So the plugins / extensions directory on a CF card or a USB stick shift (the devices must be already there and to / media / cf or / media / usb mounted) so that more space in the Flash has.
Pfter I once again what the DAUs wanted to do that even with simple things difficult to do here 2 ipks lease after Bedrarf always just one of the ipks use :-)
To install via FTP to / tmp and install slide with manual install in BP or with:
ipkg install / *. tmp/enigma2-plugin-extensions-plugin2cf IPK
or, of course:
ipkg install / *. tmp/enigma2-plugin-extensions-plugin2usb IPK
And the scripts only make a meaningful image in Flash, which is also uberpuft and possibly the installation denied.
If one of CF / USB boot then makes the plug moven indeed no sense - is there anyway it all depends.
If you want to get rid of plug and plug back in the Flash wants simply remove with:
ipkg remove Enigma2 plugin extensions-plugin2cf
or, of course:
ipkg remove Enigma2 plugin extensions-plugin2usb
PS: Lots of work, it was not, so do not expect too much. Try it first and reports, even if there are mistakes, I must still hold the fixed :-)
PPS: If you have a new image flasht and predict the plugins not remove the plug has zurpckgemoved it should be funktioniren these by further installaton einesder ipks reappear, but the plugins are not in the IPC database and if it files / settings / configs where unlike in plugins / extensions directory is likely they will not work properly because of this are the ipks not even thought of!!
download:
http://fbx.ro/z1ec4xddjxp079s6
Dislikes:
