFO FILE : /var/etc/CCcam.providers
    CHANNELINFO FILE : /var/etc/CCcam.channelinfo
    DISABLE EMM : yes
    B: /dev/sci0 00
    B: /dev/sci1 00
    BOXKEY: /dev/sc0 boxkey
    #PHOENIX READER PATH : /dev/tts/0
    CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
    CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
    CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
    CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    #CAMDATA: /dev/tts/0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SOFTKEY FILE : /var/keys/SoftCam.Key
    AUTOROLL FILE : /var/keys/AutoRoll.Key
    STATIC CW FILE : /var/keys/constant.cw
    SMARTCARD CLOCK FREQUENCY: /dev/sci0  8000000
    SMARTCARD CLOCK FREQUENCY: /dev/sci1  6000000
    TRY ALL CHIDS : /dev/sci0
    SMARTCARD CLOCK FREQUENCY: /dev/tts/0 8000000
    #TRY ALL CHIDS : /dev/tts/0
    TRY ALL CHIDS : /dev/sci1
    la boxkey faci in felul urmator se iau ultilele 10 cifre de pe conserva se pin doar 9 in calclatorul de la pc ex: 182377xxxy
    in calculator pui doar 9 adica fara "y" si dai transformare in hexa vei optine 7 litere,cifre la care adaugi in fata un "0"zero
    asta ar fi configuratia cccam pe care o descarci dp server din adoons inlocuiesti in CCcam.cfg ceea ce e mai sus in cazul in care folosesti si o interfata phonix stergi "#"
    Standard RSP member teqi's Avatar
    04 Feb 2007
    MURES
    merg si xxx pe cccam pina la urma se poate
    43 Post(s)
    Face si reshare ?...ca la mine nu se vede!
    04 Feb 2007
    MURES
    face si reshare si fara pincode
    43 Post(s)
    Vreo promotie probabil !!!
    dMd
    Guest
    @teqi
    Deci cu un abonament oficial la Dolce poti decoda canalele XXX pe alt receptor decat pe cel de la ei ?? ... pai daca da, da si tu detalii.
    @gobi2000
    In CCcam.cfg daca nu se stie frecventa de lucru a cardului mai bine nu o setezi, asta pt a nu praji cardul.
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 8000000 -- pt un card NDS 800 este cam mare dupa parerea mea, dar fiecare face cum doreste.
    21 Apr 2007
    Here
    Respecte!
    Aici sunt setari ptr cateva cadruri la:"SMARTCARD CLOCK FREQUENCY":
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 8200000 (irdeto 0.195 to 0.1370)
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5250000 ( nds ECM 0.210 DOWN TO 0.191
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 5300000 ( Sky uk 0.191 DOWN TO 0.172
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5600000 (Digialb conax 0.275 down to 0.178
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 8300000 ( BULSAT IREDETO 2 PURPLE 0.215 DOWN TO 0.151
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 8420000 ( SHOWTIME IREDETO 2 0.225 DOWN TO 0.141
    Sper ca au fost cat de cat de ajutor ptr.voi.
    Bafta!
    Respect!
    23 Jun 2008
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 6000000 ( nds ECM 0.210 DOWN TO 0.180)
    dar nu vo recomand daca sunteti slabi de inima sau dat reshare la 100.
    灌水 expression's Avatar
    09 Oct 2008
    PL-RO
    Am un server CCcam 2.0.9 cu card local Dolce in DM500(clona), Gemini 4.60
    Din cand in cand absolut aleator, desi programul pe care ma uit e din pachetul dolce si se poate decoda de pe card, el incepe sa decodeze din share. In acel moment apare un freeze. Trebuie sa comut pe un alt program si poi sa revin ca sa inceapa sa decodeze din nou de pe cardul local. A mai patit cineva asta? Existea vreo solutie de a remedia? Si pe 2.0.10 face la fel, iar 2.0.11 imi blocheaza dream-ul zilnic, deci prefer sa raman la 2.0.9
    Merci in avans.
    13 Feb 2007
    Earth
    Post Re: dolce pe cccam
    salut, o solutie , redu numarul celor la care dai cardul tau local . bafta .
    27 Mar 2007
    Eu nu cred ca are legatura cu numarul de peer. Eu am 1-2 peer activi cel mult...si unele canale le deschide din share cateodata. Si asta cu orice versiune de la 2.04 in sus. Acum folosesc newcs+mpcs+Ccam dar tot mai apare aceasta problema..e drept ca mai rar decat daca nu folosesc mpcs.
    Standard RSP member optimus's Avatar
    Timisoara
    Confirm ca merg programele xxx de la Dolce pe Cccam.
    Make it so number one!
    Standard RSP member sosozah's Avatar
    09 Mar 2008
    Si la mine se vad in share, dar local nu le deschide, desi le am in abonament.
    Standard RSP member dorinelu's Avatar
    11 Jan 2009
    Berlin
    incearca sa pui imaginea PLI cu cccam, e cea mia stabila si cea mai rapida, merge super, schimbul intre local si remote se face in scurt timp si merge brici
    Never settle for less than perfection. Never!
