Results 1 to 15 of 15
Thread: Imagini DM 600PVR
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Imagini DM 600PVR
    13 Feb 2007
    Earth
    Post scvs-image-dm600pvr-20081209214713
    Beschreibung:
    Enigma = 09.12.2008
    Plugins = 09.12.2008
    Treiber/Module = 22.08.2008
    Second Stage Bootloader = 66
    Kernel = 2.6.12r5
    Eigene SCVS Bootlogo's by yvessun und Skin by kerni
    satellites.xml - enigma by IhaD
    FAT, VFAT,NTFS, MSDOS, IPTABLES Treiber im Kernel
    MHW EPG
    EPG Private
    Webinterface Expert
    pmt.patch
    automount
    dccamd aus dem Image entfernt. Kann per Internet nachinstalliert werden
    Zitat:
    NOTE: build 200812092247: started
    OE Build Configuration:
    BB_VERSION = "1.6.8"
    OE_REVISION = "<unknown>"
    TARGET_ARCH = "powerpc"
    TARGET_OS = "linux"
    MACHINE = "dm600pvr"
    DISTRO = "opendreambox"
    DISTRO_VERSION = "1.5.0"
    TARGET_FPU = "soft"
    download :
    http://fbx.ro/x9rago7wqp29gld5
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Gemini 4.60 DM600
    Gemini v4.6:
    Technical Infos:
    * Enigma of: 19.12.2008
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet
    * adding additional functions via internet from the Gemini-Server and install them automaticly
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you realy need
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changeing the name and settings via own menu.
    * Creation of a 2nd socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
    * Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
    * added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
    * Display of EMM, ECM or "Expertinfos" are switchable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CDROM/DVD no matter using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    * Device-Manager for HDD / DVD / CF / USB
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded!
    EPG
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * change the settings for recording (before Time, after-recording time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    * the Jukebox, Please install as addon.
    Recordings:
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
    New:
    * Webcam Viewer for viewing images from the Internet, configureable via XML config (only Still, no interval as we have at E2)
    * Now you can perform a network-settings test (new construction + wizard)
    Fix + update:
    * Dreamnetcast
    * RSS-Reader
    * Jukebox
    * Changed OSD & Video grabbing
    * have a look in the CVS
    Interfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
    http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
    We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
    This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We assume no liability for direct or indirect damage.
    http://rapidshare.com/files/17675844...192032.nfi.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    13 Feb 2007
    Earth
    Post Dm600pvr Enigma2 Test 6-12-2008
    Dm600pvr Enigma2 TestImage of 081206
    New :-
    Enigma2 of srcdate 081121
    7 day epg from bskyb, skyitalia, nova gr, nrk, svt(viasat), tvprofil(rtl etc)
    Mountmanager for cifs and nfs mount
    Infobar date language options
    Plugins YouTubePlayer and VlcplayerExtended included
    New addon download manager
    Special shortcut : Button 0 -> Extra Setup
    7 day epg :
    Based on plugin e2_loadepg. If a channel does not show epg, please edit the channellist.conf files in folder /usr/lib/enigma2/python/DF/e2_loadepg/dl_modules.
    The format for a channel in the list is - id=n,channel name[,provider name] where :-
    n=0 (channel NOT selected for epg); n=1 (selected)
    channel name and provider name are the name of the channel and its provider in /usr/share/enigma2/lamedb. The provider name can be omitted if is same as the Default Provider at the top of the list. If no provider name in lamedb then use the word noprovider.
    The epg days can be changed in the .conf files in the /dl_modules folder.
    Download addons :
    Button 0 -> Addonmanager -> Download addon -> Download updated panel -> select.
    After install of Updated panel other items can be dowloaded.
    Before starting softcam first time Restart dreambox.
    Mount cifs and nfs:
    First go to Button 0 -> extraSetup -> UserConf -> Edit command -> Press OK and edit command.
    Next time you select Video button (for playback) or Red button (for recording) you get a choice for dreambox hdd or cifs or nfs hdd.
    Also as before :-
    Emumanager and Scriptmanager
    Addonmanager
    Webinterface
    Recording and streaming improvedYuv enabled
    Picon
    (1) Put the Enigma2 picon folder in '/media/cf/', or, '/media/usb/', or (2) make a new folder 'picon' with selected icons and put this folder in /usr/share/enigma2/
    ftp userscripts to /etc/scripts.
