Results 16 to 30 of 52
Thread: TV CABO &DIGITAL+ hacked!
    Standard RSP member eugennico's Avatar
    03 Feb 2007
    OLT
    Default Re: TV CABO &DIGITAL+ hacked!
    Pasi mari spre N3 , a aparut saptamana aceasta primul card N3 ,se numeste CENTAURUS si e conceput de ANNACONDA Team care se pare ca rupe tot in noul sistem si se spune ca ar "papă si ceva NDS"..........Pret 69,95 EUR http://ali.to/show.php?main_kat=4&kategorie=12&nr=
    http://img396.imageshack.us/img396/8115/centaj2.jpg
    Hier die vom Ana...
    ISO 7816 Smart****
    Flash: 72 kB
    Eeprom: 72 kByte
    Crypto: Yes (RSA)
    Protokoll: T0, T1, TE
    Language: ASM, (C)
    Programmable @ 3.57 MHZ
    Programmierbar zb mit Smartmouse und ProgBee
    Auslieferungszustand: leer mit OS
    ORIGINAL ANACONDA ****
    und hier die vom Centaurus,
    ISO 7816 Smart****
    Flash: 72 kB
    Eeprom: 72 kByte
    Crypto: Yes (RSA)
    Language: ASM, ©
    Programmierbar mit Smartmouse,
    ProgBee und anderen Programmern
    ORIGINAL Centaurus OS
    http://centaurus.to/
    05 Jun 2008
    mai asteptati un pic, nu are rost sa aruncati cu banii degaba
    23 Jun 2008
    Vorbe goale pana acum.
    Pentru a fi adevarat ar trbui sa vedem "ceva".Adica sa avem macar un decoder capabil N3.
    In ceea ce priveste "magic card" e doar interesul de al vinde!
    Anaconda-mare scofala.
    05 Jun 2008
    Quote Originally Posted by FizzIK View Post
    Non official receivers that so far work with nagravision 3 original or mosc cards with new firmware.
    Mirage models: sft-2000, sci-5110 and 8000 (Complex method but works).
    AZbox models: S710 - GA, S710 - GB, ST710 - GA and ST710 - GB.
    Mvision 9085 net and USB models. (Bought one over the weekend)
    23 Jun 2008
    Quote Originally Posted by Bengosu View Post
    Sa citeasca cardul N3 e una, sa decodeze pe baza de EMU/KEY e altceva.
    Poate m-am exprimat eu gresit.Eu ma refeream la a DECODA pe baza de EMU/KEY.
    PS: AZ-sunt pionierii N3.Ei au deschis primii calea spre N3(deocamdata doar cu CARD ORIGINAL)
    E deja normal ca sa se deschida mai intai cu anumite carduri si doar peste 6 luni-1 an sa apara emu pentru receptoare.De unde vrei sa scoata baietii banii?
    26 Oct 2007
    Ar fi o adevarata bomba pentru cei care inca se chinuie sa treaca spre N3.
    cat poate sa coste un card d'ala? tare's curios
    Quote Originally Posted by eugennico View Post
    E chiar mai ieftin decat predecesoarele lui.Va merge o jumatate de an si va ramane fara suport.Povestea se repeta.
    26 Oct 2007
    70 euro???
    mai bine iei rec cu linux...clona sau neclona, pentru inca 30-40 euro
    03 Feb 2007
    OLT
    Talking Re: TV CABO &DIGITAL+ hacked!
    ROM142
    http://img241.imageshack.us/my.php?i...2227605qx7.jpg
    http://img356.imageshack.us/my.php?i...2227661cf5.jpg
    http://img356.imageshack.us/my.php?i...2227752fo3.jpg
    ' Rom 142 GlitchTest
    ' Only Educational Purposes !!!!
    ' Enjoy !!!
