Results 16 to 30 of 42
Thread: Imagini DM 7025
    13 Feb 2007
    Earth
    Post Newnigma2-Image-DM7025-v2.3.2
    20.02.09:Online Update to v2.3.2 available
    Updates:
    * enigma2 20.02.2009
    * enigma2-plugin 20.02.2009
    * newnigma2-plugins 20.02.2009
    * dreambox-dvb-modules-dm800 07.02.2009
    * dreambox-dvb-modules-dm8000 07.02.2009
    * dreambox-dvb-modules-dm7025 06.02.2009
    * enigma2-defaultservices <= new xml
    * newnigma2-feed <= update feed
    * dream-hd skin <- div. fix
    * Kerni-hd1 skin <- div. fix
    new on feed:
    * enigma2-plugin-systemplugins-networkbrowser
    * enigma2-plugin-newnigma2-language-pl
    * enigma2-plugin-newnigma2-language-lv
    * enigma2-plugin-extensions-merlinmp3player
    * enigma2-plugin-extensions-cccaminfo
    dm7025:
    Should be flashed, instead of updating!
    enigma2-plugin-newnigma2-cfinstaller:
    This plugin will extend your flash memory with cheap cf-card memory. It will speed up the 7025 booting and also online updates will be faster. It will eliminate your flash memory problems, so more Plugins are possible!
    >> a must have for every 7025 with NewNigma²
    download :
    http://www.speedyshare.com/121355745.html
    13 Feb 2007
    Earth
    Post Ls Enigma2 Image for DM7025 - 22.02.09
    LS ENIGMA2 IMAGE 20090222
    dm7025 -dm800 -dm8000 <NEW!>
    Versione = Experimental 2.6
    Enigma2 = 22/02/09 (mod by Linsat Team) <NEW!>
    Plugins = 22/02/09
    DRIVERS dm7025 = 06/02/09 con secondstage 61<NEW!>
    DRIVERS dm800 = 07/02/09 con secondstage 70 <NEW!>
    DRIVERS dm8000 = 07/02/09 con secondstage 71<NEW!>
    Distro-Opendreambox (GIT) = 1.5
    BB_Version = 1.6.8
    + Per TUTTI gli aggiornamenti del CVS vedere QUI
    NB:QUESTE IMMAGINI CONTENGONO DRIVERS molto RECENTI, QUINDI CONSIGLIAMO DI METTERLE SOLO IN FLASH, OPPURE IN PEN/CF MA USANDO UNICAMENTE IL "Multiboot di Thowi". IN ALTERNATIVA SI PUO' USARE IL "BarryAllen" MA SOLO AVENDO IN FLASH UNA IMG CON LO STESSO SECONDSTAGE E DRIVERS (o SUCCESSIVO)
    Caratteristiche principali img LS rispetto a una CVS:
    Emumanager integrato con gestione separata softcam/cardserver (NO EMU INSIDE - NO EMU DIRECT DOWNLOAD)
    Menu Scriptexecuter (basta inserirne di nuovi nella cartella /usr/script), script già presenti:
    *Backup flash image
    *Delete Backup
    *Delete hdd crashlog
    *Emu info
    *Diritti CCcam
    *Diritti NewCS
    *Free memory
    *Free space
    *Grab video
    *Hdd temp
    *Ipk install
    *Ipk clear
    *Module info
    *Mountpoints info
    *Process
    *Remove .py
    *Spinner On/Off
    *Creating 32MB Swap on hdd/usb/cf
    *Deactivate Swap
    *Uptime
    Scelta modalità telecomando: Neutrino (default) / Enigma
    Indicazioni avanzate nello skin:
    * posizione orbitale del canale
    * info dati frequenza attiva (anche DVB-T e DVB-C) <NEW!>
    * info avanzate emu
    * info avanzate codifica
    * info nome emu e cardserv attivi (separato)
    * info tempo di risposta card (ms)
    * risoluzione video
    OpenEPG per l'epg di Sky Italia con funzionalità avanzate (vedere QUI)
    OpenVPN attivo e incluso nel Kernel
    Italiano come prima lingua di default
    Skin Eagle.Megalight (default) <NEW!>
    BitrateViewer
    Mount USB
