SmartReaderPlus
The SmartReader. The SmartReader is a USB cardreader / programmer based on a powerful ATMEL ARM 91 processor.
The SmartReader + incorporates an integrated USB to Serial converter, which enables the SmartReader plus to work with all standard Phoenix compatible Linux and Windows applications.
# Powerfull ARM® 91 Thumb® Processor
# High-performance 32-bit RISC Architecture
# High-density 16-bit Instruction Set
# 64 Kbytes, organized in 512 Pages of 128 Bytes (Single Plane)
# 16 Kbytes Internal High-speed SRAM, Single-cycle Access at Maximum Speed
# Low-power RC Oscillator, 3 to 20 MHz On-chip Oscillator and one PLL
# Supports 3.20, 3.43, 3.69, 4.00, 4.36, 4.80, 5.34, 6.00, 6.86, 8.00, 9.61, 12.0 and 16.0 MHz for smartcards
# Supports standard ftdi_sio driver for Windows and Linux applications
# Developer guide available
# Works on all Dreambox Models with USB connection
# Works with most softcams (e.g. Newcs, CCcam ect.)
# Can be cascaded with more SmartReaders using a USB Hub
# No power supply required
