Results 1 to 15 of 26
Thread: Imagini DM 7000
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Imagini DM 7000
    06 Jan 2007
    Default Gemini 4.50 DM 7000 & DM 7020
    Gemini v4.50
    For DM7000/7020
    Technical Infos:
    * Enigma of: 06.09.2008
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet
    * adding additional functions via internet from the Gemini-Server and install them automaticly
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you realy need
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changeing the name and settings via own menu.
    * Creation of a 2nd socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
    * Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
    * added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
    * Display of EMM, ECM or "Expertinfos" are switchable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CDROM/DVD no matter using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    EPG
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * change the settings for recording (before Time, after-recording time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    Recordings:
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    New:
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
    * Reorganised the BP main menu
    * addition information can now be found in Menu -> Information (new optical appearance)
    * Device-Manager for HDD / DVD / CF / USB
    * reactivated the Jukebox (special wish of a very nice User Augenzwinkern
    ). Please install as addon.
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded!
    Fix + update:
    * Dreamnetcast (now you can use TV and Internetradio at the same time)
    * RSS-Reader
    * Weatherforecast (now with favourites management)
    * SWAP
    * User-Script
    * have a look in the CVS
    Interfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
    http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
    We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
    This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We assume no liability for direct or indirect damage.
    Thanks a lot and have fun
    Your Gemini-Team
    http://www.i-have-a-dreambox.com
    http://www.dreambox.it/news/view.php?id=7304
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Gemini 4.60 DM7000
    Gemini v4.6:
    Technical Infos:
    * Enigma of: 19.12.2008
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    Addons:
    Camd:
    Files / Devices
    * Backup function
    EPG
    Extras:
    * the Jukebox, Please install as addon.
    Recordings:
    New:
    * Webcam Viewer for viewing images from the Internet, configureable via XML config (only Still, no interval as we have at E2)
    * Now you can perform a network-settings test (new construction + wizard)
    Fix + update:
    * Dreamnetcast
    * RSS-Reader
    * Jukebox
    * Changed OSD & Video grabbing
    Interfaces WebIF:
    Recommendation:
    http://rapidshare.com/files/17668729...DM7000.img.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    13 Feb 2007
    Earth
    Post EDG-Nemesis-4.4_DM7000_BU 27.12.08
    Fur DM7000 Stick,HDD,CF
    Bitte mit Flashwizard installieren
    Emus:
    Evocamd. 2.17
    Mgcamd 1.31
    camd3 902
    CCcamd 2.0.11
    scam 3.29a
    New CS 1.62
    Einige Plugins:
    Tux Commander
    Und andere
    Alle Sprachen zur Auswahl
    Satan-k*yupdater
    Minicat-k*yupdater
    download :
    13 Feb 2007
    Earth
    Post Terminator hydra rel 6.8 DM 7000/7020
    TERMINATOR HYDRA REL 6.8 DREAMBOX 7000/20 (multiboot)
    Zitat:
    - 1.09.3 Basisversion
    - Neuheiten werden in grun dargestellt
    - Hydra team - Enigma base
    - Web Interface 5.9.7-Expert
    - kernel Linux version 2.6.9
    - gcc version 3.4.4
    - New Bootlogo sowie Infos -
    - Startbild eingefugt -
    - Startplatz ist ARD
    - Bouquet mit 4 Satpostionen ist (19.2-13.0-28,2-23,5)
    - TERMINATOR Bootlogo -
    - Busybox gefixt sowie erweitert Version 1.01 -
    - Anzeige der Softwareversion
    - kurze Info gefixt wurde die kleinere Sachen -
    - zb Settings , Plugins usw.
    - Ab Version 5.0-5.6 kein Standard FTP Passwort mehr
    - Ab Version 5.7 wieder Standard FTP Passwort
    - Ab Version 6.3-7.0 kein Standard FTP Passwort mehr ( Achtung )
    - NEW EMUS -
    - EMU Camd4 4.093 - Nur Intern Nagra 3 + NDS ( TESTVERSION )
    - EMU Scam 3.29a -
    - EMU MGcamd 1.30d + NewCS 1.61 -
    - EMU Evocamd 2.17c -
    - EMU Camd3 3900 -
    - EMU Newcamd 6.10 b -
    - EMU CCcam 2.0.9 -
    - EMU g**x ( vorbereitet )
    - COMMON INTERFACE -
    - New Keys / Scce alle OK -
    - AKTUELLE -
    - Skins -
    - JTEC - IHAD Community -
    - JTEC - IHAD Community 16:9 -
    - Nemesis Greyline 3D
    - Nemesis Greyline CC
    - Nemesis Greyline CEC
    - Nemesis Greyline CEG
    - Nemesis Greyline CG
    - Nemesis Greyline 3DG
    - Orbitu Platine Skin -
    - Sprenger stone Hydra Edtion -
    - The Hydra Skin 4:3 -
    - The Hydra Skin 16:9 -
    - ascha 191 facile blue v1.0 beta -
    - ascha 191 facile red v1.0 beta -
    - Spiele -
    - Sudoku -
    - Tetris -
    - Plugins -
    00. Script Plgin
    01. Dreambox X-Weatherforecast
    02. Burn DVD Version 1.2
    03. G-Box Suite
    04. G-Box Center
    05. Key Settings
    06. Tux Box Commander
    07. DreamCAST 022 Internet Radio
    08. Teletext
    09. Recording . epl creator v2.00
    10. Dreamworld Key Info
    11. Dreamworld Menu v 2.3 ME
    12. Hacksat Key Download v9b
    13. DW Keyupdater v 4.0 N
    14. Satan Key updater
    15. Scam Edit v1.0
    16. NewCS config
    - New Languages -
    - English -
    - Nederlands -
    - Deutsch -
    - Turkçe -
    - French -
    - Danish -
    - Czech -
    - Greeks -
    - Spanish -
    - Italian -
    - Suomi -
    - Croatia -
    - Hungarian -
    - Norwegian -
    - Polish -
    - Portuguese -
    - Russian -
    - Slovenian -
    - Serbian -
    - Slovakian -
    - Svenska -
    - Arabic -
    - Urdu -
    - Icelandic -
    - Estonian -
    - Lithuanian -
    - NEW Unterstutzung u. Funktion -
    - PW Karte S01 NAGRA 2/3 OK
    - PW Karte S02 NAGRA 2/3 OK
    - PW Karte A01 NAGRA 2/3 OK
    - PW Karte A02 NAGRA 2/3 OK
    - PW Karte K01 NAGRA 2/3 OK
    - PW Karte K02 NAGRA 2/3 OK
    - PW Karte P01 NAGRA 2/3 OK
    - PW Karte P02 NAGRA 2/3 OK
    - PW Karte V13 NDS OK
    - Kabel Karte K01 OK
    - Kabel Karte K02 OK
    - Via 2.3 Originalkarten OK
    - Via 2.4 Originalkarten OK
    - Via 2.5 Originalkarten OK
    - Via 2.6 Originalkarten OK
    - Seca 2 Originalkarten OK
    - Irdeto 2 Originalkarten OK
    - Cryptoworks Originalkarten ORF , Easy TV , Digiturk usw.OK
    - Cryptoworks Arena Karten OK
    - Knotcard 1 OK
    - Knotcard 2 OK
    - Titanium 1 OK
    - Titanium 2 OK
    - Titancard 1 OK
    - Titancard 2 OK
    - Jupiter 1 OK
    - Jupiter 2 OK
    - Goldwafer 1-4 PIC 16f84 OK
    - Goldwafer 2 2-4 16f876/77 OK
    - Funcard 1-7 OK
    - AT MEGA 128 OK
    - AT MEGA 161 OK
    - AT MEGA 163 OK
    - AT MEGA 323 OK
    - Platinium OK
    - Bluewafer OK
    - ENIGMA OK
    - DIDEM OK
    - Zebra OK
    - Daytona OK
    - ANACONDA OK
    - GammaCard OK
    - GammaCard Plus OK
    - VistaCard OK
    - MINERVA OK
    - X in One Card OK
    - Mega PIC PCB - Pic 18F452 + EEprom 24LC256
    - CanaryCard (16F628 + 24C16)
    - EmeraldCard (16F628 + 24C64)
    - Singlepic 16F876, 16F627, 16F628
    - Opus 1.02-1.05 OK
    - M2 Karte OK
    - M2 Karte Plus OK
    - Wildcard OK
    - Kebap Card OK
    - Pentacard V3 r1 OK
    - Pentacard V3 r3 OK
    - Dreamcrypt Card OK
    - NEW Zusatzfunktionen -
    - Button Definition: -
    - BLAUER Button – Erweiterungen -
    - GELBER Button - Plugins -
    - ROTER Button - EPG -
    - GRÜNER Button - Unterkanäle -
    - TEXT Button - Videotext -
    - INFO Button – Programm Vorschau -
    - INFO 2x Button – Film Infos -
    - Diese Programme machen AUTOUPDATE ( AU ) -
    - ORF 1-2
    - ATV
    - Slovenien
    - Diese Programme Laufen -
    - ORF OK
    - ATV+ OK
    - MTV OK
    - VH1 - VH Classic OK
    - SLOVENIEN OK
    - MCM OK
    - RAI ITALIEN OK
    - BBC PRIME OK
    - Kingston OK
    - Xtramusic OK
    - Turner OK
    - Kabel Deutschland OK
    - Programm Anordnung TV -
    - Free TV Deutsch
    - Österreich
    - Schweiz
    - Premiere
    - Premiere Star
    - Premiere Entavio
    - Kabel Deutschland
    - Sport Extra/Bundesliga
    - Arena
    - Kinderprogramme
    - D+ Spanien
    - Spanien und Portugal
    - Hardcore
    - Softcore 24 St
    - Frankreich Pay TV
    - Frankreich C-Sat
    - ABSat ( Mit AU Programm )
    - Slovenien
    - Nachrichten
    - Wissenschaft
    - Musik POP & ROCK
    - Musik Klassisch
    - Polsat Digital
    - Cyfrowy Polsat
    - Cryfa +
    - Czech TV
    - Slovak TV
    - Holland
    - TV Vlaanderen
    - Italien Rai
    - Italien SKY
    - Nova TV
    - BSkyB
    - UPC
    - Einkaufssender
    - Informations Sender
    - Arabische Sender
    - Religion
    - Indien
    - Asien
    - ART
    - Programm Anordnung RADIO -
    - Deutsch
    - Österreich
    - Schweiz
    - Premiere
    - Kabel Digital
    - BBC
    - BSkyB
    - Vlaanderen
    - Holland gefixt
    - ABSat
    - Cryfa +
    - RAI
    - Slovenien
    - CSAT
    - Sky
    - Nova
    - Arabsat
    - Czech
    - Slovak
    - Zagreb
    - Belgacom
    - Globecast
    - M-Three-Satcom
    - RFI
    - NTH
    - Anleitung fur DVD HDD Betrieb -
    Den Ordner HDD entpacken und per FTP auf das Verzeichnis HDD gehen welches sich im Image befindet .Dort die beiden Verzeichnisse anlegen , und die Dateiattribute alle auf 755 stellen.
    - Anleitung zum Filme Brennen in der Dreambox 70X0 -
    - 01. Leere DVD einlegen in den Brenner
    - 02. Gelbe Taste drucken
    - 03. Burn2DVD Plugin auswählen und mit OK starten
    - 04. Film auswählen und mit ok bestätigen
    - 05. Gelbe Taste drucken ( Create DVD )
    - 06. Beide obriegen verzeichnisse nicht ändern
    - 07. Burnspeed auf 4x stellen ( lauft dann auf allen DVD Playern )
    - 08. Burn on the fly ( Aktiveren ) mit OK
    - 09. Delete tmp files ( Aktiveren ) mit OK
    - 10. Pal fur Europa so lassen
    - 11. 4:3 oder 16:9 Auswählen ( Standart ist 4:3 )
    - 12. Autoset new auf 10 min stellen ( Standart ist 5 min )
    - 13. Blaue taste drucken und mit OK ( Ja ) bestätigen
    - 14. Der Brennvorgang beginnt und nun warten bis er abgeschlossen ist
    - 15. Mit der Meldung ( Burn2DVD is finiseted ) ist die DVD Fertig
    - 16. Gelbe taste drucken und OK
    - 17. Auf Burn2DVD gehen und OK drucken
    - 18. Gelbe Taste drucken
    - 19. Grune Taste drucken
    - 20. Auf Eject CD/DVD media gehen und OK drucken
    - 21. Fertig ist die DVD
    Anleitug Tuxbox Commander K*y eingabe uber fernbedienung.