    Moduli per Smargo Reader USB inclusi nel kernel (avvio immediato)
    Swap abilitato al boot
    Riordino Lista Plugins premendo i tasti numerici (Nr -> posizione)
    Plugin aggiuntivi inclusi di default:
    DirettaGol Interactive v1.2
    GrandeFratello Interactive v1.2
    TG24 Interactive 1.2
    CCcaminfo v1.2 <NEW!>
    Youtubeplayer
    VLC
    MoviePlayer
    MultiRemoteControl (Vedere QUI per le istruzioni d'uso)
    DynDNS
    Tuxcom
    Moviecut
    Movieretitle
    Videomode
    Videotune
    SatellitesEquipmentControl
    NetworkWizard
    Autoresolution (only dm800 and dm8000)
    Aggiornamenti rispetto alla LS-20090129:
    + Eagle.Megalight 3.0b
    + Traduzione Italiana 1.9 by Spaeleus
    + Nuovo menu SoftwareManager con backup/restore personalizzabile
    + Nuovo menu Networkbrowser per il mount di periferiche esterne o altri dreambox
    + FIX DVB-T crash
    + Libreria libdvdcss integrata (dm8000)
    - Liste canali Sky
    Promemoria tasti:
    pressione lunga (LS):
    tasto Menu -> Softcam setup
    tasto verde -> Lista Timer
    tasto giallo -> Lista Plugins
    tasto blu -> OpenEPG (EPG estesa Sky)
    tasto Info -> Scelta del tipo di griglia EPG (normale / multiepg grafico)
    pressione normale (default):
    tasto Menu -> Menu principale
    tasto verde -> Sottoservizi
    tasto giallo -> Timeshift
    tasto blu -> Extensions
    tasto Info -> Descrizione evento
    CREDITS ESTERNI:
    Ronaldd per l' "Emumanager" e l' "expert-tuner infobar"
    Lukkino per LoadEPG OpenTv e la traduzione del dizionario
    PLi team per l'indicazione della posizione orbitale nello skin, per il menu telecomando e per il "BitrateViewer"
    AliAbdul per lo "Scriptexecuter", per il "CCcaminfo" e per il "Numero canale nei bouquet"
    dreg per il tuxcom E2
    Reinh@rd per il satellites.xml aggiornato
    Vali per le info frequenza avanzate
    Un particolare ringraziamento a Musicbob per il suo "OpenEPG", per le modifiche all'emumanager di Ronaldd e per i Plugins "Interactive" e a Spaeleus per la sua instancabile opera di traduzione e pazienza per i testing.
    ATTENZIONE:
    I FIRMWARES IN OGGETTO NON CONTENGONO CHIAVI O EMULATORI DI NESSUN GENERE
    LINSAT.NET NON E' RESPONSABILE IN NESSUN CASO DELL'USO CHE GLI UTENTI FARANNO DI QUESTI PROGRAMMI
    Download :
    http://rapidshare.de/files/45566187/...25233.rar.html
  3. #18
    13 Feb 2007
    Earth
    Post Nabilosat Enigma2 Black Hole - DM7025 v0.9
    Advanced Graphics
    What is new in this version 0.9 ?
    Nabilosat v 0.9 is the first image introducing advanced graphic engine with effects and animations to DM7025.
    New Skin
    Black Cat Plus skin By Army
    NEW BOOT LOGOS
    New Bootlogo by Army
    New Atomic spinner by Army
    New Effects and animations
    Animation during CAM start
    Animation during Addons Server Connection
    New System Monitor Panel
    New and Revolutionary Graphic System Monitor Panel (1x Blue + 1x Yellow)
    Monitor popup animation in System Monitor Panel
    New System Plugins
    This image is including the new CVS System Plugins: Network Browser and Software Manager
    Starting from v09, Nabilosat Black Hole images will have the Samba Server enabled by default. This will allow to use the Network Manager and easily share any DM or PC of your LAN.
