Results 1 to 1 of 1
Thread: Mosaic Enigma2
Threaded View
    13 Feb 2007
    Earth
    Post Mosaic Enigma2
    Showing the current channels of the bouquet (from the first channel) in a 3x3 view. The station name is displayed and the current transmitter runs until the countdown went to zero. Then the picture in the window of detention, the next station is angezappt and the next window. The image in Annex explains probably better than I * g *
    Prerequisite:
    / usr / bin / grave (by seddi) must be installed in the image
    Key functions:
    Bouquet + button: Countdown-config hochsetzen (a maximum of 20 seconds)
    Bouquet-key: Countdown-config runtersetzen (at least 5 seconds)
    OK button: Stop the plug to takeover the current transmitter
    EXIT button: Stop the plug with starting the sender, with which it has entered the plug
    Green: Countdown start
    Yellow: Countdown break
    1-9: For the video channel from windows and plug zap 1-9 finish
    Caution:
    As far as I know, is not yet grave on the 800 ... So, ONLY on the DM7025.
    The plugin I have on my box tested ... but only on my box, only with my station list and only myself error can still occur, since the plug still quite young.
    The plug should Multibouquets with and without work. I tested it only with enabled multi bouquet.
    Final word:
    The plug-in is after installing the extension menu to find (blue button).
    Plugin as ipk in the Annex, code as always on my SVN to find.
    Have fun ;-)
    SVN Rev.29:
    Innovations since Rev.18:
    - Ignore Marker
    - Added possibility to zap the video-windows with the number buttons, 1-9
    - Don 't crash if grave is not installed
    - Don 't crash after an error reading the channel-list
    Write-error-log to / tmp / mosaic.log
    download :
    http://fbx.ro/dv37mgk7zmntry7z