    Crond :-
    Edit by ftp the crontab file (in /etc) as usual with time and command etc. Start Crond from setup window and reboot. An example crontab is in the image which will create a folder cronresult in /etc. Crond will run after future reboots until stopped.
    Inadyn :-
    Edit the file inadyn.conf in /etc with your inadyn info e.g. usrname, password, alias. The example file is for the dyndns.org setup.
    Telnet command > /usr/bin/inadyn --h for other options. Inadyn can be started and stopped from the setup window and will run after future reboots until stopped.
    Also - view inadyn.log.
    pmt.tmp :-
    The image is set to include pmt.tmp in /tmp from start. If any emu start kills it, it can be restarted from the setup window. Check pmt.tmp window.
    Skins :-
    Default Skin - Nemesis.GlassLine .
    Streaming to pc:-
    Streaming (both viewing and recording on pc hdd) to pc is possible with TuxvisionE2.
    Special thanks to :-
    Gutemine, Cassiopeia 2000, Hein Holz for advice and various patches, tunhj1 and LeoGR and other friends for testing and suggestions, and of course elektronikfreak for finding bugs.
    All log files can be found in /tmp.
    No emus or keys included.
    download :
    13 Feb 2007
    Earth
    Post DM 600 PVR : EDG-Nemesis 4.4
    EDG-Nemesis 4.4
    Technical Infos:
    * Enigma of: 21.11.2008
    * Linux version 2.6.9
    * GCC 3.4.4
    * Busybox 1.01
    * Tuxtxt v. 1.99
    * for use in flash or MB (via NFS, HDD)
    * Date image 24.12.2008
    * OE 1.5
    * Bitbake 1.6.8
    Function Buttons:
    * BLUE - Nemesis Panel
    * BLUE > 1s - ECM INFO, EMM INFO e PID INFO
    * 2x BLUE - Addons
    * YELLOW – Plugins
    * YELLOW > 1s – EMU - CS Info
    * GREEN – subservices
    * GREEN > 1s – EPG Control Center
    * 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
    Global News:
    * Fix CVS for minor bugs about USB 2.0 port
    * Nemesis Panel 4.4
    * Cam Manager 4.4
    * Fix green button in play mode
    * Minor bug fix
    New CVS feature:
    * Add Plugin reorder
    * Add Plugin rename
    * Add listbox shortcut (0-9, red, green, yellow and blue)
    * Add Permanent timeshift (beta)
    * And lot of bug fix (see h**p://cvs.tuxbox.org for more info)
    EPG Control Center:
    * Hard recoded
    * Integrated EPG loader directly form Sat, (Upgradable)
    * Full support for EPGui, MVepg, WeekEPG and EPGFind.
    * Manual EPG download
    * Scheduled EPG download, via Enigma Timer list
    * Select channel to download
    * Reorder channel for EPGui via GUI interface
    * Update EPG channel list, and channel name
    * Full support for EPG Themes (Upgradable)
    * Lot of EPG loader info
    User Script:
    * Partially recoded
    * Add script cancel button
    * Minor bug fix
    Move var:
    * Partially recoded
    * Minor bug fix
    Special Thanks to our developper MaxZ4 for EPG loader
    Special Thanks to Lukkino for opentv source code
    Regards:
    - developper and betatester.
    - Skin by Matrix10
    - New Bootlogo 4.4 and graphics by Server
    !!! WARNING - IMPORTANT DISCLAIMER:
    !!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
    !!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
    download :
    http://www.sendspace.com/file/x4h6ls
    13 Feb 2007
    Earth
    Post NewNigma2 V2.3
    NewNigma2 V2.3
    for DM 600 PVR
    Data:
    · Enigma2 : 24.12.2008
    · Enigma2-plugins : 24.12.2008
    · NewNigma2-plugins : 24.12.2008
    Changes:
    · minor plugin bugfixes
    · VirtualKeyboard added in autofs-editor
    · Turkish Language added
    · Lithuanian Language added
    · Finnish Language added
    · New Picons for all supported Satellites
    · New Standard Skin for DM800 and DM8000: DreamTV-HD Skin thx to Kerni for that great Skin
    download :
    http://www.sendspace.com/file/jex40j
    13 Feb 2007
    Earth
    Post NewNigma2-image-dm600pvr-v2.3.1
    .... English ....
    Data:
    · Enigma2 : 27.01.2009
    · Enigma2-plugins : 27.01.2009
    · NewNigma2-plugins : 27.01.2009
    · Treiber: 22.08.2008
    · Secondstage: „66“
    Changes:
    · Minor bugfixes
    · New version of UShare
    · New drivers
    List:
    * dreambox-dvb-modules
    * ushare 1.1a
    * enigma2
    * enigma2-plugin-extensions-webinterface
    * enigma2-plugin-extensions-autotimer
    * enigma2-plugin-extensions-epgrefresh
    * enigma2-plugin-extensions-cdinfo
    * enigma2-plugin-systemplugins-videomode
    * enigma2-plugin-systemplugins-positionersetup
    * enigma2-plugin-systemplugins-satfinder
    * enigma2-plugin-extensions-graphmultiepg
    * enigma2-plugin-extensions-fritzcall
    * enigma2-plugin-newnigma2-picon
    * enigma2-plugin-extensions-imdb
    * enigma2-plugin-newnigma2-menu
    * enigma2-plugin-newnigma2-usbmanager
    * e2fsprogs-mke2fs
    * e2fsprogs-e2fsck
    * dosfstools
    * gst-plugin-cdio
    * kernel-module-cdfs
    * libcddb
    * libcdio
    download :
    http://www.sendspace.com/file/wsfl8a
    13 Feb 2007
    Earth
    Post Imagen KGD500plus 2.10 Español, Deutsch y Portugue
    Imagen KGD500plus 2.10 Español, Deutsch y Portugues
    Vamos a hacer un poco de analisis de este deco el modelo DM500plus, en principio este deco parece como el dm500s pero su potencial es ENORME en comparacion con su antecesor.
    Despues de investigarlo a fondo hemos conseguido sacarle el maximo provecho y hemos echo una imagen a su medida, aplicando varios cambios en el enigma hemos conseguido una estabilidad muy grande al estar ONLINE un mes funcionando con dos cams simultaneamente sin ningun problema, reinicios, ni nada por el estilo, todo ello sin llegar nunca a ocupar el maximo de RAM disponible que son 96MB.
    En cuanto a la flash dispone de 32MB por lo que te olvidas de problemas de espacio en esta version 2.10 hemos incluido los siguientes plugins:
    Blindscan(Busqueda ciega - FEEDs)
    Links Web Browser
    E-mail
    Itsy Package Management System (Permite instalar y desinstalar paquetes IPKG)
    Modem Internet
    Movieplayer
    Teletext
    Tuxbox Commander
    El plugin BlindScan para busqueda ciega sacaremos un tuto en breve para explicarlo mejor aunque es muy sencillo su uso y las busquedas muy rapidas.
    Otro de nuestros objetivos era conseguir que este deco fuese totalmente compatible con modelos dm500x, 7000 y 56xx asi que todos los plugins, cams, configuraciones del FTP son totalmente compatibles gracias a los cambios de reestructuracion y librerias que hemos añadido.
    Las botones son las siguientes:
    Azul(Panel KGD)
    Azul Pulsado 2 seg. Infobar (Muestra la info ECM del canal que se esta viendo)
    Amarillo(Plugins)
    Rojo (EPG)
    Help(Ayuda)
    El panel KGD se ha modificado con las siguientes novedades ahora, en este, informa del estado del inadyn, dropbear y programador de tareas por si en algun momento no estubiera cargado o funcionando, tambien hemos añadido un barra que indica el espacio de RAM que estamos usando.
    Y tambien hemos añadido la opcion de activar/desactivar dropbear que es un cliente/servidor SSH que es usado por ejemplo en el Plugin Español EnviarEMMs.
    Otros de los cambios esta en el OSD con nuevos menus, opciones, skin, etc.. que podreis apreciar en las capturas. Ahora disponeis de dos versiones distintas para escoger y asi no ocupar espacio var con mas skins, tambien se han hecho todos los picons que trae la imagen interna desde cero osea nuevos y se han añadido todos los picons que faltaban del proveedor español.
    El Web interface es donde mas trabajo y cambios hemos hecho, se ha hecho todo nuevo a parte de la estetica se ha mejorado la funcionalidad, se añadidod el EMUMANAGER que permite a distancias controlar nuestras cams, activandolas, cambiandolas, etc.. ademas de poder ver en el mismo la info ECM del canal que se esta viendo. Tambien podreis cargar vuestras cams desde el exterior poniendo este comando:
    http://ipdream/cgi-bin/Emu?start=nombrecam_emu
    http://ipdream/cgi-bin/Emu?start=nombrecam_cam
    Tambien, en el webif, hemos añadido una mejora muy importante que es el Zapstream ahora podras ver en tu propia red o fuera de ella la dream desde el Webif con ninguna PIXELACION, simplemente bajando la ultima version del VLC e instalar con los plugins firefox o Ie, SIN CONFIGURAR NADA MAS ni en al dream ni el PC, solo tendras que pinchar en el boton VLC o Vpid para poder ver el canal sintonizado. Tambien hemos arreglado el WEBxTO y ahora va mucho mas fluido que antes.
    En los cambios del Enigma este modelo, el dm500plus, no tiene los problemas de vulnerabilidad que tenian los dm500s:
    VER ESTE ENLACE SOBRE EL PROBLEMA
    Otro de las cosas que hemos soluccionado es un BUG que tiene el enigma que no permite montar unidades Samba, sistema que usan por ejemplo los landisk o algunos HDD multimedia, ahora se pueden montar y desmontar desde el webif perfectamente cosa que con otras imagenes NO se PODIA,
    Asi a grandes rasgos es nuestra primera version para la dm500plus seguramente con la cantidad de cambios algo se nos ha olvidado comentaros pero os seguiremos informando de mas novedades.
    Por ultimo queremos dar las gracias muy ESPECIALMENTE A:
    JaBaT, JHOSUA, YOP por todo el curro que se han pegado en la elaboracion del skin... que sin ellos no hubiese sido posible hacerlo.
    JaBaT, desarrollador del webIf.
    A Foro-Pagando por la ayuda prestada y por dejarnos este rinconzito donde estamos.
    Y todos los betatester Laisas, Krusty, Seku, Pinguino, Nozul, pepibumur, pakilloreal y seguro que alguien mas me dejo, lo siento.
    Por ultimo darle las gracias al PliTeam por cedernos su Zapstream y en especial a Sjaaky y pieterg.
    DOWNLOAD :
    http://www.sendspace.com/file/avo91p
    05 Jan 2007
    Default Re: Imagen KGD500plus 2.10 Español, Deutsch y Port
    Attached Thumbnails se vad numai daca esti membru pe sat-univers!
    02 Feb 2007
    Default PB ENIGMA DM 600 Version 3.0
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 1.9.3D dm 600pvr
    CAMBIAMENTI:
    1) Cambiato il CVS alla versione 13.02.2009 (con supporto a piu' file audio, .ogg ecc..)
    2) Nel parental Control si puo' bloccare l'accesso al pannello EMU
    3) In tutte le versioni sono presenti i comandi "ifup" e "ifdown"
    4) Per guadagnare spazio sono stati rimossi:
    "streamts" ..si deve installare dal pannello
    il secondo boot-logo ..si puo' installare dal pannello
    5) Si puo' scegliere di non eliminare i pacchetti scaricati (menu' avanzato)
    6) Aggiornato la libreria libc.so.6 (a tutti i modelli, ex: samba non funzionava piu')
    7) Modificato script avvio Qbox-one (ora il wifi si riavvia bene)
    8) Nel 200 e' stato inserito l'eseguibile e diverse librerie dell'openvpn
    9) Aggiunto nel pannello la possibilita' di montare un disco esterno USB (per la presa posteriore nel Qbox-one)
    NOTE:
    Per la versione ipbox-200@64mb si deve:
    1) Installare l'immagine del 200 normale
    2) Installare il file "serial_uboot_64.img"
    ..entrambi con Flashtools o Flasher
    Programmi:
    Per avviare programmi personali, valido per tutte le immagini SifTeam: Aggiungere il comando voluto in /var/etc/rcS.d/S99user_start.sh in fondo al file (ci sono gia' presenti diversi esempi pronti all'uso, basta decommentarli rimuovendo il simbolo #)
    Tips:
    Per entrare nel Pannello di Controllo se ci si trova nel Pannello Emu basta premere il bottone giallo, funzione aggiunta per l'uso nella WebIf.
    Per aprire il menu' Script mentre ci si trova nel Pannello di Controllo basta premere lo 0 (zero).
    Errori:
    In caso si presenti l'errore "..curl_global_init.." con qualche plugin, dopo l'installazione del medesimo, basta riavviare enigma o il decoder. (deve rileggere la nuova libreria installata dal plugin)
    * L'opzione Muovi OSD non e' piu' presente in enigma perche' la DreamMultimedia ha occupato
    il bottone rosso nelle opzioni OSD
    Si puo' installare come plugin esterno.
    ** Il Qbox-one non ha ancora tutte le funzioni degli altri modelli, ad esempio il firewall per
    ora non funziona (altrimenti il kernel non e' compatibile con il modulo wifi della duolabs)
    ...diciamo work in progress ...ma e' perfettamente utilizzabile con le funzioni base.
    Forse la cosa che manca di piu' e' la funzione del tasto
    premuto per >1sec. (per piu' di un secondo), per entrare nel pannello di controllo si deve
    passare da: tasto blu -> tasto giallo
    English
    Changes:
    - CVS updated to 02.02.2009(more audio files are supported)
    - Now you can block ,trought parental control,the access to emu panel
    - commands 'ifup' and 'ifdown' are available
    - Re:"streamts" that is available on online panel
    the second bootlogo is available also by online panel
    re(only on ipbox versions)some files...they are always available online
    - You are now able to left downloaded addons(advanced menu)
    - Libc.so.6 updated
    - start script of qbox one fixed(wifi won't lose settings at reboot)
    - 200 image has already buil-in executable and any library of openvpn
    -you can mount an external hdd on qbox(added option on advanced panel)
    Note:
    For the version ipbox-200@64mb you must:
    1)install the normal img for ipbox200
    2)install "serial_uboot_64.img"
    both with flashtools or Flasher
    * About Programs:
    For all sifteam images, on /var/etc/rcS.d/S99user_start.sh you can choose a program to start(there are already some commented examples..remove "#" to active them)
    Tips
    To enter in Control Panel from Emu panel you can press the yellow button (added also on webif)
    The menu Script can be opened from Control panel pressing 0(zero)
    To change the positions of Channel name or Clock you can modified by telnet the values
    (Horizontal)(50 & 80 are the default values)
    echo 50 > /var/etc/SifTeam/conf/altOraOSD
    echo 80 > /var/etc/SifTeam/conf/altCanaleOSD
    (Vertical)(10 is the default value)
    echo 10 > /var/etc/SifTeam/conf/oriOraOSD
    echo 10 > /var/etc/SifTeam/conf/oriCanaleOSD
    Errors:
    If the following message appear "..curl_global_init.."...please restart enigma(Menu-5-restart enigma)
    * The option Move OSD is no longer available but you can install it as external plugin
    To use the old /Var you should edit the file /var/tuxbox/config/enigma/config
    and change the text "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/golden.esml" in
    "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/bluzzy3_adv.esml"
    ** The Q-box has not all the functions of the other boxes...for example to open the Control Panel you must press blue>yellow
    Enjoy Sif-team fans
    http://rapidshare.com/files/20591707...600pvr.nfi.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default PLi® Jade2 Dm600 20090317 Rev.6300
    22-03-2009] PLi® Jade2 Enigma1 images released
    A new Enigma1 PLi® Dreambox release is available for download.
    The Original Enigma1 PLi® Jade2 suite contains the following images:
    * PLi®-Jade2-DM500 (regular and maxvar)
    * PLi®-Jade2-DM500+ (Plus)
    * PLi®-Jade2-DM600
    * PLi®-Jade2-DM5600/5620
    * PLi®-Jade2-DM7000
    * PLi®-Jade2-DM7020
    Use the downloadsection on our website to be sure to download our original PLi® images.
    Direct download: http://www.pli-images.org/downloads.php
    See below for fixes & features since the initial PLi® Jade release
    New features highlights:
    - New tuxtxt plugin
    - Tuxtxt subtitling (enable tuxtxt caching to get this feature)
    - Current and next EPG can be switched in service selector using audio key
    - Added "browse" selection in various menus
    - Timeshifts can be recorded on a separate location now
    - Selectable remote control channel
    More new features:
    - CVS Repository 11/01/2009
    - PLi® Repository 18/03/2009
    - Update to CCcam 2.0.11 for normal DM500 image and DM56x0 image
    - Default CCcam selected in cam setup for non-maxvar DM500, DM56xx
    - Updated encoding.conf
    - Removed movieplayer in DM500 maxvar image(image became too large, it's downloadable now)
    - Disable AC3, teletext stream recording added
    - web-x-tv: added support for vlc 0.9.x
    - Automatic LinuxExtensions correction for cifs mounts. Improves NAS compatibilty
    - Added teletext as programmable yellow/blue button
    - Support for slave harddisk on DM7020
    Fixes:
    - Web interface timer menu fixes
    - Let exit key on a DM500 repeat to quit menus quickly
    - Take time start and stop offsets into account if a recording is added using webif
    - Fixed the save button (Green button) if unintentionally pressed in sat config screen
    - Harddisk format fixes
    - Default small silver remote for the DM500 and DM500+
    - Zapstream fixes
    - Solved wrong genre in webif channel EPG
    - "x% in use" updated in filemode now
    - Fixed service selector too near to window border
    - Fixed possible problems if /var is moved to a network share
    - RSS plugin fixes
    - Fixed dropbear plugin
    - Backup/restore fixes
    - MV fix for illegal date/time
    - Remove timeshift options for boxes which cannot timeshift
    Languages:
    - Spanish language update by Corvus
    - Estonian language update by Indrek
    - Dutch language update by dAF2000
    - Czech language update by ims
    Known bugs:
    - Picons may not work if a satellite has both Ku and C band channels
    - Unmounting network shares may not work all times
    - Network settings may not be restored in backup/restore
    See our PLi® Wiki for more answers on your questions...
    Many low level changes fixes and other updates...
    http://www.pli-images.org/downloads....download_id=60
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2009
    Default Darkstar2_DM600
    Nabilosat Enigma1 DarkStar II - DM600
    What is new in this DarkStar II DM600 ?
    KERNEL UPDATE TO 2.6.12 (it was from a very long time that Dm images was stopped to 2.6.9 kernel)
    Updated CVS: 08 August 2008
    The image has been completely recoded based on the latest CVS
    Updated Skin by porto
    New DarkStar II skin customized by porto
    Enigma 1 Integrated 8 Days Sky IT EPG
    Download 8 days Sky IT EPG, and have it integrated to Enigma1
    EPG Event Search
    Select a single channel EPG, press 0, enter a keyword and search for your preferred events
    EPG Channels Selection
    Customize the list of EPG channels to download. We reccomend to restart Enigma upon completing the selection
    EPG Channels Update List
    Update the EPG channels list when there are changes
    Standby after reboot
    Your DM will automatically standby after an accidental reboot, such as after a powercut
    Scheduled Reboot
    Schedule an automatic daily reboot
    Network fix
    This feature is for DM7020 versions
    Updated OpenVPN Plugin
    Openvpn fully integrated with plugin and graphical panel included
    Warning Do not download the OpenVPN plugin to your DM600. It is already included
    Plugin movieplayer included in image (alternative to Vlc)
    Fixed an old bug in Nabilosat images (hdd standby not working well). Thanks to Astemio for this
    Main Function Keys
    Button 1xOK = Light Info OSD
    Button 2xOK = Extra Info OSD
    Button Blue = Nabilo Blue Panel
    Button 2xBlue = Nabilo Extra Settings
    Button Yellow = Nabilo Yellow Panel - Plugins List
    Button 2xYellow = Nabilo Yellow Panel - Addons Manager
    Button Red = Current Channel EPG
    Button 2xRed = Select Channel EPG or MultiEPG
    Features
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma1 Analogic Clock
    Channel Orbital Position
    Signal SNR, AGC, BER
    Infobar Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Extra Settings
    Swap File Settings
    Inadyn
    Hard Disk Settings
    Nabilo EPG Settings
    Nabilo OSD Preferences
    Nabilo Scheduler
    Network Services Panel
    NFS Server Panel
    Mount Points
    System Info
    Dreambox
    Mount Points Info
    Process Info
    Memory Info
    Enigma Setup
    Bitstream
    Save
    Select/Start/Restart EMU
    2) Yellow Panel
    Forums
    Shoutbox
    Addons
    Scripts
    Addons Download Manager
    Manual Install Panel
    Addons Uninstall Panel
    Images Uninstall Panel
    Nabilosat Statistics
    Many thanks to the Beta Testers Team
    Black33, ^^Corrado^^, ^^Maximo II^^, greg, Matrix10, Porto, ^)0(^Nabilo^)0(^, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, frimmino, astemio, DeepDiver
    Credits
    Sky IT Epg fully integrated to Enigma 1 by the great MaxZ4.