    Enigma2 CVS date
    23 February 2009 2.6 experimental
    Drivers date
    06 February 2009
    Second Stage #61-pr1
    Main Function Keys
    Button 1xOK = Light Info Skin
    Button 2xOK = Extra Info Skin
    Button Blue = Nabilo Blue Panel
    Button 1x Blue + 1x Yellow = New System Monitor Panel
    Button Green = Nabilo Green Panel
    Button Green-Long-Push = Subservices
    Button Red = Start Record
    Button Yellow = Time Shift
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma2 Analogic Clock
    Channel Orbital Position
    Signal SNR, BER
    Infobar Picons
    LCD/OLED Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Setup
    OSD Settings
    Nabilosat E2 EPG Settings
    LCD Settings
    Fast Plugin Settings
    Inadyn Settings
    Swap File Settings
    Hard Disk Setup
    Nabilo Mount Wizard
    OpenVPN Panel
    Samba/Cifs Panel
    NFS Server Panel
    Telnet Panel
    FTP Panel
    CCcam Info
    Service Info
    Enigma2 Settings
    About
    Memory
    Space
    CPU
    Process
    Save
    Select/Start/Restart EMU
    2) Green Panel
    Shoutbox
    Fast Plugin
    Addons
    Addons Download Manager
    Manual Install Nab packages
    Manual Install IPK packages
    Addons Uninstall Panel
    Nabilosat Statistics
    Scripts
    Many thanks to the Beta Testers Team
    ^^Corrado^^, Franzjuve, Willow, MaxZ4, DeepDiver,
    Credits
    E2 Sky Epg loader integration by MaxZ4.
    Army for the new Black Cat Plus skin
    Army for the new System Monitor Panel graphics.
    Many Thanks to lukkino (VDR-Italia) for opentv source code.
    This Images doesn't contain any keys nor softcams.
    Backups or other modified Images are not supported!
    WARNING.If you install it to multiboot, you must install the Nabilosat Pure Flash DM 7025 dated 23 February 2009.
    download :
    http://rapidshare.de/files/45581169/...25_09.zip.html
  4. #19
    13 Feb 2007
    Earth
    Post Nabilosat DM7025 Pure Flash 23FEB09, with ....
    Nabilosat DM7025 Pure Flash 23FEB09, with Barry Allen 4.6.81
    What is the Nabilosat DM7025 Pure Flash ?
    This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.
    What is included in this image ?
    This image is including the latest available edition of Barry Allen: 4.6.81. Software Manager and Network Browser
    Why should I install this image in flash ?
    Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.9 of its Black Hole image. If installed to multiboot, the new Black Hole v0.9 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
    How do I install Barry Allen with this image ?
    Barry Allen will be automatically installed at the end of the default wizard
    Will I loose the images already installed on my media ?
    No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.
    How do I install it to flash ?
    You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.
    Release Details
    NEW Nabilosat Bootlogo by MaximoII
    Barry Allen 4.6.81 included
    TARGET_ARCH = "mipsel"
    TARGET_OS = "linux"
    MACHINE = "dm7025"
    DISTRO = "opendreambox"
    DISTRO_VERSION = "1.5.0"
    TARGET_FPU = "soft"
    ENIGMA2_CVS_DATE = "23 February 2009"
    ENIGMA2_VERSION = "2.6 experimental"
    DRIVERS = "06 February 2009"
    SECOND STAGE = "61-pr1"
    BARRY_ALLEN_VERSION = "4.6.81"
    Instructions
    1) Flash your DM 7025 with Web Interface or DreamUp and serial cable
    2) Complete the Default Wizard to setup the basic steps
    3) Upon Wizard completion, Barry Allen will install automatically, and a Console Window will report the progress
    4) Enigma2 will restart as usual
    5) Barry Allen is available in the plugin list, ready to install images to multiboot.
    Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
    download :
  5. #20
    13 Feb 2007
    Earth
    Post Re: Nabilosat DM7025 Pure Flash 23FEB09, with ....
  6. #21
    13 Feb 2007
    Earth
    Post OoZooN-CVS--dm7025 --28-02-2009
    OoZooN-CVS-lean-dm7025-20090228.nfi + OoZooN-CVS-full-dm7025-20090228.nfi
    # Hier kommt wieder ein aktuelles CVS Image aus dem enigma2 2.6 "dev" zweig.
    # Enigma stand ist 28.02.2009
    # die plugins sind vom 28.02.2009
    # die treiber vom 06.02.2009
    # neuer kernel 2.6.12.6-s6
    # frontprozessor ist v7, secondstageloader ist 61
    # änderungen an Enigma2 können Hier verfolgt werden
    # dieses image ist in zwei versionen verfugbar: lean und full. das lean ist 19,6 mb, das full 29 mb gross.
    # alles was im lean entfernt wurde, kann uber den plugin-download nachinstalliert und auch wieder deinstalliert! werden
    # die full-version enthält alle aufgefuhrten plugins sowie benötige libs und ist fur alle gedacht, die ihre box nicht online haben
    # diese können naturlich alle plugins deinstallieren, die sie nicht benötigen.
    # meine änderungen am oe:
    # eigene bootlogo's, artwork von clumsy
    # mit satellites.xml - enigma² by Reinh@rd
    # usb, fat und vfat treiber im kernel
    # änderung des dccamd start
    # dccamd nicht im image enthalten, kann online nachinstalliert werden
    # systemplugins:
    # frontprocessorupgrade
    # positionersetup
    # satelliteequipmentcontrol
    # satfinder
    # skinselector
    # softwaremanager
    # hotplug
    # videotune
    # networkwizzard
    # defaultservicescanner
    # plugins:
    # cutlisteditor
    # filemanager
    # graphmultiepg
    # ipkginstaller
    # mediaplayer
    # mediascanner
    # pictureplayer
    # socketmmi
    # antiscrollbar
    # autotimer
    # dyndns
    # emailclient
    # epgrefresh
    # fritzcall
    # httpproxy
    # imdb
    # ofdb
    # lastfm
    # logomanager
    # movietagger
    # netcaster
    # simplerss
    # startuptostandby
    # trafficinfo
    # vlcplayer
    # webcamviewer
    # webinterface
    # werbezapper
    # wirelesslan
    # nfsserver
    # aioscreengrabber
    # tuxcom
    # userscripts
    # hddtemp
    # mountmanager
    # nfsedit
    # moviecut
    # movieretitle
    # tageditor
    # cdinfo
    # downloadbare plugins
    # dccamd
    # barryallen
    # merlin-browser
    # cronmanager
    # orwell
    # pauli
    # renamemovie
    # screensaver
    # skintransp
    # timeshiftsave
    # wastebasket
    # permanenttimeshift
    # lcd skin
    # spinnerselector
    # iprec
    # integrierte Skins:
    # dreamTV
    # blackbox
    # cromline
    # cromline.cobolt
    # glassline
    # shadowline
    # avalon
    # downloadbare Skins:
    # beyonddreams
    # beyonddreams.simple
    # x2-line
    # merlin-racer
    # blueline
    # blueline.extended
    # blueline.single
    # flatline
    # flatline.blue
    # flatline.picon.blue
    # flatline.picon.lava
    # greenline
    # greenline.extended
    # greenline.single
    # greyline
    # greyline.3d
    # greyline.extended
    # greyline.single
    # änderungen an enigma:
    # MHW epg aktiviert
    # .recordings patch
    # das image ist uber erweiterungen -> softwareupdate uber das internet aktualisierbar!
    # OE Build Configuration:
    # BB_VERSION = "1.6.8"
    # TARGET_ARCH = "mipsel"
    # TARGET_OS = "linux"
    # MACHINE = "dm7025"
    # DISTRO = "opendreambox"
    # DISTRO_VERSION = "1.5.0"
    # TARGET_FPU = "soft"
    download :
    < lean >
    http://rapidshare.de/files/45714142/...90228.rar.html
    download :
    < full >
    http://rapidshare.de/files/45714143/...90228.rar.html
  7. #22
    13 Feb 2007
    Earth
    Post Re: OoZooN-CVS--dm7025 --28-02-2009
    in english :
