Page 1 of 4 1234 LastLast
Results 1 to 15 of 56
Thread: e2 RSP beta 1.0 TDT 600 by ZILDAN
    Default e2 RSP beta 1.0 TDT 600 by ZILDAN
    Noutati TDT:
    - LNB oprit in standby
    - Sonoru merge perfect
    - Merge si Wizard-ul de pornire (la imaginea mea e scos)
    - Sub-ul merge cam la toate posturile
    Addon RSP:
    -Plugin Fantastic cu download separat la emu, setari-emu si keys
    -Standby din telecomanda
    -Skin-uri
    -Picons
    -Satellites.xml se poate descarca direct de pe net
    -Seting RSP de e2 pus in menu la download, (inca nu e fisierul pus pe server).
    Probleme:
    Nu tine minte ultimul post activ decat daca
    intrati in standby inainte de oprire.
    ATENTIE!!!
    NU copiati decat cwshare.cfg cu ftp.
    restul fisierelor le puteti descarca din butonul albastru.
    Daca faceti asa porneste emu la restart.
    MIRROR
    EXISTA 2 GRESELI LA DENUMIREA DIRECTOARELOR SKIN
    comenzile de corectare sint:
    (In telnet rename skin folder: )
    cd /usr/local/share/enigma2             ( Enter )
    mv BlueGlass AAF.Blue.Glass            ( Enter )
    mv DarkGlass AAF.Dark.Glass            ( Enter )
    O zi frumoasa! Snow's Avatar
    Default Re: e2 RSP beta 1.0 TDT 600 by ZILDAN
    Felcitari!!!
    Merita stiky*
    FELICITARII ZIDAN PT. EFORTUL DEPUS , acum ma apuc de treaba
    RSP Team XVanish's Avatar
    Baia Mare
    10 Post(s)
    Felicitari si din partea mea!
    13 Feb 2007
    Earth
    Thumbs up Re: e2 RSP beta 1.0 TDT 600 by ZILDAN
    Felicitari .
    ps: asteptam prima imagine romaneasca pt dm 800 ( E2 )
    02 Feb 2007
    Somewhere in Aegean Sea!!
    felicitari!!!!Cumpara si un ipbox 910 sa faci firmware si pt el!!!!!Vrem si noi
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    RSP - TEAM
    03 May 2007
    Zildan rocks
    Felicitari si multumesc pentru tot ceea ce ai facut.
    03 Jun 2008
    Multumim MAESTRE !!!!
    12 Jul 2007
    in sud la dunare
    Quote Originally Posted by savin stelian View Post
    Felicitari .
    Sa o faca latraul Dongle...
    RAPIDIST PUR SINGE
    11 Apr 2007
    Felicitari, sarbatori fericite si la multi ani!
    19 Dec 2008
    Member Visitor sman's Avatar
    28 Nov 2007
    Smile Re: e2 RSP beta 1.0 TDT 600 by ZILDAN
    FELICITARI !
    cu stima sman
    22 Dec 2008
    22 Dec 2008
    Installed the image on USB. However when I download and install incubusCamd, it says "installation failed". Any help will be appreciated.
    Afzal
    Baia Mare
    10 Post(s)
    Hi,
    You should check your internet connection settings. Set the DNS correctly.
    It works just fine
    Good Luck!
