Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 94
Thread: incubusCamd pe Kathy = Cccam
  1. #46
    25 Jul 2007
    Default Re: incubusCamd pe Kathy = Cccam
    Pentru ghinionistii carora nu le porneste Incubuscam-ul pe configuratia data de Zildan Ii roga sa incerce asta.
    Cu ea am reusit sa fac si eu lumina.
    [Prov:FF00]
    card_server_url_0=cccam://<user>:<pass>@<hostname>:<port>
    [Servers]
    card_server_url_1=cccam://<user>:<pass>@<hostname>:<port>
  2. #47
    15 Nov 2007
    a reusit sa porneasca cineva incubusCamd_0_75 pe kathrein? ..... ca la mine nu vrea.
  3. #48
    Porneste inainte de e2 sau in standby, din key dar nu deschide.
    Cred ca ceva nu e legat bine in vers de e2.
  4. #49
    24 Mar 2009
    Hello,
    does anyone get Incubus higher than 0.55 running on the kathi?
    I tried 0.70 0.75 and 0.80
    nothing will run.
    only 0.55 runs and that very bad. have to restart it every few minutes because it freezes.
    Perhaps someone can help me to get a newer version running.
    Thanks
    Regards
    Alex
  5. #50
    RSP Enigma Team
    29 May 2008
    No version after 0.55 will run on kathy. You should try mbox, it's a lot more stable and most important, works on kathy.
  6. #51
    04 Jun 2008
    Ar putea cineva sa-mi explice daca s-a lovit de urmatoarea problema:
    Am instalat incubus 0.55, am pus fisierele de .conf si .prio la locul lor, am adaugat linia de cccam de doua ori, asa cum scrie la tutorial. Insa, emu-ul nu porneste nici mort, se opreste imediat, fara vreun mesaj de eroare sau ceva. Vreo sugestie?
  7. #52
    Mai verifica linia din server, vorbeste cu cel care ti-a dat-o.
  8. #53
    14 Nov 2008
    Quote Originally Posted by liviurosio View Post
    in conf file pune inainte de linia cu [PROV....] asta:
    decoder_type=1
    Apoi:
    [Prov:FF00]
    card_server_url_0=cccam://***********
    Apoi:
    [Servers]
    Da restart la box.
    Vezi daca merge.
  9. #54
    30 Dec 2008
    France
    what's the config for 3 servers CCcam ?
    [Prov:FF00]
    card_server_url_1=cccam://***********
    card_server_url_2=cccam://***********
    [Servers]
    I tested this, without succes
    Thanks a lot in advance
  10. #55
    11 Apr 2009
    hello for all
    i have kati ufs 910 white 2 enigma image on usb flash barry allen (aaf_sussex_revolutions_ba_image) & (AAFmod_E2-BA_Weihnachtsimage_TDT_rev600.tar.gz) but the incubusCamd not started
    on kati or any image how any can help me pleas whatiis a prablem?
    tanks
  11. #56
    O zi frumoasa! Snow's Avatar
    Quote Originally Posted by dreanew View Post
    [Prov:FF00]
    [Servers]
    I tested this, without succes :dance:
    on 0.55 you can use only one line so the config will be:
    [Prov:FF00]
    [Servers]
    on last 0.80 you can use more line but the config shoul be:
    [Prov:FF00]
    [Servers]
    card_server_url=cccam://***********
    more ex:
    [Prov:000000:CaID:0000]
    decoder_type=1
    card_server_url_0=cccam://user1:pas1@host1.no-ip.biz:12000 #12000=peer port
    card_server_url_1=cccam://user2:pas2@host2.no-ip.org:12000
    [Servers]
    card_server_url=cccam://user1:pas1@host1.no-ip.biz:12000
    card_server_url=cccam://user2:pas2@host2.no-ip.org:12000
  12. #57
    30 Dec 2008
    France
    Thanks a lot for your reply,
    but I did not know use the 0.80 version on the kathrein with enigma² RSP firmware.
  13. #58
    12 Apr 2009
    Could You please give a link for download new Incubus 0.80 what works on Kathrein UFS 910 enigma2 ?
  14. #59
  15. #60
    12 Apr 2009
    Quote Originally Posted by Snow View Post
    Thank You for fast reply!
    Can You please confirm that it works on Kathy UFS 910 e2 (for RSP latest e2 image?) ?
    I have just understood that 0.55 is latest working Incubus for Kathy UFS 910 , and the team has finished Kathy support???