    # OoZooN-CVS-lean-dm7025-20090228.nfi + OoZooN-CVS-full-dm7025-20090228.nfi
    # here is my latest CVS Image based on enigma2 2.6 dev.
    # Enigma is of 28.02.2009
    # the plugins are of 28.02.2009
    # the drivers are of 06.02.2009
    # new kernel 2.6.12.6-s6
    # frontprozessor is v7, secondstage is 61
    # changes at Enigma2 can be pursued HERE
    # this image is available in two versions: lean and full. the lean is about 19,6 mb, the full is 29 mb.
    # everything what's stripped in the lean, can installed via plugin-download and also deinstalled!
    # the full-version contains all listed plugins and needed libs and is intended for all, who have their box not online
    # of course are plugins and libs deinstallable if not needed.
    # my changes at oe:
    # own bootlogo's, artwork by clumsy
    # with satellites.xml - enigma² by Reinh@rd
    # usb, fat and vfat driver in kernel
    # changes of dccamd start
    # dccamd not included in image, can be installed via plugin download
    # systemplugins:
    # positionersetup
    # satfinder
    # skinselector
    # softwaremanager
    # hotplug
    # videotune
    # networkwizzard
    # plugins:
    # cutlisteditor
    # filemanager
    # graphmultiepg
    # ipkginstaller
    # mediaplayer
    # mediascanner
    # pictureplayer
    # socketmmi
    # antiscrollbar
    # autotimer
    # dyndns
    # emailclient
    # epgrefresh
    # fritzcall
    # httpproxy
    # imdb
    # ofdb
    # lastfm
    # logomanager
    # movietagger
    # netcaster
    # simplerss
    # startuptostandby
    # trafficinfo
    # vlcplayer
    # webcamviewer
    # webinterface
    # werbezapper
    # wirelesslan
    # nfsserver
    # aioscreengrabber
    # tuxcom
    # userscripts
    # hddtemp
    # mountmanager
    # nfsedit
    # moviecut
    # movieretitle
    # tageditor
    # cdinfo
    # download only plugins
    # dccamd
    # barryallen
    # merlin-browser
    # cronmanager
    # orwell
    # pauli
    # renamemovie
    # screensaver
    # skintransp
    # timeshiftsave
    # wastebasket
    # lcd skin
    # spinnerselector
    # iprec
    # Integrated Skins:
    # dreamTV
    # blackbox
    # cromline
    # cromline.cobolt
    # glassline
    # shadowline
    # avalon
    # downloadable Skins:
    # beyonddreams
    # x2-line
    # merlin-racer
    # blueline
    # blueline.extended
    # blueline.single
    # flatline
    # flatline.blue
    # greenline
    # greenline.single
    # greyline
    # greyline.3d
    # greyline.extended
    # greyline.single
    # my changes at enigma:
    # MHW epg active
    # .recordings patch
    # this image is updateble via plugins -> softwareupdate over internet!
  8. #23
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default LT5 SP6 Release DM7025
    Hey LT fans,
    now it's time for our last service pack for the image LT The fifth Campaign.
    General note:
    Barry Allen is a great tool for the experienced Dreambox user but it is also the source of much problem for the inexperienced Dreambox user.
    LT Team has only tested the image in flash and if you are using Barry Allen and have some problems then install the image in flash. If the
    error is still exist after installing the image in flash then send us the crashlog which is created on harddisc.
    No error reports will be read if image is used with Barry Allen!
    Barry Allen & LT:
    This usual problem with using BA is that the drivers & kernel are usually loaded from the image in flash. This means that if you do not have the same drivers in a flash image as the one you are booting using BA you will end up in a non-tested (and non-supported) configuration.
    Also, the LT image has tweaked the early boot process and this might be effected by using a tool such as BA.
    However, the Barry Allen is a great tool and if it works for you we are very happy!
    DM7025
    The image is now pushing the hardware to the limits (and little beyond) so to make all functions to work as intended you have to install
    a Compact Flash so you can create a swapfile on it. We have notice several issues which a swapfile will solve.
    Also before installing the image if you are upgrading please remove the epg_external.dat if you are using LTEPG and activate swap as first
    thin you do after installing the image.
    We also recommend that you on dm800/8000 insert a USB Stick in lower slot and creates a swapfile for the Dreambox.
    If you follow the notes above you will be just as us, a happy Dreambox owner.
    LT rev 2264
    Enigma2 20090226
    Drivers:
    dm7025 20090206
    dm800 20090207
    dm8000 20090207
    Secondstage:
    dm7025 61
    dm800 70-r1
    dm8000 71-r1
    New:
    New converter LTOnlineChecker (checks the internet connection all 5 minutes)
    EPG Search (callable from the LT EPG)
    DeviceManager