    1) Gelb auf der Fernbedienung fur Plugins
    2) Tuxbox Commander und OK taste
    3) Links ist die entsprechende datei die man ändern mochte...zb. fur MgCamd die Softcam.K*y datei.
    Bei meinem Backup habe ich das so gespeichert.Bei anderem image muss jeder selber machen.
    4) Die Softcam.k*y datei ist markiert dann die 4 fur BEARBEITEN drucken.
    5) Jetzt nur noch mit oben/unten taste scrollen, den richtigen Provider wählen
    und mit OK die zeile frei machen und den K*Y ändern. Unten ist auch eingeblendet was mit entsprechenden
    Fernbedienung taste eingegeben werden kann.
    6) Jetzt raus mit LAME...auf die frage SPEICHERN mit JA beantworten.
    7) Emu neustarten
    - Hier die Installations -
    !!! Achtung mit Flashwizzard 6.3 einspielen
    !!! Achtung beim einspielen haken bei Settings aus aktivem Image ubernehmen entfernen
    DOWNLOAD :
    http://www.sendspace.com/file/0hnok7
    13 Feb 2007
    Earth
    Post Imagen KGD 2.10 dm7000 y dm7020
    Version Dm7000 (Flash, Multiboot) y Dm7020 (only Multiboot)
    Lo Primero querias pedir disculpas por tardanza que por problemas ajenos al Team se retraso todo un poquito pero bueno de momento vamos a publicar las imagenes siguientes:
    Version Dm500s, Dm500c y equipos compatibles (Flash, Multiboot)
    Version Dm7000 (Flash, Multiboot) y Dm7020 (Solo Multiboot)
    Version Dm500plus (se publicara esta semana o la siguiente como mucho)
    Botones:
    Azul(Panel KGD)
    Azul Pulsado 2 seg. Infobar (Muestra la info ECM del canal que se esta viendo)
    Amarillo(Plugins)
    Rojo (EPG)
    Help(Ayuda)
    En esta nueva version 2.10 hemos intentado seguir con nuestro objeto que era la estabilidad y creo que lo seguimos haciendo, a ello le hemos sumando un nuevo web interface mejorado y renovado, al igual que todo el OSD, skin, infobar, etc.. con cambios y mejoras totalmente nuevas, tambien hemos corregido algunos bugs y sugerencias de versiones anteriores.
    El panel KGD se modificado con las siguientes novedades ahora, en este, informa del estado del inadyn, dropbear y programador de tareas por si en algun momento no estubiera cargado o funcionando tambien hemos añadido un barra que indica el espacio de RAM que estamos usando.
    En configuraciones hemos añadido un aviso si la memoria es menor a 100Kb que es muy frecuente con el uso de cams y si se diera el caso lo mejor seria reinicar con esto la gente puede evitar los famosos cuelgues que no son por la imagen sino el 99% de las veces porque la memoria RAM es muy justa y se queda sin ella y las cams suelen ser las causantes, tambien si se hace frecuente esto se puede desactivar el aviso en configuraciones.
    Y tambien hemos añadido la opcion de activar/desactivar dropbear que es un cliente/servidor SSH que es usado por ejemplo en el Plugin Español EnviarEMMs.
    Otros de los cambios esta en el OSD con nuevos menus, opciones, skin, etc.. que podreis apreciar en las capturas
    En el EPG hemos hecho mejoras, tanto en el webif como el infobar ahora esta añadido un buscador EPG que permite buscar Eventos.
    El Web interface es donde mas trabajo y cambios hemos hecho, se ha hecho todo nuevo a parte de la estetica se ha mejorado la funcionalidad, se añadidod el EMUMANAGER que permite a distancias controlar nuestras cams, activandolas, cambiandolas, etc.. ademas de poder ver en el mismo la info ECM del canal que se esta viendo. Tambien podreis cargar vuestras cams desde el exterior poniendo este comando:
    http://IPDream/cgi-bin/Emu?start=nombrecam_emu
    http://IPDream/cgi-bin/Emu?start=nombrecam_cam
    Tambien en el webif hemos añadido una mejora muy importante que es el Zapstream ahora podras ver en tu propia red o fuera de ella la dream desde el Webif con ninguna PIXELACION, simplemente bajando la ultima version del VLC e instalar con los plugins firefox o Ie, SIN CONFIGURAR NADA MAS ni en al dream ni el PC, solo tendras que pinchar en el boton VLC o Vpid para poder ver el canal sintonizado. Tambien hemos arreglado el WEBxTO y ahora va mucho mas fluido que antes.
    Respecto a cambios internos del enigma vamos a destacar los mas importantes ahora la imagen funciona perfectamente en Multiboot en modelos DM500x que antes tenian problemas, tambien se ha añadido uno Accesos directos nuevos para la gente que tienen montados FREENAS tengan mas facilidades,etc... Y el MAS IMPORTANTE SE HA SOLUCCIONADO UN PROBLEMA general que tienen todas las imagenes las del KGD versiones 2.0 o inferiores y tambien las demas de vulnerabilidad, ya que cualquier persona desde la fuera de la red puede extraer informacion de tu dream si se tiene abierto el puerto 80 al exterior, asi que aunque en esta version esta soluccionado LO MEJOR ES NO DEJAR EL PUERTO 80 ABIERTO FUERA DE TU RED INTERNA. Esto ha sido soluccionado por algunos teams sacando nuevas versiones de sus imagenese asi que informaros de la imagen que tengais y si se ha soluccionado el problema
    Por ultimo queremos dar las gracias muy ESPECIALMENTE A:
    JaBaT, JHOSUA, YOP por todo el curro que se han pegado en la elaboracion del skin... que sin ellos no hubiese sido posible hacerlo.
    JaBaT, desarrollador del webIf.
    A Foro-Pagando por la ayuda prestada y por dejarnos este rinconzito donde estamos.
    Y todos los betatester Laisas, Krusty, Seku, Pinguino, Nozul, pepibumur, pakilloreal y seguro que alguien mas me dejo, lo siento.
    Por ultimo darle las gracias al PliTeam por cedernos su Zapstream y en especial a Sjaaky y pieterg.
    download :
    http://www.sendspace.com/file/ibjl90
    02 Feb 2007
    Default SifTeam 1.9.3D dm7000
    CAMBIAMENTI:
    1) Cambiato il CVS alla versione 13.02.2009 (con supporto a piu' file audio, .ogg ecc..)
    2) Nel parental Control si puo' bloccare l'accesso al pannello EMU
    3) In tutte le versioni sono presenti i comandi "ifup" e "ifdown"
    4) Per guadagnare spazio sono stati rimossi:
    "streamts" ..si deve installare dal pannello
    il secondo boot-logo ..si puo' installare dal pannello
    5) Si puo' scegliere di non eliminare i pacchetti scaricati (menu' avanzato)
    6) Aggiornato la libreria libc.so.6 (a tutti i modelli, ex: samba non funzionava piu')
    7) Modificato script avvio Qbox-one (ora il wifi si riavvia bene)
    8) Nel 200 e' stato inserito l'eseguibile e diverse librerie dell'openvpn
    9) Aggiunto nel pannello la possibilita' di montare un disco esterno USB (per la presa posteriore nel Qbox-one)
    NOTE:
    Per la versione ipbox-200@64mb si deve:
    1) Installare l'immagine del 200 normale
    2) Installare il file "serial_uboot_64.img"
    ..entrambi con Flashtools o Flasher
    Programmi:
    Per avviare programmi personali, valido per tutte le immagini SifTeam: Aggiungere il comando voluto in /var/etc/rcS.d/S99user_start.sh in fondo al file (ci sono gia' presenti diversi esempi pronti all'uso, basta decommentarli rimuovendo il simbolo #)
    Tips:
    Per entrare nel Pannello di Controllo se ci si trova nel Pannello Emu basta premere il bottone giallo, funzione aggiunta per l'uso nella WebIf.
    Per aprire il menu' Script mentre ci si trova nel Pannello di Controllo basta premere lo 0 (zero).
    Errori:
    In caso si presenti l'errore "..curl_global_init.." con qualche plugin, dopo l'installazione del medesimo, basta riavviare enigma o il decoder. (deve rileggere la nuova libreria installata dal plugin)
    * L'opzione Muovi OSD non e' piu' presente in enigma perche' la DreamMultimedia ha occupato
    il bottone rosso nelle opzioni OSD
    Si puo' installare come plugin esterno.
    ** Il Qbox-one non ha ancora tutte le funzioni degli altri modelli, ad esempio il firewall per
    ora non funziona (altrimenti il kernel non e' compatibile con il modulo wifi della duolabs)
    ...diciamo work in progress ...ma e' perfettamente utilizzabile con le funzioni base.
    Forse la cosa che manca di piu' e' la funzione del tasto
    premuto per >1sec. (per piu' di un secondo), per entrare nel pannello di controllo si deve
    passare da: tasto blu -> tasto giallo
    English
    Changes:
    - CVS updated to 02.02.2009(more audio files are supported)
    - Now you can block ,trought parental control,the access to emu panel
    - commands 'ifup' and 'ifdown' are available
    - Re:"streamts" that is available on online panel
    the second bootlogo is available also by online panel
    re(only on ipbox versions)some files...they are always available online
    - You are now able to left downloaded addons(advanced menu)
    - Libc.so.6 updated
    - start script of qbox one fixed(wifi won't lose settings at reboot)
    - 200 image has already buil-in executable and any library of openvpn
    -you can mount an external hdd on qbox(added option on advanced panel)
    Note:
    For the version ipbox-200@64mb you must:
    1)install the normal img for ipbox200
    2)install "serial_uboot_64.img"
    both with flashtools or Flasher
    * About Programs:
    For all sifteam images, on /var/etc/rcS.d/S99user_start.sh you can choose a program to start(there are already some commented examples..remove "#" to active them)
    Tips
    To enter in Control Panel from Emu panel you can press the yellow button (added also on webif)
    The menu Script can be opened from Control panel pressing 0(zero)
    To change the positions of Channel name or Clock you can modified by telnet the values
    (Horizontal)(50 & 80 are the default values)
    echo 50 > /var/etc/SifTeam/conf/altOraOSD
    echo 80 > /var/etc/SifTeam/conf/altCanaleOSD
    (Vertical)(10 is the default value)
    echo 10 > /var/etc/SifTeam/conf/oriOraOSD
    echo 10 > /var/etc/SifTeam/conf/oriCanaleOSD
    Errors:
    If the following message appear "..curl_global_init.."...please restart enigma(Menu-5-restart enigma)
    * The option Move OSD is no longer available but you can install it as external plugin
    To use the old /Var you should edit the file /var/tuxbox/config/enigma/config
    and change the text "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/golden.esml" in
    "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/bluzzy3_adv.esml"
    ** The Q-box has not all the functions of the other boxes...for example to open the Control Panel you must press blue>yellow
    Enjoy Sif-team fans
    http://rapidshare.com/files/20580564...D-7000.img.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    13 Feb 2007
    Earth
    Post Backup_SifTeam-1.9.3D-7000&7020.im_multiboot
    Backup_SifTeam-1.9.3D-7000&7020.im_multiboot_BY_ANTR@G
    Emu
    CCcam 2.0.11
    Evocamd 2.17
    Mgcamd 1.31
    Camd 3.902
    Scam_9.29a
    Plugins
    CCcam Info
    Cryptinfo
    keydownload
    TuxBox Commander
    LCD Animation Player
    Total Football
    WeekEOG 3.2b
    Picon-Full-0.7
    Settings
    Vhannibal Dual Feed
    key Incluse
    All Languace
    BY_ °°ANTR@G°°
    download :
    http://rapidshare.de/files/45880725/...NTR_G.rar.html
    02 Feb 2007
    Default DM7000 Evolution 2.1
    Technical Infos:
    CVS Version: 05.03 2009
    Linux kernel version: 2.6.9
    Web Inteface 6.0.4-Expert
    Busybox 1.01
    BLUE - Blue Panel (Emu Addons)
    YELLOW - plugins
    RED - EPG
    GREEN - subservices
    Blue Panel Info:
    Start/Stop Emu
    Green - News
    Red - Sys Info
    Blue - Addons
    Yellow - Settings
    Addons info:
    Download Addons - Emus,keys,Plugins,Setting....
