Results 1 to 4 of 4
Thread: FloppyDTV S2/CI
    27 Apr 2007
    Post FloppyDTV S2/CI
    Digital Satellite ( DVB-S2 and DVB-S ) Receiver for multimedia computer
    Main Features
    Support for HDTV Channels
    - DVB-S and DVB-S2 receiver
    - Software decoding of MPEG2 and MPEG4 / H.264
    - Watch and record TV in the highest available quality
    Read the "System requirements" below!
    Support for PayTV Channels
    - Integrated Common Interface , watch and record Free To Air or PayTV channels
    - Compatible with most popular CAMs
    - Tested with several PayTV providers
    PayTV channels require a CAM and a valid smartcard (subscription)
    Fully integrated in Windows Media Center
    - Easy to use in Windows Media Center
    - Driver for Windows Media Center in Vista64 are also available in the download section
    Windows Media Center doesn"t support MPEG4/H.264 channels!!!
    Integrated in most popular Media Center Software
    - Fully integrated in many TV Software like DVBViewer , Mediaportal
    - Driver for Vista 64 bit also available in the download section
    Fits in almost any computer!
    - FloppyDTV S2 can be mounted on any PCI, PCI-Express, AGP or empty slot
    - Need only a single PCI Slot
    - Connection to the computer through FireWire (IEEE1394)
    - Easy connect more than one FloppyDTV thanks to the integrated FireWire Repeater
    System requirements
    - FireWire (IEEE1394) port on board or with OHCI-adapter
    - For PayTV: CAM-Module, valid subscription/smartcard
    - For Windows Media Center in WinMCE 2005: RollUp2, MPEG2 software decoder
    - For Windows Media Center in Vista: Vista Home Premium or Vista Ultimate
    - For other compatible TV software: Windows XP SP2 or later, MPEG2 decoder
    - For SDTV: Pentium@ IV 1,5GHz, AMD Athlon XP+ 2000
    - For HDTV: Minimum: Pentium@ IV 3,5GHz, AMD Athlon XP+ 3500, DXVA/H.264 graphic card (Windows XP)
    Recommended: Dual Core processor (REQUIRED for WinMCE 2005 or Vista)
    - For H.264 channels: H.264 software decoders
    Front End features
    - Antenna Connector: F-Type 75 Ohm
    - Input Frequency Range: 950-2150MHz
    - Supported Modulation: 8PSK/QPSK (DVB-S2), QPSK (DVB-S)
    - LNB Supply, 13/18V, 22KHz tone, max. 400mA
    - DiseqC: 1.0, 1.1, 1.2 (depending on used Software)
    Included in the "FloppyDTV S2"
    - FloppyDTV S2, with pre-assembled power cable and FireWire cable (also suitable for connection to the motherboard)
    - Printed Assembly and Quick Install Guide
    - Setup CD with BDA and Windows Media Center driver for WinMCE 2005 and Vista 32Bit (Home Premium or Ultimate)
    - FireDTV Viewer Software to watch and record TV channels. Vista 32 and 64 capable, H.264 capable
    MPEG4 / H.264 Software decoders are NOT included in the FloppyDTV S2 package
    Accessories (sold separately)
    A "FloppyDTV Extender KIT" will be available soon and will include:
    - 3,5" FloppyDTV Adapter
    - Remote control
    - MPEG2 / MPEG4 Software decoders
    - CD with Drivers and FireDTV Software
    - Also suitable to be mounted on 3,5" Floppy Drive Bay (additional adapter available separately)
    - Download the Assembly Guide
    Manual de asamblare
    Mai multe detali si Download
    Pret: 169.Euro
    24 Feb 2007
    45°39'N & 25°35'E
    Default Re: FloppyDTV S2/CI
    Foarte interesanta.....daca ar fi si un tuner mai sensibil decat la ss2....ar fi cred muuult mai buna o placa din asta....cu toate ca e cam pretentioasa la resurse.
    Nu recunosc tunerul.........
    De urmarit in continuare placuta asta
    27 Apr 2007
    Thumbs up Re: FloppyDTV S2/CI
    Dupa cate am citit eu din revista "Quale Computer" este cam foarte interesanta aceasta placa si a cam trecut multe teste.
    RSP - Team dan2000's Avatar
    28 Feb 2007
    roma
    poate nu credeti dar eu am 2 placi dvb un ss2 rev2 ..., si un ...jepsen ... aica o chinezarie ... nu am mai atins ss2 de cand am observat diferenta neta intre ele . nu se inchinge nu se blocheaza si e si mult mai sensibil .