    Translator converter for fixed texts
    Added new configs convert picon names from 0.9W to 0.8W (yes/no), convert picon names from 1.0W to 0.8W (yes/no), convert picon names from 5.0E to 4.8E (yes/no), convert picon names from 28.4E to 28.2E (yes/no)
    Changes:
    Font-name and the font-size can be given from the skin.xml for LTEPG (servicename and event-name)
    Translate date strings (Converter LTClockToText)
    Added uk translation. Thx to bodyan
    Added VideoSize and IsHD convert-types to LTServiceToText converter
    Updated lt-locale. Thx to Adga
    Updated de-locale
    Added LTPVRState and LTTimeShiftState again
    FIX position/size RecordState in LCD/OLED
    Check calendar events in the background all 5 minutes instead of everytime when showing the infobar
    New config... EPG type (long-holding Info-button): Multi EPG / LT EPG, Graphical Multi EPG, IMDB or Choice Box
    New config for LTEPG: show servicename, picon or HD-version (servicename and picon)
    Added CF to fstab in dm8000 image (/dev/scsi/host0/bus0/target0/lun1/part1 /media/cf auto defaults 0 0)
    Load normal png-size after e2 couldn't resize png in LT EPG
    Changes EPG-Grabber:
    Moved more code to "common.py" (get_cached_content and some helpers)
    Changed date for cached files (YY-MM-DD) in all grabbers
    New class "cdata" in common.py used in the new grabber html_hallandsposten
    Only load the module/sub you need in all grabbers
    Cache in all grabbers except radiotimes
    xmltv - use cElementTree instead of minidom
    New nordic_drdk.xml (no) -> (od) bugfix
    New nordic_hallandsposten.xml
    Changed SVT2 Värmlandsnytt ID since service has moved
    Added missing TV4 Värmlandsnytt Terrestrial
    Replaced all TSID's from 0x0010 to 0x02c on SVT1 & SVT2 (SVT no longer transmits on TSID 0c0010)
    Updated so all local SVT1 & SVT2 gets updated
    Changes MediaCenter:
    Stop playing movie after pressing STOP-button in Media-Center - Movie-Player, not only TV-button
    Added mytunes.cc support to MediaCenter
    Added ORF IPTV to StreamPlayer+
    Added ORF onDemand to StreamPlayer+
    Added Subtitle-Selection support (TEXT-button)
    Changes GlassLine.II skins:
    Added all wizard screens
    Added DVD player screen
    Removed :SS in full InfoBar
    Added LTEPG search screen
    Some small fixes in network
    Added Main menu DVD icon
    Software skin added
    Small tweaks of the infobar icons
    http://www.upload-drive.com/9232/LT-Fifth_6-dm7025_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  9. #24
    02 Feb 2007
    Default Experimental Dm7025 13/03/2009
    Experimental image for DM7025
    Lastest update of 13.03.2009
    http://www.sateliti-upload.info//ind...reambox%207025
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  10. #25
    02 Feb 2007
    Default DM7025 milo-image
    DM7025 milo-image-dm8000-20090319153209.nfi
    19 maart 2009
    Code:
    Nieuw in deze release:* Fix in opname menu (sub-folder)In dit image:* Opname menu verbeteringen: Auto-tagging, afspeelstatus icoontjes, folder selecteren* Picons downloaden naar CF, USB of HDD* NETcaster plugin fixes van Bushwhacker* Nederlandse vertalingen* Mount manager* DVD speler* Mediaspeler* CCCam.cfg, .ssh dir and dropbear_rsa_key worden uit /hdd/backup teruggezet, net als in Ronaldd* Software manager zit nu onder blauwe knop of onder "instellingen", zoals DMM het wil* Enigma2 CVS van 2009-03-18* CCcam 2.0.11* Freesat EPG* Mediahighway EPG* EPG import patch* Veel van Ronaldd's toevoegingen in zijn december 2008 imageTraduction : N&eacute;erlandais » Allemand19. M&auml;rz 2009 Neu in dieser Version: * Fix im Aufnahme-Men&uuml; (Sub-Ordner) In diesem Bild: * Aufnahmemen&uuml; Verbesserungen: Auto-Tagging-, Wiedergabe-Status-Symbole, Ordner, w&auml;hlen Sie * Picon download CF oder USB-Festplatte * NETcaster Plugin behebt Bushwhacker * Niederl&auml;ndisch &Uuml;bersetzung * Berg-Manager * DVD-Player * Media * CCCam.cfg. Ssh dir und dropbear_rsa_key ab / hdd / backup wieder, wie in Ronaldd * Software-Manager wird nun unter blaue Taste oder "Institutionen", wie er will DMM * Enigma2 CVS von 2009-03-18 * CCcam 2.0.11 * Freesat EPG * Media Highway EPG * EPG-Import-Patch * Viele Ronaldd der Erg&auml;nzungen im Dezember 2008 Bildgracias Felek
    http://www.megaupload.com/?d=WKCADKR0
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  11. #26
    02 Feb 2007
    Default Experimental Dm7025 19/03/2009
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  12. #27
    13 Feb 2007
    Earth
    Post OoZooN-CVS--dm7025-20090321
    OoZooN-CVS-lean-dm7025-20090321.nfi + OoZooN-CVS-full-dm7025-20090321.nfi
    Enigma stand ist 21.03.2009
    die plugins sind vom 21.03.2009
    änderungen an Enigma2 konnen Hier verfolgt werden
    dieses image ist in zwei versionen verfugbar: lean und full. das lean ist 19,7 mb, das full 29 mb gross.