    Manual Install Addons tar.bz2
    Delite Addons
    -------- New in Evolution 2.1------------
    Add USB Manager
    Add User script
    Add Show EPG in Infobar from EPG-Cache
    Add Gbox/Cccam/Mbox/Mgcamd/Evocamd info in infobar
    (decode,dns,hops,ecm time,dist,level,peers,cards,caid,pid,provid)
    Add crond,crondtab
    Small change in blue panel add icons in settings option
    Small changes in epg
    Fix libc.so.6
    Fix emu start up
    Fix some bugs with not working plugins on Evolution 2.0
    Change Dark Center skin for more osd information
    New satellites.xml with latest TP-s
    New feeds for news reader(you can add you own feeds var/etc feeds.xml)
    And more...................
    Many new stuff in cvs.......
    Max var image
    http://www.sateliti-upload.info//ind...reambox%207000
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default PLi® Jade2 Dm7000 20090317 Rev.6300
    22-03-2009] PLi® Jade2 Enigma1 images released
    A new Enigma1 PLi® Dreambox release is available for download.
    The Original Enigma1 PLi® Jade2 suite contains the following images:
    * PLi®-Jade2-DM500 (regular and maxvar)
    * PLi®-Jade2-DM500+ (Plus)
    * PLi®-Jade2-DM600
    * PLi®-Jade2-DM5600/5620
    * PLi®-Jade2-DM7000
    * PLi®-Jade2-DM7020
    Use the downloadsection on our website to be sure to download our original PLi® images.
    Direct download: http://www.pli-images.org/downloads.php
    See below for fixes & features since the initial PLi® Jade release
    New features highlights:
    - New tuxtxt plugin
    - Tuxtxt subtitling (enable tuxtxt caching to get this feature)
    - Current and next EPG can be switched in service selector using audio key
    - Added "browse" selection in various menus
    - Timeshifts can be recorded on a separate location now
    - Selectable remote control channel
    More new features:
    - CVS Repository 11/01/2009
    - PLi® Repository 18/03/2009
    - Update to CCcam 2.0.11 for normal DM500 image and DM56x0 image
    - Default CCcam selected in cam setup for non-maxvar DM500, DM56xx
    - Updated encoding.conf
    - Removed movieplayer in DM500 maxvar image(image became too large, it's downloadable now)
    - Disable AC3, teletext stream recording added
    - web-x-tv: added support for vlc 0.9.x
    - Automatic LinuxExtensions correction for cifs mounts. Improves NAS compatibilty
    - Added teletext as programmable yellow/blue button
    - Support for slave harddisk on DM7020
    Fixes:
    - Web interface timer menu fixes
    - Let exit key on a DM500 repeat to quit menus quickly
    - Take time start and stop offsets into account if a recording is added using webif
    - Fixed the save button (Green button) if unintentionally pressed in sat config screen
    - Harddisk format fixes
    - Default small silver remote for the DM500 and DM500+
    - Zapstream fixes
    - Solved wrong genre in webif channel EPG
    - "x% in use" updated in filemode now
    - Fixed service selector too near to window border
    - Fixed possible problems if /var is moved to a network share
    - RSS plugin fixes
    - Fixed dropbear plugin
    - Backup/restore fixes
    - MV fix for illegal date/time
    - Remove timeshift options for boxes which cannot timeshift
    Languages:
    - Spanish language update by Corvus
    - Estonian language update by Indrek
    - Dutch language update by dAF2000
    - Czech language update by ims
    Known bugs:
    - Picons may not work if a satellite has both Ku and C band channels
    - Unmounting network shares may not work all times
    - Network settings may not be restored in backup/restore
    See our PLi® Wiki for more answers on your questions...
