Aica o sa gasiti noutati pt noi firmware si emu care o sa apare in curind!
Dislikes: 0
Mai jos vedeti ce o sa stie nou firmware de la DGS.
r8445 under tests...
and little changelog:
1. Support HDMI with compressed Dolby digital audio
2. Support DVB subtitle function
3. Update Finnish, Russian and Polish language table
(Karlsson Christer translate Finnish. Thank you for his kindness.)
4. Add Front scroll function when channel name is long.
5. Add Video Resolution on banner
6. Fixed bug in Fast Scan
7. When schedule recording, remove timeshift buffer.
8. Display the resolution of the channel ON Front Panel
9. Fixed crash problem When schedule recording
10. Fixed front display bug when channel name is long.
11. favourites list upgrade
13. Fixed dvb/mhw epg on cyfra+
Note. If you watch webTV, you must to install VLC_0.8.6.
Regarding as Video Player, we can support only codec by ST.
if you have trouble with A/V decoding, I recomend you using A/V format converter
Vin cu o informatie oficiala.Se face test pt enigma 2 sa ruleze prin Flash, si nu prin usb.Deja versiuna asta e la beta testers....Si asta versiuna vine de la sifteam.Asa pt vecinii cu gura mare care spune ca e2 nu se poate sa fie instalat la flash, propun sa stau la banca lor si sa citeste din cind in cind si un forum serios...Pt ca la ultimul timp face ca manelistii: gura mare si creier mic!!!
DGS release r8573: Added or improved Function
1. Change Date format(dd.mm.yyyy)
2. support youth protectioon
3. support nfs mount recording
- remove access to /media/
- mount remote directory to /media
mount -o nolock,soft IP DIRECTORY /media/
4. Fixed pvr trick/record length bug
5. Fixed dvb-subtitle bugs
6. Display video resolution at scrambled channel
7. Update language table for Czech and Slovak
Asta contine versiuna beta 8573.Din ce spune lucreaza foarte bine si e foarte stabila.Asa in curind o sa iese pe public.Din ce am inteles o sa merge ca lumea DVB subtitle.Si posibil o sa are si IPTV.
Acuma a iesit si versiuna r8577
