Page 7 of 8 FirstFirst ... 345678 LastLast
Results 91 to 105 of 118
Thread: qbox hd
  1. #91
    Default Re: qbox hd
    noutati pt. detinatori acestui model :
    "QBoxHD Boot Image Date: 09/06/2009
    Use "QBoxHD Updater" to program it."
    - http://duolabs.redballon.us/qboxhd/q...09_06_2009.QHU
    "QBoxHD File System Image Date: 09/06/2009
    This version is a lot different from the previous ones.
    We was using an old version of Enigma2 and now we updated our system to the latest version.
    Making this works left some issue open, so at the moment you can use this version for your QBOXHD.
    Please come back to this site daily to find updated system with new feature and less bugs.
    To make it working you need to update the boot image file to the 09/06/2009 version."
    - http://duolabs.redballon.us/qboxhd/qboxhd_update_20090609_0319752846.tbz"
    preluat de pe : http://www.sat-universe.com/showthread.php?t=123086
  2. #92
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Re: qbox hd
    nu are rost sa scrii de unde ai luat-o pt ca si sat-universe a luat din alte parte....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  3. #93
    02 Feb 2007
    Default QBoxHD File System Image Rel. 2009.06.11
    - New CI Dirver
    - Fixed Ethernet configuration problem on restart
    - Fixed 2lcamd loop
    - Fixed Hard Disk detection for EXT3
    Know issue:
    - Sometime changing channels you hear only the audio ( change to another channel to solve )
    - You can record SD and HD channels on fat32 ( you have to make the "movie" folder on your HD
    - FAT32 can record only 2 gigabytes , so about 40 minutes of a HD channel
    - EXT3 format does not create automatically the movie folder ( you must create it with telnet until the next release to let enigma2 to see the Harddisk )
    - EXT3 can't record HD channels
    HERE
    QBoxHD Boot Image
    Date: 11/06/2009
    HERE
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  4. #94
    02 Feb 2007
    Default Qbox HD 16.06.2009
    Rel. 2009.06.16
    - This realease MUST be used along with the QHU version 12_06_2009
    The QHU is used for updating the NOR Flash that contains the Linux kernel.
    - Fixed several critical bugs in e2:
    Fixed USB HDD format. It is done using the ext2 filesystem.
    WARNING: At the moment, it only records files up to 2GB. This means
    approx. 30 min of HD content (it can vary depending on the ts bitrate).
    Only USB HDD are supported. eSATA HDD are not supported, yet.
    Fixed USB HDD filesystem check. The HDD must be previously formatted in ext2.
    NOTE: In order to format the USB HDD, it must be connected to the
    decoder before power-on; otherwise, it will only be able to
    record/play using the default vfat filesystem.
    Fixed stand-by bug. If the POWER button was pressed more than once, there was a crash.
    Fixed smartcard bug. It was very slow when the smartcard was not inserted
    and some times, when inserted, it blocked.
    Fixed DivX player. File names with space were discarded and not played.
    - Updated starci2win driver: Better communication with kernel
    - Updated LIRC driver: Optimized code that makes navigation in e2 menus faster
    - Updated 2lcamd: Polling for the smartcard happens each 200ms using less CPU
    than before that was very CPU-demanding.
    - Updated and fixed several filesystem scripts: These modifications make
    the whole system more stable.
    Bootloader
    Filesystem
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  5. #95
    02 Feb 2007
    Default QboxHD EmuAddon v1.4 (IncubusCamd 0.83 working)
    Emu Addon for QboxHD (Only tested on image release 21. may 2009)
    BETA Boxes seems not to support newest image 10.june.2009, so no option to verify.
    * v1.4 update
    Updated mbox II v6 build 02
    Added IncubusCamd 0.83 PATCHED - FINALLY WORKING ON QBOXHD again!.
    Removed Wireless addon to make sure new 06102009 image is not affected.
    Still kept NFS Addon inside package.
    Gracias dexter
    http://rs739.rapidshare.com/files/244184015/qboxHD_emu-addon_v1_4_dexter.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  6. #96
    02 Feb 2007
    Default Nemesis Glassline skin for Qbox HD
    Nemesis Glassline skin for Qbox HD.
    Box looks sooo much better running this!!
    Just add it to your /USR folder.
    I had trouble selecting it because it overwrites the .ttf font files, and so I couldn't read the menus. Once I figured how to select it, and rebooted the box all works fine.
    Thanks to Webkurier for the skin
    http://www.megaupload.com/?d=QCT1N96Z
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  7. #97
    02 Feb 2007
    Default QBOXHD Emu manager plugin (ccam) by DVB Busters
    Here you go, you just unzip and copy the file in a usb stick(like a filesystem update), plug it in the Qboxhd ...and restart.