    Many Thanks to lukkino (VDR-Italia) for opentv source code.
    Se descarca de aici
    02 Feb 2009
    Default PLi Jade 3 (update)
    For all DVB-S, DVB-C and DVB-T versions.
    Please only use the download section on our PLi® website to be sure you download our original PLi® software.
    - Fixed MediaHighway EPG for Dutch 'Canal Digitaal' and Belgium 'TV Vlaanderen' provider
    - Improved movieplayer
    More new features:
    - CVS Repository 31/05/2009
    - PLi® Repository 14/06/2009
    - CCcam updated to version 2.1.1 for normal DM500 image and DM56x0 image
    - MultiEPG channelnames are scaled too, just as the program name
    - Turkish and Dutch translations updated
    - Removed LAN selection box in network setup
    - The global (all satellites worldwide) satellites.xml updated 15/06/2009 (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal)
    Fixes:
    Languages:
    - Turkish language update by Kerem
    Known bugs:
    - There is maybe some rotor related bug in the Open Embedded boxes like the DM7020, DM600 and DM500Plus images.
    * An online internet fix for the rotor users will be released soon.
    More detailed info, Wiki, FAQ's, HowTo's, TechNotes and informationabout this and the previous PLi® releases can be found on the PLi® Website:
    Se descarca de aici
    Standard RSP member potty's Avatar
    23 Dec 2008
    Default gemini-4.70-dm600pvr
    Technical Infos:
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    Addons:
    * own Addon-Server via Internet, many addons with preview
    * Retreiving additional functions via internet from the Gemini-Server and install them automatically
    * Create your own Satellites.xml, which only contains the Satellites you really need
    * Manual installation or deinstallation of addons
    Camd:
    * Changing the name and settings with a menu of its own
    * Possibility of establishing a second socket (/tmp/cam1.socket)
    * Automatic test whether the box is connected with the internet or not (To be shown in the infobar)
    * Dropbear (SSH) can be set on and off (DM500 - DM7000: Standard->off)
    * Added editor to configure the cron-daemon
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Perfect for DVD- or Net-Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, not for DM500, DM500+ and DM56xx)
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins supports this function)
    * Display of EMM, ECM or "Expertinfos" are adjustable
    Files / Devices
    * Support for CD-ROM/DVD-drives ,regardless of using IDE or USB
    * Backup function
    * Two new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * Support of the bigger remote on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded automatically!
    EPG
    Extras:
    Recordings:
    New:
    * USB-Cardreaders can be activeted over the menu (BP->Extra->USB-CardReader
    * With the variables "show_gemini_server" and "show_camd_plugins" the addondownload and the server can be influenced (/var/etc/Gemini.conf)
    Fix + update:
    * After- and Prerun at records increased to 20 minutes
    * after a backup-restore the datas are available immediately, eg. bouquets
    * Crash at web-access to PMT-Pid without a valid PAT
    * Flickering of the popup "Channel change: Service not found"
    * Prevent the popup "Channel change: Service not found" while the rotor is moving
    * have a look at the CVS
    Interfaces WebIF:
    We'd like to thank everybody who participated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized by us, but must be developed by the CVS-Team
    This images doesn't contain any keys or softcams. Backups or other modified Images are not released by and won't be supported in any way!!!
    Recommendation:
    if several processes running in background. We take no responsibility for direct or indirect damages!
    Descarca aici!
