Results 16 to 30 of 32
Thread: Dm 100
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default DM100 Loader / Channel Editor Version 2.3
    DM100 Loader / Channel Editor.
    New Version 2.3
    Uploaded 30-10-08
    http://rapidshare.com/files/15908732...erChEditor.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Re: DM100 Loader / Channel Editor Version 2.3
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  3. #18
    02 Feb 2007
    Default Dm100s firmware v0128
    Remember to do a Factory Reset after flashing new firmware.
    Expert PIN Code: 0101
    We fixed,
    - DiSEqC 1.1
    - USALS
    - Input USER ID 15 character in cccam user name,
    - FTA scan.
    Note This is a TEST version and NOT a full release.
    The bug with the standby button on encrypted channels is still the same.
    Don't switch off into standby on encrypted channels otherwise the box crashes.
    http://rapidshare.com/files/16183155...V0128_TEST.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  4. #19
    02 Feb 2007
    Default Dm100s firmware v0129
    Firmware v1.29
    In this version,
    We fixed
    Power on/off
    User ID & PW up to 15 digits for NEWCAMD, CCCAM
    DiSEqC 1.1
    CCCAM Port input up to 65499
    We Added
    SoftCAM Key Editor (in Expert Setup)
    We changed
    Subtitle menu by RCU subtitle button
    http://www.upload-drive.com/4507/DM1...9_20081115_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  5. #20
    02 Feb 2007
    Default Dm100s firmware v0130
    In this version,
    - Updated CCCAM, sorry for late update!
    - Modified softcam key editor
    - Changed subtitle
    - Fixed aspect ratio
    - Fixed diseqc,c
    http://rapidshare.com/files/16571607...0_20081120.rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  6. #21
    02 Feb 2007
    Default Re: Dm100s firmware v0131
    Dm100s_main_v0131_20081121
    Remember to do a factory reset after flashing.
    Expert menu Pin: 0101
    Release version1.31.
    Fixed OSD problem while power on/off
    http://rapidshare.com/files/16600468...1_20081121.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  7. #22
    02 Feb 2007
    Default Dm100s firmware v0132
    Firmware v1.32
    fixed:
    - Diseqc,
    - CCCAM server
    Notice:
    when you update new firmware, you have do ‘factory reset’,
    And all user setting will be erased. We will find a way to keep
    ‘user setting’ after updating new firmware without ‘factory reset’.
    http://www.upload-drive.com/5518/DM1...2_20081126_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  8. #23
    02 Feb 2007
    Default Dm100s V1.33
    Remember to do a factory reset after flashing firmware.
    Expert Menu Pin Code: 0101
    Use New XLoader 2.4 to flash firmware.
    In this version,
    Fixed,
    - scan problem
    - TV out mode when power on/off
    Added,
    - Czech, Polish language
    - cccam user id 20characters
    Sorry, CCCAM was not updated yet.
    http://rapidshare.com/files/17934823...3_20081231.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  9. #24
    02 Feb 2007
    Default DM100 Original Release V022F
    Release V022F from 24.12.2008 For Dreambox 100
    http://rapidshare.com/files/18455296...F_20081224.rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  10. #25
    Default Re: Dm 100
    Toate utilitarele si firm pentru DM100 le gasiti aici;
    http://www.worldofemu.com/
  12. #27
    02 Feb 2007
    Default Dm100s Main V0200s 30jan2009
    In this version,
    Updated CCCAM,
    Updated CCCAM Multiple servers,
    Changed CCCAM servers to 5 servers,
    Able to on/off emulator on CCCAM by 'remote emus',
    - recommend to stay 'off' on 'remote emus' for better quality.
    Channel data is compatible with any later versions since Ver2.00S,
    Able to share channel list with your friends,
    - no other information will be included in your channel list.
    Go into Main menu by pressing 'Menu button' directly without setting Antenna,
    Automatic factory reset when s/w updated,
    Update Astra/ Hotbird TP info,
    Able to input Nagra key upto 16bytes,
    Duplicated channels in network scan fixed,
    Teletext fixed,
    http://www.upload-drive.com/7565/DM1..._30JAN2009_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  13. #28
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  14. #29
    02 Feb 2007
    Default Dm100s main v0200n nemesis test
    Here we release new osd skin 'nemesis'.
    No need to do factory reset, all original settings will be retained.
    This is only a change of skin, user can select skin for his own taste.
    http://www.upload-drive.com/8579/DM1...MESIS_TEST_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  15. #30
    02 Feb 2007
    Default Dm100s V027F
    Firmware: Release V027F fur DM100 S from 04.03.2009
    http://www.sateliti-upload.info/inde...Dreambox%20100&
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
