Results 1 to 2 of 2
Thread: dvdrom
    30 Sep 2008
    Default dvdrom
    salut! am un asus f3jc si de ceva vreme dvdrom nu mai vrea sa masterizeze.
    am tot cautat solutii dar se pare ca e blocat ceva din setari.
    ma poate ajuta cineva?
    Multumesc
    30 Sep 2008
    Default Re: dvdrom
    Windows Vista 6.0
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 9.0.9.100
    Internal Version: 9, 0, 9, 100
    Recorder: <HL-DT-ST DVDRAM GSA-T10N>Version: PR03 - HA 1 TA 0 - 9.0.9.100
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default
    CD-ROM: <HL-DT-ST DVDRAM GSA-T10N >Version: PR03 - HA 1 TA 0 - 9.0.9.100
    === Scsi-Device-Map ===
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-T10N E: CdRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 1022MB (1047068kB)
    Free physical memory: 371MB (380776kB)
    Memory in use : 63 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    8.10.2008
    Scrivi Immagine DVD
    17.10.12 #1 Text 0 File SCSIPTICommands.cpp, Line 450
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    17.10.12 #2 IMAGEGEN -10 File ImageGen.cpp, Line 449
    Image was written as DAO.
    DAOI:
    MediaCatalogNumber = ''
    TocType = 0x00
    Finalized = 1
    First/Last Track = 1 / 1
    1: ISRC = ''
    Blocksize = 2048
    TrackMode = 'TRM_DATA_MODE1'
    TrackConfig = 0x00
    First/Last Index = 0 / 1
    Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4655611904
    CUES:
    MTYP: Mediumtype = DVD (old format) (0x1C)
    Image file name: <C:\Users\user\Documents\mumia.nrg>
    17.10.12 #3 Text 0 File Burncd.cpp, Line 3563
    Turn on Disc-At-Once, using DVD media
    17.10.12 #4 Text 0 File DlgWaitCD.cpp, Line 312
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2273247 (505:09.72, 4439MB)
    17.10.12 #5 Text 0 File DlgWaitCD.cpp, Line 324
    Write in overburning mode: NO (enabled: CD)
    17.10.12 #6 Text 0 File DlgWaitCD.cpp, Line 2951
    Recorder: HL-DT-ST DVDRAM GSA-T10N, Media type: DVD-R
    Disc Manufacturer ID: <SONY16> <D1>
    Disc Application Code: 64, Disc Physical Code: 193
    17.10.12 #7 Text 0 File DlgWaitCD.cpp, Line 499
    >>> Protocol of DlgWaitCD activities: <<<
    17.10.12 #8 Text 0 File ThreadedTransferInterface.cpp, Line 756
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (1 - DVD-ROM)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2273248 (2273248) = #2273248/505:9.73
    not relocatable, disc pos for caching/writing not required/not required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2273248 blocks [E: HL-DT-ST DVDRAM GSA-T10N]
    17.10.12 #9 Text 0 File ThreadedTransferInterface.cpp, Line 958
    Prepare [E: HL-DT-ST DVDRAM GSA-T10N] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4655611904, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2273248 | 0 | 0x00
    2273248 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    17.10.13 #10 Text 0 File SCSIPTICommands.cpp, Line 240
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    17.10.13 #11 Text 0 File Burncd.cpp, Line 4362
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
    17.10.13 #12 Phase 24 File dlgbrnst.cpp, Line 1767
    Caching of files started
    17.10.13 #13 Text 0 File Burncd.cpp, Line 4484
    Cache writing successful.