    ' By Zeoroone && Mitega
    Option Explicit
    Dim StartDate
    Dim FileName
    Dim OutFile
    Dim StrCmd1
    Dim StrCmd2
    Dim MsgPrompt
    Dim MenuChoice
    Dim Bytes
    Dim Bytes2
    Dim ByteOut
    Dim InitDelay
    Dim EndDelay
    Dim InitVcc
    Dim LowVcc
    Dim GlitchType
    Dim Count
    Dim i
    Dim Dump
    dim Comando12
    dim boot1
    dim countx
    dim mixDelay
    dim mixVcc
    dim inVcc
    dim inDelay
    InitDelay = &H100
    EndDelay = &H400
    GlitchType = &H7
    InitVcc = &H40
    LowVcc = &H1
    mixVCC=1
    mixDelay=5
    inVCC = InitVcc
    inDelay = InitDelay
    Call SetupLoader()
    Sub Main()
    If CheckChipVer <> 1 then
    Sc.MsgBox("Flash your Loader with NewD13.hex")
    Exit Sub
    End if
    sc.verbose = 1
    Sc.Write("A0")
    Clearoutputwindow
    StartDate = Now()
    Do
    MsgPrompt="Rom142 Rev G01 GlitchTest"
    MenuChoice=Sc.ButtonBox(MsgPrompt,vbDefaultButton1+vbQuestion," ROM142 Rev G0
    1 GlitchTest" & " Versi.n : 1.0" & " - Men. : ","GO","Exit")
    Select Case MenuChoice
    Case 1: go()
    End Select
    Loop Until MenuChoice=2
    Exit Sub
    End Sub
    Sub go()
    Call Glitch
    End Sub
    Comando12="214008A0CA00000212000615"
    Sub Glitch ()
    SC.write("73 0A 70 214097A0CA000091048F49012410F600000000000000000000000000000000
    000000009D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9
    D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9D9BA699AD0CB752A6F04A26FDB652819D
    00")
    Sc.Read(2)
    Sc.Write("F0")
    Sc.Read(1)
    Bytes = Sc.Getbyte(0)
    Sc.Read(Bytes)
    Print"Initial Parameters = Delay:" & HexString(InitDelay, 4) & " VCC:" & HexStri
    ng(InitVcc, 2) & " Glitch Type:" & HexString(GlitchType, 2) & vbCr & vbCr
    Do
    Sc.Write("B0" & HexString(InitVcc, 2))
    Do
    Sc.Write("06 10 01 03 50 1A 00")
    Sc.Read(2)
    Bytes = Sc.Getbyte(1)
    If Bytes > 25 then
    Sc.Read(Bytes)
    countx=0
    Exit Do
    Else
    Count = Count + 1
    End If
    If Count > 100 Then
    ok = MsgBox("Card Maybe Looped - NO ATR - ", vbOKOnly, "Rom 142 ")
    Exit Sub
    End If
    Loop
    Sc.verbose = 0
    Sc.write("2F 15 0B 60 28 9DB7524FADF3AE0A431100ADE820001000ADE298250411002
    00410002000ADD5485A26F01000810272 50 07 00")
    Sc.Read(2)
    Sc.Read(Bytes)
    'CMD15
    Sc.write("16 1F 60 0B" + Comando15 + "20 "& hexstring(InitDelay,4) & hexst
    ring(GlitchType,2) & "50 00 00")
    sc.read(2)
    Sc.Read(Bytes)
    byteout=&h00
    if bytes > 0 then
    byteout=Sc.getbyte(0)
    sc.print HexString(byteout,2)
    If byteout = &h99 then
    bytes2 = byteout
    End if
    End if
    If Bytes2 = &H99 Then
    Sc.Write ("A1")
    Print " : ACK Received ....." & vbcr
    Print "***************************************" & vbcr
    Print " " & HexString(Bytes2, 2) & " Was Glitch at: Delay:" & HexSt
    ring(InitDelay, 4) & " VCC:" & HexString(InitVcc, 2) & " GlitchType:" & HexString
    (GlitchType, 2) & vbcr
    Print " Delay Range: " & HexString(InitDelay, 4) & " to " & HexStrin
    g(EndDelay, 4) & vbcr
    Print " Elapsed: " & TimeDiff(StartDate, Now()) & vbcr
    Print "********************************" & vbcr
    Print "* Rom_142 , Glitch Succes !! *" & vbcr
    Print "* *" & vbcr
    Print "* 142 Glitch Test *" & vbcr
    Exit Sub
    End If
    If ByteOut <> &H99 Then
    Print "."