    Many low level changes fixes and other updates...
    http://www.pli-images.org/downloads....download_id=61
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    15 Apr 2009
    Default Re: DM7000 Evolution 2.1
    Am incercat imaginea, este tare, multumesc.
    Member Beginner Gogoman's Avatar
    07 Jun 2009
    Default Tdw 1.70 dreambox 7000 multiboot
    TDW 1.70 DREAMBOX 7000 MULTIBOOT
    EMULATOARE
    - EMU CCcam 2.1.1 -
    - EMU MGcamd 1.31 -
    - EMU Newcamd 6.10b -
    - EMU Scam 3.50 -
    PLUGIN
    - Tux Box Commander -
    - Satan Key updater -
    - Hacksat Key Download v9b -
    - Language Preference -
    -Luxsat Softcam Update -
    SETTING
    Motor 62.0E-30.0W,2\1Diseq
    Lista Favorite
    - Digi Tv -
    - Akta Tv -
    - Focus Tv -
    - Adult -
    - Premiere-
    - Polsat -
    - Rai -
    - Libere -
    - Maghiare -
    SKIN
    - AD_TECH GEMINI -
    - ULUS TDW BLUE1 -
    http://rapidshare.com/files/23475651..._multiboot.rar
    07 Jun 2009
    Default Evolution 2.2.DM7000_multiboot
    EMULATOARE
    - EMU CCcam 2.1.1 -
    - EMU MGcamd 1.31 -
    - EMU Newcamd 5.28 -
    - EMU Scam 3.50 -
    - EMU Gbox 2.25 N3 -
    PLUGIN
    - Satan Key Manager -
    - CCcam Info -
    - DreamBox key Editor -
    - G-Box Center -
    - G-Box Suite -
    - EasyLogo -
    SETTING
    Lista Favorite
    - Digi Tv -
    - Akta Tv -
    - Focus Tv -
    - Adult -
    - Premiere-
    - Polsat -
    - Rai -
    - Libere -
    - Maghiare -
    SKIN
    - EvolutionV1_Extended -
    - BlueLine x 2 -
    - Vali x 2 -
    - DarkCenter -
    http://rapidshare.com/files/24181663..._multiboot.rar
    07 Jun 2009
    Default TERMINATOR-HYDRA-7.4_Multiboot
    - gcc version 3.4.4
    EMULATOARE
    - EMU Camd4 4.093 - Pentru Nagra 3 + *** ( VERSIUNE TEST )
    - EMU Scam 3.29a -
    - EMU Camd3 3900 -
    - EMU CCcam 2.0.9 -
    PLUGIN
    - Script Plgin -
    - Dreambox X-Weatherforecast -
    - Burn DVD Version 1.2 -
    - G-Box Suite -
    - G-Box Center -
    - Key Settings -
    - DreamCAST 022 Internet Radio -
    - Recording . epl creator v2.00 -
    - Dreamworld Key Info -
    - Dreamworld Menu v 2.3 ME -
    - DW Keyupdater v 4.0 N -
    - Scam Edit v1.0 -
    - NewCS config -
    SETTING
    Lista Favorite
    - Digi Tv -
    - Akta Tv -
    - Focus Tv -
    - Adult -
    - Premiere-
    - Polsat -
    - Rai -
    - Libere -
    - Maghiare -
    http://rapidshare.com/files/24212625..._multiboot.rar
    03 Aug 2009
    Default Re: TERMINATOR-HYDRA-7.4_Multiboot
    Eyxaristw