    17.10.13 #14 Phase 25 File dlgbrnst.cpp, Line 1767
    Caching of files completed
    17.10.13 #15 Phase 36 File dlgbrnst.cpp, Line 1767
    Burn process started at 4x (5.540 KB/s)
    17.10.13 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2675
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    17.10.13 #17 Text 0 File DVDR.cpp, Line 3259
    Reco***ng mode: Sequential Reco***ng Mode
    17.10.13 #18 Text 0 File DVDR.cpp, Line 3413
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    17.10.13 #19 Text 0 File Cdrdrv.cpp, Line 10187
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
    Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    Outer Limit of Data Recordable Area: 26127F h
    Data in Burst Cutting Area (BCA) does not exist
    Revision number of maximum reco***ng speed: 6.0
    Revision number of minimum reco***ng speed: -
    Revision number table of reco***ng speed: 1.0 2.0 3.0 4.0 5.0 - -
    Class: 0, Extended part version: 33
    Start PSN of the Extra Border Zone: 2FE10 h
    Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
    Media Specific [16..783]:
    00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    01 40 C1 FD 9E D8 52 00 - 02 84 0E 10 87 88 80 00 .@....R.........
    03 53 4F 4E 59 31 36 00 - 04 44 31 00 00 00 00 00 .SONY16..D1.....
    05 88 80 00 00 00 01 00 - 06 09 0B 12 A8 88 90 00 ................
    07 88 80 00 00 00 00 00 - 08 06 13 0A 0E 08 04 00 ................
    09 96 06 0C 0B 70 88 00 - 0A 80 00 00 00 00 10 00 .....p..........
    0B 08 18 17 B8 88 85 00 - 0C B6 79 0B B0 33 03 00 ..........y..3..
    0D 30 00 D0 00 00 00 00 - 0E 0A 20 3B 37 29 1E 00 .0.........;7)..
    0F 50 1D 2B 15 AA B5 00 - 10 88 80 00 00 00 00 00 .P.+............
    11 00 00 00 00 00 00 00 - 12 0A 2D 39 35 2B 1D 00 ..........-95+..
    13 50 1F 2D 19 98 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
    15 00 00 00 00 00 00 00 - 16 09 3A 45 40 2E 27 00 ..........:E@.'.
    17 80 21 2E 1F 78 B5 00 - 18 88 8C 00 0C 00 0C 00 ..!..x..........
    19 00 00 00 00 00 00 00 - 1A 09 4F 47 46 38 26 00 ..........OGF8&.
    1B 70 21 2D 1B 67 C5 00 - 1C 88 84 00 04 00 04 00 .p!-.g..........
    17.10.13 #20 Text 0 File DVDR.cpp, Line 3551
    Reserved Track size: 2273248 (22AFE0h, 4439MB) -> return code 0
    17.10.13 #21 Text 0 File ThreadedTransfer.cpp, Line 273
    Pipe memory size 83836800
    17.10.29 #22 SPTI -1135 File SCSIPassThrough.cpp, Line 215
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
    CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    Sense Area: 0x70 00 03 00 00 00 00 10 32 4D 03 0C 0C
    Buffer x0aac0040: Len x10000
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    17.10.29 #23 CDR -1135 File Writer.cpp, Line 306
    Write error
    17.10.29 #24 Text 0 File DVDR.cpp, Line 3819
    EndDAO: Last written address was -1 (FFFFFFFFh)
    17.10.29 #25 CDR -1135 File WriterStatus.cpp, Line 292
    Write error
    17.10.29 #26 TRANSFER -24 File WriterStatus.cpp, Line 292
    Could not perform end of Disc-at-once
    17.10.29 #27 Text 0 File DVDPlusDualLayer.cpp, Line 1424
    SetDriveCaps: Set LAST LBA of layer 1 to 0
    17.10.29 #28 Phase 38 File dlgbrnst.cpp, Line 1767
    Burn process failed at 4x (5.540 KB/s)
    17.10.29 #29 Text 0 File SCSIPTICommands.cpp, Line 287
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    17.10.31 #30 Text 0 File Cdrdrv.cpp, Line 11444
    DriveLocker: UnLockVolume completed
    17.10.31 #31 Text 0 File SCSIPTICommands.cpp, Line 450
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
    poate reuseste cineva sa inteleaga ceva