    die full-version enthält alle aufgefuhrten plugins sowie benotige libs und ist fur alle gedacht, die ihre box nicht online haben
    diese konnen naturlich alle plugins deinstallieren, die sie nicht benotigen.
    systemplugins:
    positionersetup
    satfinder
    skinselector
    softwaremanager
    hotplug
    videotune
    networkwizzard
    plugins:
    cutlisteditor
    filemanager
    graphmultiepg
    ipkginstaller
    mediaplayer
    mediascanner
    pictureplayer
    socketmmi
    antiscrollbar
    autotimer
    dyndns
    emailclient
    epgrefresh
    fritzcall
    httpproxy
    imdb
    ofdb
    lastfm
    logomanager
    movietagger
    netcaster
    simplerss
    startuptostandby
    trafficinfo
    vlcplayer
    webcamviewer
    webinterface
    werbezapper
    wirelesslan
    nfsserver
    aioscreengrabber
    tuxcom
    userscripts
    hddtemp
    mountmanager
    nfsedit
    moviecut
    movieretitle
    tageditor
    cdinfo
    dccamd
    barryallen
    merlin-browser
    cronmanager
    orwell
    pauli
    renamemovie
    screensaver
    skintransp
    timeshiftsave
    wastebasket
    permanenttimeshift
    lcd skin
    spinnerselector
    iprec
    integrierte Skins:
    dreamTV
    blackbox
    cromline
    cromline.cobolt
    glassline
    shadowline
    validator 3
    downloadbare Skins:
    avalon
    beyonddreams
    beyonddreams 3
    beyonddreams.simple
    x2-line
    merlin-racer
    merlin-magic
    blueline
    blueline.extended
    blueline.single
    flatline
    flatline.blue
    flatline.picon.blue
    flatline.picon.lava
    greenline
    greenline.extended
    greenline.single
    greyline
    greyline.3d
    greyline.extended
    greyline.single
    MHW epg aktiviert
    .recordings patch
    TARGET_OS = "linux"
    MACHINE = "dm7025"
    TARGET_FPU = "soft"
    http://www.4shared.com/file/94151594...-20090321.html
    http://www.4shared.com/file/94151562...-20090321.html
  13. #28
    Standard RSP member celenhein's Avatar
    Ţară condusă de rahaţi lacomi şi ignoranţi
    Default Re: LT5 SP6 Release DM7025
    Misto imaginea.
    Doar ca iti lasa prea putin spatiu in flash.
    E neaparata nevoie de activat swap-ul si eventual de facut un "Freeze" cu CF-ul ca sa ai spatiu de manevra.
    In rest e beton.
  14. #29
    13 Feb 2007
    Earth
    Post LS-E2 Images DM7025 13.05.2009
    Pannello LS Extra (comprende Emumanager e Scriptstarter)
    *Backup flash image
    *Delete Backup
    *Emu info
    *Diritti CCcam
    *Diritti NewCS
    *Free memory
    *Free space
    *Grab video
    *Hdd temp
    *Ipk install
    *Ipk clear
    *Module info
    *Mountpoints info
    *Process
    *Remove .py
    *Spinner On/Off
    *Deactivate Swap
    *Uptime
    *OpenVPN On/Off
    * info avanzate emu
    * risoluzione video
    OpenEPG by Musicbob per l'epg di Sky Italia con funzionalità avanzate (vedere più sotto per le info dettagliate)
    Skin default Eagle.Megalight
    BitrateViewer
    OpenEPG 0.93 + MyEpg 0.2.4
    CCcaminfo v1.2
    Youtubeplayer
    VLC
    MoviePlayer
    MultiRemoteControl (Vedere QUI per le istruzioni d'uso) (solo dm7025 e dm800)
    DynDNS
    Tuxcom 1.16
    Moviecut
    Movieretitle
    Videomode
    Videotune
    NetworkWizard
    CommonInterfaceAssignment
    StartupToStandby
    TagEditor
    Autoresolution (solo dm800 e dm8000)
    + OpenEPG 0.93 by Musicbob con integrato MyEpg 0.2.4 by Skaman:
    NEWS :
    - 2 EPG IN UNA ! la velocità e la completezza di OpenEPG (vedere QUI) e l'integrazione in enigma2 grazie a MyEpg
    - epg enigma2 aggiornata senza riavviare enigma2 !