    InitVcc = InitVcc - mixVcc
    If InitVcc < LowVcc Then
    InitVcc = inVcc
    InitDelay = InitDelay + mixDelay
    Print "vbcr & Delay:" & HexString(InitDelay, 4) & " VCCStart:" & HexStri
    Print "Elapsed = " & TimeDiff(StartDate, Now()) & vbcr
    End If
    End If
    If InitDelay > EndDelay Then
    InitDelay = inDelay
    GlitchType = GlitchType + 1
    If GlitchType > &H9 Then
    GlitchType = &H7
    End If
    End If
    Loop
    End Sub
    Function HexString(Number,Length)
    Dim RetVal
    Dim CurLen
    RetVal=Hex(Number)
    CurLen=Len(RetVal)
    If CurLen RetVal=String(Length-CurLen,"0") & RetVal
    End If
    HexString=RetVal
    End Function
    Function CheckChipVer()
    CheckChipVer = 1
    sc.write("90")
    delay(80)
    If sc.read(4) <> 4 then
    CheckChipVer = 0
    Exit Function
    End if
    If getbyte(0) <> &H4E then CheckChipVer = 0
    If getbyte(1) <> &H44 then CheckChipVer = 0
    If getbyte(2) <> &H31 then CheckChipVer = 0
    If getbyte(3) <> &H33 then CheckChipVer = 0
    End Function
    Function TimeDiff (StartTime, EndTime)
    Dim Hours, Minutes, Seconds
    Seconds = DateDiff("s", StartTime, EndTime)
    If Seconds > 90000 Then Seconds = 90000
    If Seconds < 0 Then Seconds = 0
    Minutes = Seconds / 60
    Minutes = Fix(Minutes)
    Seconds = Seconds - (Minutes * 60)
    Hours = Minutes / 60
    Hours = Fix(Hours)
    Minutes = Minutes - (Hours * 60)
    Seconds = CStr(Seconds)
    Minutes = CStr(Minutes)
    Hours = CStr(Hours)
    If Len(Seconds) = 1 Then Seconds = "0" + Seconds
    If Len(Minutes) = 1 Then Minutes = "0" + Minutes
    If Len(Hours) = 1 Then Hours = "0" + Hours
    TimeDiff = Hours & ":" & Minutes & ":" & Seconds
    End Function
    Function SetupLoader()
    sc.print "****************** Setting up WinExplorer ************************" & V
    bCr
    Wx.BaudRate = 115200
    Wx.ResetBaudRate = 115200
    Wx.Parity = 0
    Wx.StopBits = 0
    Wx.DTRControl = 0
    Wx.RTSControl = 1
    Wx.ResetDelay = 0
    Wx.ByteDelay = 0
    Wx.RxByteTimeout = 2500
    Wx.ResetMode = 2
    Wx.ResetLine = 1
    Wx.ByteConvention = 1
    Wx.FlushEchoByte = 0
    Wx.FlushBeforeWrite = 1
    Wx.IgnoreTimeouts = 1
    Wx.ResetAfterTimeout = 0
    Wx.LogTransactions = 0
    Wx.DisplayUSW = 0
    Wx.DisplayFuse = 0
    End function
    05 Jun 2008
    12octombrie 2007?
    03 Feb 2007
    OLT
    Rumours about hack NDS and Nagravision 3
    Since yesterday monitors our editors increasingly rumours about the possible hack of the NDS Videoguard and Kudelski Nagravision 3 coderingsystemen. In practice this could mean that the package of Sky Italia (Videoguard), the Spanish D (Nagravision3) and the German Premiere (Nagravision3) without paying any adjustments can be made visible.
    The potential of the hack Nagravision3 system will be a major blow to the ailing Swiss coderingsspecialist Kudelski. This past week, made known a substantial loss in the first part of 2008 ago. This was mainly suffered by the costs that the company had to make codes cracked by television weather to recover. Even the loss of customers by the long-term free channels has to look at the losses to Kudelski. In the Netherlands using the digital television CanalDigitaal (Mediaguard) and UPC (Nagravision2) the encryption of Kudelski well as other products and services of the Swiss company.
    The possible Nagravision3 hack is of a commercial nature. There will soon be a "smart card ijskrabber" on the market which brought more than 120 euros will cost. The force and any lasting effect of this smart card is totally uncertain, hence the pet name "ijskrabber."
    Today come from Italy also becoming increasingly stubborn rumors that have never publicly hacked Videoguard encoding of the English NDS prey would have been cases of hackers. It talks about using an old Nokia Dbox receiver via a particular file should be modified. This is the zenderpakket of the Italian branch of the worldwide Sky television. The international satellietforum Satscreen has been through an email to its members asked to holders of Dbox recipients to enter into the file on force to be tested.
    Satellite Magazine would unnecessarily indicate that use of modified smartcards and / or satellite receivers are free to be able to watch television which must be paid in the Netherlands through the Penal Code prohibited. Reason to strongly warn visitors of possible ways to look for free use.
    23 Jun 2008
    Ce zehnderpaket-prostii.
    Am la dispozitie toate prostiile astea.
    Am un Zehnder pe mana dar nu deschide decat ce deschide orice reciver obisnuit si nimic altceva.Asta apropo de Sky IT.E timpul sa deschidem ochii si sa nu mai citim porcarii.De fapt sa nu le luam in seama.
    Totul e o abureala,un fals nimic nu sta in picioare.
    Standard RSP member Sandutsu's Avatar
    13 Aug 2007
    Chisinau
    Vad ca apar de cateva zile cheile pentru D+ si TV Cabo ,cine stie ,sunt bune ,ori le pun special sa-l gadile pe Kudelski la nervi ?
    03 Feb 2007
    OLT
    d+ & tv cabo tested n3
    New encryption system nagra3 open, tested at 100% in receivers dreambox,Edision.
    http://www.crosat.org/aploud/index.p...xt&directory=&
