Page 2 of 20 FirstFirst 12345612 ... LastLast
Results 16 to 30 of 297
Thread: Vplug 2.4.3_Primul post
    Voua va merge canalul Dorc** TV de pe Hotbird?
    Merg toate de pe frecventa respectiva doar asta nu merge..am imaginea neagra..sau transmite numai noaptea?
    transmite non stop dar nu se vede cu plugu :wink:
    Merci..inseamna ca pe SS2 nu se poate vedea canalul respectiv
    La mine merge doar in sharing...
    da doar in sharing si cu chei DCW dar nu se stie niciodata
    06 Jan 2007
    Discutam de Vplug aici.
    Astazi a actualizat key
    06 Jan 2007
    La TPS s-a schimbat... iar ...sistemul de codare si nu mai functioneaza AU. Asa ca intrati in vplug monitor -> preferences si edit TPS AU to disabled sau vplug.ini si puneti TPS_AU=0. Apoi luati tps.bin de pe net si il puneti in vplug. TPS is back! Asteptam raspunsul creatorului arab.
    A aparut vplug V.1.5.2
    08.02.2006
    V 0.7.7 (update 0.76!)
    -New: Calculating hash of Via-1/2 and TPSCrypt1/2.
    -New: Calculating hash of Seca-1.
    -New: Auto ECM. (Auto Cycle between different ECMs of one provider and selecting the decryptable one based on correct hash of decoding.)
    -New: v_sid_cache.xml file. (its records will be generated by plug-in based on successful pids of AutoECM)
    -Bug fix: Crash on_exit has been fixed (BMDThread was removed!).
    -Bug fix: Nagra2 EMM handling and fake keys. (Thnx to Daex for the info. and testing)
    -Update: tvCabo -> Nagra2 ECM handling was fixed. (Remove Nagra1 keys and then test it
    MULTUMIRI IRANIANULUI!
    merge din nou tot ce mergea cu plugu.nu uitati sa activati TPS_AU
    Aici e linkul vplug 1.5.2 - By Vahid
    http://www.zshare.net/download/vplug1-5-2-zip.html
    si vplug 1.5.2 FULL (toate fisierele necesare) - crosat
    http://www.zshare.net/download/vplug...glish-zip.html
    V 1.5.3
    - Update : Fixed TPS AU!
    link..www.crosat.org/aploud/
    La mine nu si-a facut update pe TPS...a mai patit cineva?
    Quote Originally Posted by outcast
    11.02.2007
    V 1.5.3
    Un link direct Vplug 1.5.3 by Vahid
    http://www.zshare.net/download/vplug11-5-3-zip-csj.html
    sau intrati pe forumul "de la mama lui":
    http://dvbn.happysat.org/viewtopic.php?t=39080
    se pare ca merge pachetu CANAL+ FRANTA pe hot bird si se pare ca si ceva canale in conax ar merge dar a inceput o ploaie torentiala si nu am mai putut verifica :cry: koha si klan tv pe w2 am reusit
    face update la d+
