Results 1 to 3 of 3
Thread: HDD in your 5620
    13 Feb 2007
    Earth
    Post HDD in your 5620
    HDD in your 5620
    Being a poor 5620 owner, I use the following method for recording on pc and playback (found to be better than other methods like mtuxvision and mgrab). I tried it with Gemini1.04. :-
    In PC
    (1) Create another user dream with username and passwd both dream.
    (2) Create shared directory c:\dreambox\movie
    (3) Download and install VLC player. Link .mpg and .ts files to VLC player.
    In DB
    (4) Download plugin CIFS. (included in Gemini 3.1)
    (5) In expert settings-comm-blue button-select the following (See Attachment 'CIFS Howto' for more help).
    PC ip
    CIFS
    Dir-dreambox
    local dir -hdd (if that doesn't work try /mnt/hdd)
    dream
    dream
    RW
    tick "automount"
    leave the rest
    Mount.
    To record
    (6) Video button followed by Radio button.
    To stop recording, press TV button.
    To see timer menu press Radio button again.
    To watch on TV
    (7) Dream-File mode-root-hdd-movie - select file OK.
    Hope it works for you. Regards, pcd.
    editat de Snow
    Savin nu uita ca suntem un forum romanesc, este util ce postezi dar ar fi si mai bine daca le-ai posta direct in romana. Multumesc!
    Sarbatori fericite!
    Standard RSP member valeriu's Avatar
    20 Apr 2007
    Default Re: HDD in your 5620
    HDD-vă in 5620
    Am utilizat următoarea metodă pentru inregistrarea şi redarea de pe PC (pentru a fi găsit mai bine decat alte metode ca mtuxvision şi mgrab). Am incercat-o cu Gemini1.04. : --
    In PC-ul
    (1) Creaţi un alt utilizator de vis cu nume de utilizator şi passwd atat de vis.
    (2) Creaţi directorul partajat c: \ dreambox \ film
    (3) Descărcaţi şi instalaţi VLC player. De link-uri. Mpg şi. TS fişiere la VLC player.
    In DB
    (4) Descarca CIFS plug-in-ul. (incluse in Gemeni 3.1)
    (5) In expert setările de-a Comitetului de-albastru-buton selectaţi următoarele (a se vedea Atasament-CIFS Modalitatea de "ajutor pentru mai multe).
    PC-ul de IP a
    CIFS
    DRI-dreambox
    HDD-dir locale (in cazul in care nu funcţionează, incercaţi / mnt / hdd)
    visa
    visa
    RW
    bifaţi "automount"
    Mount.
    Pentru a inregistra
    (6), urmat de butonul de video buton radio.
    Pentru a opri inregistrarea, apăsaţi butonul de TV.
    Pentru a vedea meniul de timp apăsaţi butonul radio din nou.
    Pentru a urmări la TV
    (7) vis-Mod de fişiere rădăcină-hdd-film-- fişier, selectaţi OK.
    Sper că lucrează pentru tine. Cu respect, PCD
    Mi-am facut putin timp si aici e contributia mea pt acest Forum.
    Craciun Fericit.
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Cu multumiri valeriu! Craciun fericit!