    After the installation you will have in the plugin manager( menu > Plugin or just blu key) qboxHD softcam panel; just select the cam you like( ccam- mbox0.5 b21- mbox-newcs or underworld HD)
    Thanks to DVB Busters
    http://www.megaupload.com/?d=ZVGHLBHM
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  8. #98
    02 Feb 2007
    Default Qbox HD 25.06.2009
    Rel. 2009.06.25
    - The QHU is used for updating the NOR Flash that contains the Linux kernel.
    - Fixed several critical bugs in e2: #192 After recording, the video freezes
    - Fixed black screen while zapping, mainly between crypted channels
    - Added features to e2:
    - Added YouPorn plugin with parental control
    - Added image version with creation date and time to Menu->Information->About
    - Added a "Bruteforce" region for Germany. All DVB-T frequencies for Germany are included (2009/06/22) Thanks to Alexander Fuertsch!
    - Fixed feeder app: concurrence error while bridging
    - Updated wrapper_csa driver: Improved functionality
    - Updated pti and dvr drivers: Improved functionality
    http://www.4shared.com/file/11423365...25_945271.html
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  9. #99
    02 Feb 2007
    Default New QboxHD DVB Busters emu panel
    Now works great for my opinion; the radar cam(CCcam) start faster, and there are very few freezes..Still remain the problem of about 2 hours time limits...then stop to works, but they are working hard on it.
    New DVB Busters emu panel 1.04
    Underworld inside Updated to version 113
    radar cam inside
    One cam for all; in the emu panel activating RADAR CAM now you can read subscription card and in the same time you have also CCcam available.
    Read the read me for configuration(you have to edit for CCcam the file RADAR.cfg with the line C)
    DVB BuStErS MMM 04 july 2009 UMMZ PrOudLY PrEsEnTs MMB QBoxHD Emu Plug-In =The Independence Day=
    -^- RaDaR CaM 1.0 -^
    MBox + NewCS
    UnderWorld
    What's RaDaR CAM?!?!
    RaDaR CAM now includes CCCam Client
    and NewCS for card reading coming next
    all the other sharing protocols like
    gbox, newcamd and radegast
    Usage: Uncompress RAR File
    Copy qbox_update folder in root of USB Stick
    Insert USB Stick in QBoxHD ;
    Turn OFF and Turn ON QBoxHD
    Wait for install and enjoy
    Blue Button to access the EMU Panel ;
    files can be located in
    var/etc/ or var/keys/ or var/bin/
    radar.cfg is the new file you have to edit
    C: string is for CCCam and N: string is for NewCS
    http://www.sendspace.com/file/9w70uy
  10. #100
    02 Feb 2007
    Default Qbox Hd X2 Line 3.0 mod by webkurier
    http://www.sendspace.com/file/r956ly
  11. #101
    02 Feb 2007
    Default Qbox HD 12.07.2009
    12/7 New QboxHD boot and filesystem update
    This filesystem works only with the new bootloader, so please before update the bootloader, then the filesystem
    Rel. 2009.07.11
    - This release MUST be used along with the QHU version 11_07_2009
    - Fixed a critical bug in the feeder app: Some ts packets were discarded
    - Added features in e2:
    Stand-by: Added reset funcs for the tuners, the CI modules and the video and audio outputs
    - Updated starci2win driver: Added support for stand-by
    - Updated qboxhd_generic driver: Added support for stand-by
    Filesystem
    BOOT
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  12. #102
    02 Feb 2007
    Default IncubusCamd 0.88 for QBOX HD
    IncubusCamd v0.88 fur die Qbox HD!
    V0.88
    - fixed another bug on irdeto channels
    File here
    http://www.sat-universe.com/showthre...964#post415964
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  13. #103
    28 Apr 2007
    Default Re: qbox hd
    La mine incubus 0.88 nu vrea sa mearga, se leaga la server dar nu reuseste sa faca lumina, tot la vechiul 0.55 am ramas, mi-a mers cel mai bine. A aparut si un alt client ccccam, radar cam facut de DVB Busters, dar e mult in urma incubus, face lumina dar are freez-uri si macroblocuri frecvent
  14. #104
    02 Feb 2007
    Default New QboxHD DVB Busters emu panel V1.0.8
    A new function has been added in this release of Radar Cam by DVB Busters:
    Now you can insert in the file radar.cfg also the lines of GBOX, and both the cam(gbox and cccam if you have already insert line c) will works in the same time without any conflicts between them.
    So now with radadr cam you can use cccam gbox and read a card in the same time with the same cam.....soon next step more lines of cccam
    http://www.sendspace.com/file/0izo4d
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  15. #105
    02 Feb 2007
    Default New remote control for qboxHD for substitution
    16/7 New QboxHd Filesystem image and new bootloader
    IMPORTANT: From this version and on the old remote control is not supported anymore.
    If you have that model please contact Duolabs Spa at support _at_ duolabs _dot_ com
    for a substitution
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
