Likes Likes:  2
Page 1 of 3 123 LastLast
Results 1 to 15 of 255
Thread: Optibox CX PVR Ready
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Optibox CX PVR Ready
    Time Shifting cu device extern USB 2.0
    Inregistrare si Redare cu device extern USB 2.0
    Inregistare si Time Shifting in acelasi timp
    Inregistare si Redare in acelasi timp
    Inregistrare programata prin EPG
    Suporta Dual USB 2.0 (player MP3 Player si vizualizare JPEG)
    Transfer Software si Lista de programe prin USB
    Afisaj VFD 8 Digiti pe panoul frontal
    Blind scan
    MPEG-II Digital & Fully DVB Compliant
    Multi-LNB Controlat prin protocoalele DiSEqC versiunea 1.0, 1.1, 1.2 si USALS
    Cautare Multi-Satelit
    Suporta EPG (Ghid electronic de Program)
    Meniu de rezolutie mare in 65535 de culori
    Canale Favorite
    Sortarea canalelor dupa Alfabet, Transponder si CAS
    Suporta mai multe limbi ( OSD & Meniu )
    Suporta Teletext
    Maxim 10.000 canale
    Afisaj Multi-picture
    Parental Lock / System Lock / Installation Lock
    Iesire CVBS Video si Audio prin RCA
    Iesire CVBS, RGB Video si Audio prin TV SCART
    Iesire Optica AC3
    Iesire 0/12V
    Decodor video si Tuner
    Conector intrare: tip F, IEC 169-24, mama
    Iesire Loop: F-type, IEC 169-24, mama
    Gama de Frecvente: 950MHz ~ 2150MHz
    Impedanta de intrare: 75ohmi
    Signal Level: 65 to -25dBm
    Tensiune LNB: 13/18VDC, max. 400mA
    Ton 22KHz: (22±2)KHz, (0.6±0.2)
    DISEqC: V1.0/1.2/compatibil USALS
    Demodulare: QPSK
    Rata simbolurilor: 2 ~ 45 Ms/s
    FEC: 1/2, 2/3, 3/4, 5/6 si 7/8
    Decodare A/V MPEG Transport Stream
    Transport Stream:MPEG-II ISO/IEC 13818
    Profile Level:MPEG-II MP@ML
    Rata de intrare:Max. 15Mbit/s
    Formate Video: 4:3 LetterBox, 4:3 PanScan, 16:9
    Rezolutie Video:720 x 576, 720 x 480
    Decodare Audio:MPEG/MusiCam Layer I & II
    Mod Audio:Stereo/Joint stereo/Mono
    Rata de esantionare:32KHz, 44.1KHz si 48KHz
    Procesor si memorie
    Procesor: Conexant Virgo
    Memorie :Flash-ROM: 2 MBytes; SDRAM: 32 MBytes
    Intrari/Iesiri Audio/Video si Date
    TV SCART: iesire RGB, CVBS Video, Audio S, D
    VCR SCART: iesire CVBS Video, Audio S, D; intrare RGB, CVBS, Audio S, D
    RCA: iesire Video CVBS Video, iesire Audio S, D
    OPTIC: AC-3 Dolby Digital (S/PDIF)
    RS-232C:9 pin D-SUB (tata) type, rata de transfer 115Kbps
    USB: suporta USB 2.0 Host (panou Frontal si spate)
    Pret: 205 lei GARANTIE 3 ANI
    http://digitalsatelit.ro/shop/produc...222fb12156f3aa
    05 Jan 2007
    Default Re: Optibox CX PVR Ready
    05 Jan 2007
    05 Jan 2007
    softul se incarca pe un usb stick
    Attached Files Attached Files
    05 Jan 2007
    cateva noutati:
    tastand meniu+8282+ tasta recall desupra la sat permite sharingul la 9 receptoare. 1 server + 8 client
    stie subtitrare dvb cu caractere romanesti (sub tasta verde)
    o alta combinatie ar mai fi meniu + 8282
    mai puteti face incercari
    23 Apr 2007
    P3X-888
    felicitari asta da prezentare de receptor , treaba de profesionist .
    Standard RSP member xnetbogdan's Avatar
    23 May 2007
    Cum pot sa folosesc acest receiver in sharing prin portul rs232?adica merge cu gbox control sau cu alt soft?
    12 Aug 2008
    In fata calculatorului
    cel mai tare receptor pana acuma la care am pus softul
    datorita voua cei care scrieti
    va multumesc
    AM PUS SOFTUL CU STIKUL
    apoi s-a updatat SINGUR pe JIJI
    incredibil
    si merge subtitrarea
    bestial receptor
    se misca bine
    la pret bun
    MULTUMESC PENTRU USERI
    06 Oct 2008
    soft nou pentru Optibox CX PVR Ready :optibox.atw.hu/?a=downloads&path=./Optibox%2520TSCX%2520PVR
    06 Oct 2008
    Angry Re: Optibox CX PVR Ready
    am acest receptor de 2 zile si sunt foarte multumit de el , singurul lucru care mi-a dat bataie de cap si la care nu i-am gasit rezolvarea e modulatorul RF! nu reusesc sa vad canalele din banda UHF, ma poate ajuta cineva ?????:
    05 Jun 2008
    Ploiesti
    cum se pot salva key-le la Optibox CX PVR Ready dupa ce le bag manual? revine la alea vechi...
    Multumesc anticipat
    Standard RSP member gogu69's Avatar
    r12
    Trebuie sa asteptam sa apara un sw care sa nu faca update automat. Nu stiu de unde ia cheile alea, e posibil ca receptorul sa nu mai faca update-ul cum trebuie din cauza ca cei de la jiji au schimbat ambele key si 00 si 01.
    11 Oct 2008
    Unhappy Re: Optibox CX PVR Ready
    Nu am umblat mult cu acest receptor mult laudat si nu stiu cum sa il manevrez multumesc.
    08 Apr 2007
    No bun ... Mi-o adus si mie astazi "Mosh Craciun" o bucata ... ma apuc si pun pe unu 1.17.00 ... Brumiere nimik ... bag 1.17.03 ... Brumiere nimik ... (am stat pret de cateva minute pentru auto) = pixu ... Intru la keys, fac vreo 2 ture de zappinguri la dreapta si zic in capu meu ... "hai sa sterg toata tabla si dupa aia flashuiesc dinou, ca poate s-o agatzat ceva" ... dupa ce flashuiesc, tot asa nici o tabla de keys ... adica pot pune cate softuri vreau ca nu le mai vad si nici nu gasesc una bucata de minifisier pentru USB, ca sa flashuiasca adresa de memorie cu keys la loc. Ce se poate face??? Futui ...
    05 Jan 2007