    - entrambe le epg sono attivabili o disattivabili da finestra config:
    cioè si possono scaricare i dati solo per MyEPG oppure solo per OpenEPG, oppure naturalmente per entrambe
    - autodownload perfezionato perfettamente funzionante in tutte le modalità
    - il plugin effettua il caricamento della cache epg dopo il reboot totale non gestito (es.: spegnendo il dream o dando "reboot" da telnet)
    - le linee comando per MyEPG sono inseriti nei due files "downloader.sh" e "dbconverter.sh" presenti nella cartella del plugin /usr/lib/enigma2/python/Plugins/SystemPlugins/OpenEPG/
    Editare questi due files inserendo le linee comando con le opzioni necessarie, che possono cambiare ad ogni update di Skaman.
    NEW!
    + Visualizzazione epg anche dei canali Mediaset (al posto dell'insulso "Visibile in analogico e digitale terrestre") SU TUTTE LE FINESTRE, compresa WebIf, e skin OSD
    Addio alla noiosa frase che da mesi impediva di leggere la programmazione degli eventi correnti per i canali Mediaset
    download :
    http://www.easy-share.com/1905171059...0513193723.nfi
  15. #30
    13 Feb 2007
    Earth
    Post Nabilosat Enigma2 Black Hole - DM7025 v0.10
    What is new in this version 0.10 ?
    Army Black Cat updated version for Black Hole v0.10
    Nabilosat Black Hole socket system creates a communication with Enigma 2 for the management of the EMU restart and Nabilosat API's
    EMU Management: the Black Hole Socket system allows EMU's to be run externally to Enigma2.This solution offers a better EMU performance. As an example, when you start the EMU, the spinner will not display
    NEW EPG Panel introducing new features for the control of EPG
    Download Now reset EPG download timer and immediately start a download
    NEW EPG Provide list available in EPG main panel
    EPG settings global setting for all provider, and single provider settings
    EPG Cron for each single provider
    EPG search buttons enable/disable the epg search buttons
    Panic Button quickly zap to a fixed channel and clear zap history
    Analogue Clock: the analogue clock and gauge needles have been rewritten to offer a clear reading
    Increased Performance: all Nabilosat panel have been recoded to offer better performance
    System Pop Ups: using Nabilosat socket system now
    Extra Info Bar: new system
    Manual Install IPK: added Enigma2 console
    CCcam Info now available directly from the Green Panel (1x Green + 1x Red )
    Experimental addition
    Australian Open EPG Download Australian Open EPG via satellite stream
    TV Sajten Web EPG Download Tv Sajten Web EPG
    NOTE. These 2 additions are experimental. Please test them and report any issue.
    New:
    Nabilosat Black Hole System: this system represents a new approach to the communications exchange between the image core, the external environment and Enigma2. Making the image faster and more efficient.The Nabilosat Black Hole Socket allows also the following:
    1) Introduction of Nabilosat Black Hole API
    2) EMU and Application enhanced management, as they run externally to Enigma2
    The following diagram represents the communication flow
    What are the benefits ? When you start or restart your default EMU, Enigma2 will be busy at controlling this process, until it is started and initialized. As Enigma2 is busy with this process, the spinner will display. With Nabilosat Black Hole System, when you start/restart your default EMU, Enigma2 will only send a short signal to the Socket, and this Socket will be responsible for starting the EMU. Therefore, Enigma2 is free to keep running, and the spinner will not display. Additionally, the EMU will also be more efficient as it does not depend from Enigma2.
    Another benefit is represented by the possibility to send command to Enigma2 from the Linux shell, or from a schedule custom script. This system is the new Nabilosat Black Hole API.
    New:
    Nabilosat API: you can now start a Telnet or SSH session and send a command to execute any of the following available API's:
    - Restart EMU
    - Restart E2
    - Reboot DM
    - Standby
    - Shutdown
    To launch each of the available API's, start a Telnet or SSH session, and type the following commands:
    Nabilocmd restartemu
    Nabilocmd restartenigma2
    Nabilocmd standby
    Nabilocmd reboot
    Nabilocmd shutdown
    Each API can also be executed manually via Telnet or SSH. It can also be included in your custom script. It can be executed automatically and regularly with the new Nabilosat Black Hole Cron Manager, at a set time, and every day.
    Nabilosat API are also useful if your DM hangs. Instead of choosing to Power OFF, you can now simply restart Enigma2 or reboot using the required API.
